Pagina 4 di 6 primaprima ... 23456 ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 58
(Rom) CriskeloRomNOTE
  1. #31
    Senior Droid L'avatar di Maurizio7013
    Ringraziato 34 volte in 30 Posts
    Sinceramente a me sembra rientrare nella media...ora ho messo modem LA4
    Inviato dal mio Note
    Senior Droid L'avatar di garret79
    Aug 2010
    Trecate
    lg g3,asus zenfone 2,galaxy s6
    Flashata funziona perfettamente!!Ho solo cambiato il kernel con l'abyss e mi sembra vada ancora meglio!!
  4. #33
    Riserva Navajo
    [ROM] CriskeloRomNOTE. v5 BaseRom XXLA6 - CallRec -Jkay Mod13.5.1-14Toggles-THEME ICS
    http://www.jota.cl/criskelo/ROMS-NOT...DAD2521CC4.zip
    Changelog
    • Rom No Wipe (not erase your data)
    • Kernel AbyssNote
    • New Base Rom LA6
    • Modem LA4
    • Updated Jkay v13.5.1 + Spanish
    * Added one more row of sliders to AOSP lockscreen (now 4 rows)
    * Added quick Wi-Fi hotspot toggle panel
    * Added the 4 power buttons (reboot, recovery, download and power off) to panel quick too (by request!)
    * Fixed bug when "Screen on 'quick toggle panel WAS enabled at boot (FC would SystemUI)
    * Fixed a bug on screen at lockscreen Deluxe AOSP off
    • Fixed problem with clean install
    • New DigitalClock MY MOD AND SamsungWidget_WeatherClock Transparent
    • Improved scrolling of contacts
    • CallRec Phone.apk with option
    • TW mod launcher to use 4/5 icons in the Dock and smoother shifting
    • SMS are not logged in CallLog
    • Source more defined (improved viewing in small letters)
    • EFS AutoBackup
    • And so much more you pray do not remember
    Remember, you may wish to install (SD-CARD / CRISKELO-ADDONS/CriskeloRom-MakeLiteRom-InstallCWM-Manager OpeClick) by CWM Manager can make your rom LITE
    nuova base LA6
    tutto perfetto in flash sembra molto carina
  5. #34
    Riserva Navajo
    update con l'ultimo Abyss di Angelo 3.6
  6. #35
    Androidiano VIP L'avatar di Osarco94
    HTC ONE m7 ,HTC Wildfire
    Ringraziato 163 volte in 138 Posts
    Poi fammi sapere come scende la batteria
    In custodia
    HTC Wildfire
    rooted with Cyanogen 9
  7. #36
    Riserva Navajo
    CriskeloRom NOTE V6
    • Touch Menu / settings (functions are grouped as in ICS, grouped by category)
    • Added in adjustment functions (HomeMyHome, CPU-Spy, CPU monitor, CSC Select and Samsung Secret Code)
    • Changes in Framework res.apk and systemUI -small graphics
    • Kernel 3.6 AbyssNote
    • And some other details
    http://www.jota.cl/criskelo/ROMS-NOT...FC96F8147A.zip
  8. #37
    Riserva Navajo
    flash tutto OK
  9. #38
    /a sto provando anche io.... Mi sembra ci sia anche un buon compromesso con la batteria, quella speriamo perché è davvero bella
    In custodia
    HTC Wildfire
  10. #39
    Riserva Navajo
    io mi trovo benissimo
  11. #40
    Installata stamattina e devo dire che va molto bene!
    grazie 1000
    Ultima modifica di tcianca; 06-02-12 alle 15:52
LinkBacks (?)
