Pagina 28 di 47 primaprima ... 18262728293038 ... ultimoultimo
Visualizzazione dei risultati da 271 a 280 su 464
[KERNEL][4.3/4.4.2] CivZ-Engine/KatEngine/KatTurbine
  1. #271
    Androidiano VIP L'avatar di dado72
    Pesaro-Urbino[orig SALENTO]
    GalaxyNOTE-SM-N9005-S2 GT-9100
    Ringraziato 1,196 volte in 434 Posts
    Quote Originariamente inviato da nickGT9100 Visualizza il messaggio
    Changelog della 3.0?
    questa e la changelog
    Changes compared to stock kernel.
    • Selinux status = Permissive
    • NTFS R/W support with the use of Paragon (see playstore)
    • ExFat
    • XZ compressed
    • Build in init.d support
    • DynamicFsync
    • insecure & adb insecure
    • Power suspend driver_1.2 @ Faux123
    • Synapse control added with various options: CPU control; Kernel controls...
    • Led control_1.1 @ Yank555.lu
    • mdnie control_1.3 and synapse support @ Wootever
    • Faux Sound_3.2 @ Faux123 & Wootever
    • 2.88GHz Maximum overclock (unlock with Synapse app)
    • TouchBoostdriver Min frequency locked = no more jumping to 1.1GHz as minimum frequency
    • Voltage control thanks to myfluxi & synapse voltage control thanks to wootever.
    • Intelli HotPlug_2.3 & ECO Mode @ Faux123
    • GPU control
    • Governors: IntelliActive , Conservative , Adaptive, wheatly , powersave , interactive , performance, Pegasusq.
    • Schedulers: cfq , noop , bfq , deadline , vr , row , fiops , fifo , sio , zen.
    • OC Unlock / lock setting in Synapse = Default is set at 2.265GHz stock speed. = Replacement for maximum frequency lock (Based on angelom max_limit)
    • Extra driver support (Starting from Rev2.4)
      USB_RTL8150
      USB_HSO
      USB_DUN_SUPPORT
    • FrontSwap and CleanCache (Starting from Rev2.4)
    • Compiled in release mode = stripped of all debugging (Starting from Rev2.4)
    Edit:
    Appena flesciato ottimo direi e questi sono i risultati ancora lo devo settare
    Ultima modifica di dado72; 08-04-14 alle 12:09
    <-----Un grazie non costa niente premi Thanks
    Sviluppatore Android L'avatar di luigimak
    Catania
    OnePlus 3, OnePlus 5
    Ringraziato 11,257 volte in 3,483 Posts
    Quote Originariamente inviato da dado72 Visualizza il messaggio
    • ExFat
    • XZ compressed
    • DynamicFsync
    • GPU control
      USB_RTL8150
      USB_HSO
      USB_DUN_SUPPORT
    Edit:
    08/04/2014: Release SnapKat Rev 3.0 N9005/N900T
    Compiled on GCC 4.8 Google toolchain with optimizations.
    Reverted a bunch of commits in the hope to resolve the reboot problems
    Small update in voltage commit
    GPU OC removed as there seems to be a negative effect on the system performance when changing to higher frequency.
    some cleanups
  4. I seguenti 2 Utenti hanno ringraziato luigimak per il post:
    dado72 (08-04-14),kavstefa (08-04-14)
  5. #273
    GT-I9505 <3
    Ringraziato 28 volte in 24 Posts
    • ExFat
    • XZ compressed
    • DynamicFsync
    • GPU control
      USB_RTL8150
      USB_HSO
      USB_DUN_SUPPORT
    Edit:
    Direi che cammina!
    Device:I-900F White
    Rom : X-Note v1.1
    Kernel : X-Note v1
    Recovery : CWM
  6. #274
    Ringraziato 70 volte in 63 Posts
    Io per ora ho cambiato solo gli scheduler i/o. Magari qualcuno può consigliarmi una configurazione che aumenti le prestazioni senza intaccare eccessivamente la batteria? È per uso classico, poco gioco.
  7. #275
    GT-I9505 <3
    A me non tiene le frequenze...Durante antutu mi mette la cpu a 1.47 ghz da solo....si abbassa lo scaling e ci si mette a pari....quindi faccio punteggi bassi...a 2.8ghz lavorava a 1.9 e ho fatto 37300 quindi tecnicamente a frequenza ori dovrei stare intorno ai 37500...il problema è che non riesco
    Device:I-900F White
    Rom : X-Note v1.1
    Kernel : X-Note v1
    Recovery : CWM
  8. #276
    Androidiano L'avatar di reddev94
    Galaxy Note 3
    io penso sia antutu " buggato ".....anche a me la maggior parte delle volte cambia le frequenze e le impostazioni del governor.......ti consiglio di andare in gestione applicazioni e fare cancella dati e chace di antutu e arresto forzato ( e di fare cio dopo ogni volta che lo usi )
    Android è la cosa migliore che ti possa offrire la vita!!!!!!!.........o forse è la seconda????......
    Smartphone: Samsung Galaxy Note 3
    ROM: X-Note build 20.0
    Kernel: LeanKernel 3.14
  9. #277
    Ringraziato 21 volte in 17 Posts
    Ma a voi non gracchia l'audio con questo kernel???? Io monto la rom Omega V12 e con il Civz e l'Abyss se vado in impostazuoni-dispositivo-suono-suonerie e provo un pò di suonerie a volume max o cmq sostenuto, l'audio gracchia da paura. Ora ho messo il Lean kernel e questo problema non si presenta. Verificate anche voi.
  10. #278
    Quote Originariamente inviato da emcantu Visualizza il messaggio
    Prova ad andare synapse sound è da li regoli il volume
  11. #279
    GT-I9505 <3
    Quote Originariamente inviato da reddev94 Visualizza il messaggio
    Antutu si relaziona con synapse? Perché per esempio lo scaling non me lo fa impostare poi come dovrebbe
    Device:I-900F White
    Rom : X-Note v1.1
    Kernel : X-Note v1
    Recovery : CWM
  12. #280
    GT-I9505 <3
    0 problemi sinceramente
    Device:I-900F White
    Rom : X-Note v1.1
    Kernel : X-Note v1
    Recovery : CWM
