Grazie per la risposta.
Ascolta non è che gentilmente potresti dirmi come configurare il kernel agni per un consumo minore di batteria?
Grazie mille in anticipo!
bruttissime notizie in arrivo![]()
post del dev della rom:
Listen guys
5.4.9 has been officially announced but im not building it for 2 reasons:-
1. I'm out of town and I will be back on 6th July ....
2. We are getting toooo many complaints about this not being stable even on v2
Our lead developer @westcrip has asked me to stop maintaining for this device as we are getting toooo many reports from you guys claiming there are too many bugs .even in v2
Now tell me something guys .I have done every thing in my power to help get this build to be stable
What's wrong now? Why is it that some people are still reporting device specific issues?
We are getting too many of them on our g+ and Facebook page
Because of reports of n7100 and i9300 we are having some bad reviews on social media websites
I had already said reporting device specific issues is gonna make it difficult and now @westcrip has asked me to stop maintaining for this device ....
If you guys don't want this to happen I want you to share some positive experience ( if you have any) over the latest release on the g+ page and let everyone know if the ROM is bug free or not!
Please cooperate or this device will be discarded from the official device list
Share your thoughts here on the G+ page :
https://plus.google.com/communities/...46351468373340
You guys have uptill 6th July till I reach home and if I get some amount of positive feedbacks here or on g+ , I will continue maintaining this device .
Thank you for listening
Have a good day
molto difficile dare consigli di questo tipo vista la differenza di uso tra i vari utenti..puoi agire sull'undervolt, aumentare le soglie di attivazione dei core, scegliere un governor più risparmioso, minimizzare l'impatto gpu...ma c'è un ma...l'agni su questa rom è piuttosto delicato (almeno sul mio device)...potrebbe aumentare l'instabilità. insomma bisogna sperimentare di persona..
un'alternativa può essere scegliere uno dei main profiles in agni control
EDIT AGGIORNAMENTO
Nuovo post di varun date
Thank you to all those who posted positive feedbacks on g+
@westcrip is very happy with them and we shall continue development for this device all thanks to your positive feedbacks
Thank you once again
Expect a release on 6th July
We love you all
Take care
God bless
Ultima modifica di 8thphloor; 03-07-15 alle 22:24
The answer to the ultimate question of life, the universe and everything is:
CLEAN FLASH
Giulio1000 (03-07-15),pomokiss (04-07-15)
Ciao, ho letto le ultime news e ne sono contento.
Personalmente ho provato le ultime versioni sia di questa ROM che della CM12 e continuo ad avere problemi piuttosto seri. WiFi lentissimo quando non del tutto fermo e numeri in uscita costantemente segnalati come sconosciuto.
Ho provato tutti i fix proposti nei vari forum e qualche altro trick ma nulla da fare, i problemi persistono.
A questo punto torno alla DN4 o vedo cosa fare, magari stock e root .
Apprezzo enormemente gli sforzi di sviluppo ma il tipo di problemi riscontrati sono bloccanti nell'uso quotidiano.
Qualcuno ha aggiornato all'ultima versione? Mi è stata notificata stamattina, tutto bene tranne che per le vibrazioni, rimane fissa ( un pò troppo forte ) e non è possibile modificarla tramite il menu presente in impostazioni/configurazioni/misto.
Possiamo solo decidere cosa fare con il tempo che ci è stato concesso...
Resurrection Remix Lollipop 5.1.1 - v5.5.0
Merge tag Android-5.1.1_r6 (Clean installation highly recommended)
Pie Tile
Add App sidebar
App sidebar: Long press Launch in floating mode
App sidebar : Fix hardcore switch & System uı FC
Notifications: Launch in floating mode button.
Floating windows update: Fixes and Improvements.
SystemUI: use smaller padding for battery
SystemUI: DozeService: Prevent NPE
HeadsUp snooze function
HeadsUp: only snooze when swiping up
Fix lot of system ui issues
Fix keyguard freezes
Charging indicators for text-only battery view
Use 24dip of height for statusbar - M style
Update default wallpaper
Update Pitch Black theme
OTA:Fixed property name for current file
Massive APN Update
Fix Sprint 3G
SystemUI: fix recents task view height calculation
Turn off screen pinning off by default in recents
Selinux Switch
Add mw settings and tile
Make G notification font colors more compatible with dark and light themes
Screen pinning improvements
Add missing wallpaper permission
[ActivityManager] Refactor broadcast and reduce deliver delay.
Battery saver enhancements
Enable fingerprint option in Settings & Numerous Fingerprint Improvements
density: do not apply to virtual displays
packages/apps/Contacts/
Contacts: Fixed "%s" appearing in contact options in some languages
Russian and Italian Translations improved
settings: Fix developer options crash when mBackupManager is null
msim: fix parse error when roaming with slot 2 only
Forward Port Floating Window with Multitasking. Forward Port and Fixups done by BlackDragon && rogersb11
Selinux Switch
CM Recovery RAINBOW MODE MOTHER****ERS & improve Rainbow Mode
Email: Allow saving attachments even if there's no intent handling them & Allow download of compressed attachments.
SystemUI: dynamically generate visualizer color
Fix LiveDisplay notification.
OTACenter: remove old translations
Settings: fix confirm pattern crash on rotate
Add Left clock
Calculator: Remove duplicate color.
SystemUI: fix visualizer tile initial state
Frameworks/base: Add removeAll for ArraySet
SystemUI: Double tap to sleep anywhere on the lock screen
Reduce greeting default timeout
Dont show greeting and carrier label on keyguard
Fix navigation bar view after apply theme
Default time format is hard coded to 24
Enable Advanced Reboot by default
Remove superuser indicator option
Add Volume Key Answer
Many device specific changes as well
Updates from CM
For more detailed changelog check commits on github
people on 5.4.8 should get OTA notification
EDIT ..in test da ieri sera...la miglior RR mai provata...
Ultima modifica di 8thphloor; 08-07-15 alle 16:56
CLEAN FLASH
A me release precedente e questa hanno reso inutilizzabile il WiFi. Provato letteralmente di tutto, senza esito. Non capisco davvero il problema ma è critico. Passato alla cm12 ultima versione va come un treno.
Cavoli installata la 5.5.0, fatto tutto il necessario per mettere a posto la ROM, e manco 10 ore dopo un altro aggiornamento.
Va bene, significa che mantengono la ROM aggiornata, però adesso si esagera, non posto mica passare le giornate ad installare e mettere a posto il cellulare
CLEAN FLASH
Si però mi sto kakando letteralmente sotto, sono in servizio 118 d'urgenza avanzato ed il Sygic mi va in crash sovente, segnalando che si é chiuso in modo anomalo.
Pensa quando stati andando su un paziente ed alla guida ti si chiude il navigatore, mettiti nei miei panni...
ciò che scrivi ad essere sincero mi inquieta e non poco...forse, vista l'importanza del lavoro per cui il telefono viene utilizzato, sarebbe il caso di restare stock o almeno su una rom più stabile e "sicura"...
p.s. ti invito a non lamentarti degli aggiornamenti troppo frequenti, perchè il dev è sensibile all'argomento. e non vorrei che ripensasse a mollare...questa rom per un uso normale è fantastica![]()
CLEAN FLASH
