Pagina 178 di 978 primaprima ... 78128168176177178179180188228278678 ... ultimoultimo
Visualizzazione dei risultati da 1,771 a 1,780 su 9780
[ROM][KK][4.4.4 PORTING] Ditto Note 4 (by Electron Team) | Note 4 Features
  1. #1771
    Androidiano VIP L'avatar di andy88de
    Ringraziato 754 volte in 508 Posts
    Ecco il change log come vedete la base è europa MK9 il Selinux sarà disabilitato alcuni aggiornamenti come quello sms appaiono interessanti...niente di rivoluzionario vedremo se saranno messi in ordine i piccoli bug presenti
    @titooo7
    Changelog of 3.2
    -MK9 used as rom base
    -Added some ML4 files
    -Kernel with Selinux disabled
    -Supersu and some other apps updated
    -Share accessibility fc fixed
    -Fixed wipe option in aroma installer
    -SMS app with features backup/restore , no sms to mms conversion, no sms in call logs thanks to (pending to check)
    -Option to choose mk4, mk9 or ml4 modem
    -Optional transparent multiwindow
    -Optional beats megabass thanks to (pending to check)
    -Optional *DN3 custom sounds and bootanimation thanks to (pending to check) and our LTE team member solohendo
    -Optional performance tweaks configuration of Marcosuper7 from htcmania.com
    -Some other things we probably forget at the moment
    Note 1:
    Performance tweaks and dn3 sounds and bootanimation are disabled by default in aroma, so those who want them should test it.
    "I tweak performance, audio e boot animation sono disabilitati di default in aroma...."
    Note2:
    Personally I usually have my doubts about any kind of performance tweaks, but a lot of Spanish users have been using them for more than one month and most of them noticed a positive difference. Some of us also used them for some time and we could see that it really improves boot time after doing wipes and I persobally also felt that the rom was a little bit more responsive. So the option to have performance tweaks is there so now is upto the users to enable it or disable it. Thanks for Marcosuper7 for that.
    Ultima modifica di andy88de; 03-01-14 alle 16:01
  2. Il seguente Utente ha ringraziato andy88de per il post:
    8thphloor (03-01-14)
    continua.mente
    Quote Originariamente inviato da marco9797 Visualizza il messaggio
    Mats aveva degli esami o titoo uno dei due
    Appunto!
    Non è che c'è da star qui a scrivere che le persone sono poco serie solo perché badano a cose un pochino più importanti di una custom rom!
  5. I seguenti 3 Utenti hanno ringraziato continua.mente per il post:
    alberisca75 (03-01-14),andy88de (03-01-14),nickaka (03-01-14)
  6. #1773
    Senior Droid L'avatar di marco9797
    Varedo
    Note 2 n7100
    Ringraziato 138 volte in 128 Posts
    Quote Originariamente inviato da continua.mente Visualizza il messaggio
    Appunto!
    A volte la gente non capisce che sono solo delle passioni degli hobby non si puo essere presuntuosi con chi svolge questo compito con fatica e senza lucro
  7. I seguenti 3 Utenti hanno ringraziato marco9797 per il post:
  8. #1774
    Senior Droid L'avatar di pierpaolos
    Sep 2013
    Torre Annunziata (Na)
    Note 3, Note 2
    Ringraziato 181 volte in 122 Posts
    bastava rilasciarla domani ecco cosa vuol dire serietà.... se uno rilascia una cosa deve almeno testarla per bene ... non le cose fatte a capa... e poi scompattare un file e rifarlo zip per loro dovrebbe essere una minchiata. con la perdita di una decina di minuti ma per chi non è pratico o sta dietro a loro e poi gli seve il cell non può stare in attesa..... della serie ci si perde in un bicchiere d'acqua...
    Ultima modifica di pierpaolos; 03-01-14 alle 16:06
  9. #1775
    Varedo
    Note 2 n7100
    Quote Originariamente inviato da pierpaolos Visualizza il messaggio
    Qualcuno mi dice che l'hanno testata prima di rilasciarla semplicemente l'upload du una rom non è sempre una cosa facile e si può corrompere....informati
  10. #1776
    Tranquilli ragazzi...che problema c'è aspettiamo di vedere come va...
  11. I seguenti 3 Utenti hanno ringraziato andy88de per il post:
    8thphloor (03-01-14),alberisca75 (03-01-14),interzippo (03-01-14)
  12. #1777
    Androidiano L'avatar di kurt89
    Oct 2010
    Varese
    Mate 10 Pro BLA-L29
    Ringraziato 45 volte in 41 Posts
    Questo è il changelog :
    Changelog of 3.2
    Phone : SGNII GT-N7100 Rom : Stock Prerooted ML4 Version : 4.3 Firmware : N7100DDUEML4 Modem : N7100DDEMK1 Kernel : Stock
    Theme : Nova launcher Prime
  13. I seguenti 2 Utenti hanno ringraziato kurt89 per il post:
    8thphloor (03-01-14),interzippo (03-01-14)
  14. #1778
    Caro Pierpaolos, ci sono persone che perdono il tempo per passione, senza prendere una lira per metterci a disposizione rom varie e migliori di quelle stock.
    Se il cellulare ti serve semplicemente evita, invece di lamentarti come un ragazzino a cui spetta tutto quando è come vuole lui. Non te l'ha ordinato il medico di cambiare nulla, e visto che non paghi una lira abbi un minimo di rispetto per chi si fa un mazzo così è non chiede nulla.
    Se non ti va bene amen, sono certo che sapresti, anzi, saprai, fare di meglio e più velocemente.
    Cordialità.
  15. I seguenti 3 Utenti hanno ringraziato zioneed per il post:
    8thphloor (03-01-14),interzippo (03-01-14),tezuya13 (03-01-14)
  16. #1779
    Campobasso
    Samsung Galaxy S6 flat
    Ringraziato 149 volte in 131 Posts
    Ragazzi se mi dite come uppare la rom e dove provo a metterla
    Inviato dal mio Super S6 super moddato!!!
    Se ti sono stato d'aiuto premi il tasto thanks.
  17. #1780
    Androidiano L'avatar di scorpion74
    Bergamo
    Galaxy S1 S2 S3 Note2
    per il momento aspetto a flashare la ditto 3.1 va da paura
