[ROM] CyanogenMod 11.0
CyanogenMod 11.0 for Samsung Galaxy Mini 2
Ne io e androidiani ci assumiamo la responsabilità di eventuali danni che questa custom rom potrebbe causare sui vostri dispositivi
TOPIC DI XDA: CyanogenMod 11.0 for Samsung Galaxy Mini 2 - xda-developers
La rom funziona sui modelli:
-GT-S6500;
-GT-S6500D;
-GT-S6500T;
-GT-S6500L.
Cosa non funziona:
* Fotocamera
* Native screen recording
Dawnload:
Google apps: Vedere nella pagina di xda visto che non riesco mai a mettere il link funzionante per un periodo lungo
Download: http://goo.im/devs/thewhisp/jena-cm11
Come installare:
1) Raccomando di usare questa ClockWorkMod : http://forum.xda-developers.com/show....php?t=2156194
2) Download ROM .zip
3) Download Google apps
4) Metti il file zip scaricato nella sd (internal or external storage)
5) Accendi il telefono in recovery mode
6) Ti consiglio di fare un nandroid backup
7) Wipe data/factory reset
8) Format /system (se vieni da altre versioni di CM)
9) Installa la ROM .zip file
10) Mount /system, installa le Google apps
11) Fatto
Bug reporting:
https://github.com/TheWhisp/android_...ues?state=open
1) Visit the above link
2) Click on "New issue"
3) Enter title that explains the problem
4) Explain your problem very clearly with as much details as possible
5) Attach logs and screenshots (if needed)
Don't report a bug if it's already reported.
Don't report a bug if you:
1) have restored apps with Titanium Backup or similar software
2) are using any kind of task killer
3) are using any 3rd party tweak/hack
Name what device you're using: jena, jenad or trebon
Name CM version you're using: 10, 10.1, 10.2
Use proper English, try not to make any spelling errors so I and other people can understand you correctly.
XDA:DevDB Information
CyanogenMod 10.2 for Samsung Galaxy Mini 2, a ROM for the Samsung Galaxy Mini
senti,la cwm 6.0.2.8 non va bene?
Attendo una prima build stabile
Fesmo97
No, secondo il thread di XDA, bisogna usare la 6.0.4.5
Fesmo97
non ha il supporto per kit kat
a me da installation aborted..nn riesco ad installarla..
dawnload di una prima build disponibile ora la provo!
L'hai provata? Comè?
Inviato dal mio GT-S6500D usando Androidiani App
ok provata non va il wifi!!
ciken
il wifi a me funziona ...
