Pagina 45 di 117 primaprima ... 3543444546475595 ... ultimoultimo
Visualizzazione dei risultati da 441 a 450 su 1170
[ROM][N910F][COI3]Dr.Ketan ROM - Port Note5/S6 Edge + Xposed Aggiornato 5.1.1
  1. #441
    Senior Droid L'avatar di HacKasS
    Apr 2014
    Note 4 (N910F)
    Ringraziato 285 volte in 235 Posts
    Quote Originariamente inviato da vitale Visualizza il messaggio
    solo GPS fix
    Si piu o meno.. C erano altri piccoli bug che hanno avuto solo alcuni utenti..
    Se sono stato d'aiuto premi il tasto Thanks
    Apr 2014
    Note 4 (N910F)
    ChangeLog L16.
    I have already planned to stop further development on LP but couldn't leave because of some issue reported (Specifically long standing Map/Navigation issue) So here I hope final version of lollipop. (yet can't promise for MM)
    There is no feature wise major changes but sure there should be better stability. As previously did this time also two versions of ROM available 16F and 16G F and G denotes base of ROM. G based on N910G base and F similarly from N910F base. If you want to use stock kernel (Provided) you have to use your device variant version only. Like N910G have to use L16G and N910F have to L16F But if you want to use cross variant e.g L16F on N910G OR L16G on N910F (This implies to T-Mob users) then you have to use custom kernel.
    ChangeLog of L16
    L16F is based on N910FXXU1COL3(AP)_N910FOJK1COK1(CSC)_N910FXXU1COL1 (Baseband/Modem)
    L16G is based on N910GDTU1COL2(AP)_N910GOLB1COL3(CSC)_N910GDTU1COJ4 (Baseband/Modem)
    - All the features of L15 will remain as it is.
    - New feature (Samsung's Old feature) added - Now you will have old option to select*Once only OR Always*to app when have multiple choice
    -*GPS (Navigation) issue fixed*(hopefully**) Tested newer Map version 9.21 from play store and navigation working as it should be on both L16 F/G
    - Workaround for faster homescreen after reboot (earlier there was little delay)
    - Some changes made in ROM wizard (appears after first boot). I strongly recommend to select to apply essential fix when it appears on screen. It will auto fix all then required fix, remove trial tag from material black theme. Also it will offer to setup battery icons and option to setup clock (it will appear once wizard finish). These two options are bcoz of almost everyday we read where is my clock and how can i change battery icon to stock**Hope this should get rid of these messages.
    - Some tweaks added to remove left over of ROM when you flash other ROM.
    -*Statusbar clock transparency issue fixed. Now you can use potato clock (Clock mode) with same stock color clock (default color is set to stock)
    - Location setting (Long press location QP toggle) added few more settingsAssisted GPS toggle (Later I found this option is useless and even not applied, may be samsung have stuck it to enabled permanently )Satellite view*- you can see how many satellite used to fix GPSSync with GPS clock*- Useful for person on roaming, they may not require to change time manually and clock will set according local time via satellite. I haven't tested this feature yet.
    -*Material black theme (A series exclusive)*is preinstalled (Sorry but it is my favorite theme and I wish it to be ready out of box. If you don't like just open setting - theme - select material black and delete).*
    PS : Don't apply it when there is trial tag there. After one reboot trial tag will auto removed and you can apply theme.
  4. Il seguente Utente ha ringraziato HacKasS per il post:
    lorenzo63 (12-03-16)
  5. #443
    Apr 2014
    Note 4 (N910F)
    Intanto scaricate la L16.. Il modem è uguale alla versione precedente..
    http://d-h.st/K0sf
    Piu tardi aggiorno la guida
  6. #444
    Ringraziato 24 volte in 24 Posts
    Basta flashare e fare solo wipe cache e dalvik?
  7. #445
    Apr 2014
    Note 4 (N910F)
    Quote Originariamente inviato da mariokart Visualizza il messaggio
    Segui la procedura della prima pagina
  8. #446
    Androidiano L'avatar di El Moro
    Samsung Galaxy Note IV
    tutte le estensioni di S Note ora sono installabili !
  9. #447
    Senior Droid L'avatar di lorenzo63
    Foggia
    Samsung Galaxy S9+
    Ringraziato 103 volte in 86 Posts
    Flashata solo con wipe cache e dalvik. .. sembra funzioni tutto bene...
    DEVICE: S9 Plus
    ROM: stock
    LAUNCHER: Nova
    KERNEL: stock
    CARRIER: VODAFONE
    EXT-MEM: Samsung micro SD 64GB class 10
  10. #448
    Apr 2014
    Note 4 (N910F)
    Quote Originariamente inviato da El Moro Visualizza il messaggio
    Ottimo io ho finito tardi di lavorare quindi flasho domani.. Voi intanto fatemi sapere se è tutto ok
  11. #449
    Apr 2014
    Note 4 (N910F)
    AGGIORNAMENTO L16:
    LINK DOWNLOAD AGGIORNATO..
    IL BOOTLOADE\MODEM È UGUALE ALLA VERSIONE PRECEDENTE..
    Si consiglia di partire da base pulita (WIPE FACTORY RESET)
    Aggiorno il changelog appena ho tempo...
  12. #450
    Grande aggiornamento adesso funziona alla perfezione snote, anche al riavvio e migliorato e più veloce a caricare tutto, un piccolo problema che ogni tanto si presenta in tutte le rom dr.keatan la connessione internet Wi-Fi e cellulare si blocca e devo riavviare, volevo sapere se qualcuno di voi usa tastiera Samsung alternativa dove quando scrivi ti suggerisce emoticon e ultima cosa come mai Livello patch di sicurezza e fermo a novembre 2015 si può aggiornare?
