Pagina 9 di 12 primaprima ... 7891011 ... ultimoultimo
Visualizzazione dei risultati da 81 a 90 su 111
Knowledgement emmc damage tutte le info del caso
  1. #81
    Quote Originariamente inviato da Andromeda1968 Visualizza il messaggio
    Ciao scusa se disturbo ho downgredato grazie alla tua guida a gb tutto andato per il meglio con un inclemento di velocità generale pazzesco.. Ora unico problema il tel non mi vede gli aggiornamenti ota e non aggiorna il market al playstore come mai?.
    Cè un modo per avere la tastiera di kk5 su altri firmware quando ho comorato il note lo avevo così sensa numeri sopra e mi trovavo meglio
    Ultima modifica di ceppe90; 30-05-12 alle 21:34
    Androidiano L'avatar di KamAMaK
    Ringraziato 20 volte in 17 Posts
    da un utente di XDA
    Easily fix bricked Samsung Galaxy Note N7000
    As you may know, there are many kernels that can damage your Samsung Galaxy Note’s emmc, so your phone will be hard bricked. Unfortunately there are many bad kernels, including official ones and many have bricked their devices, including me. But I found a fix for this and I also have a list of kernels you should stay away from in order to make sure your device is safe from bricking.
    While there isn’t any way of fixing the damaged emmc, you can repartition it and also used the internal SD card to move some system partitions to it in order for the device to work. Doing this is pretty easy, thanks to an XDA Developers user, who created a PIT file that can repartition your device.
    First, here is the list of dangerous kernels: XXLPY, XXLPF, UCLD3, SiyahKernel 3.1rc6, all Samsung Epic 4G Touch (SPH-D710) leaks, all Samsung Galaxy Note (GT-N7000) leaks. If you are running on one of these kernels and your device is still working fine, we recommend you to flash another ROM through Odin right away and do not use ClockworkMod Recovery while on this ROM. Flashing or wiping in recovery can permanently damage your Galaxy Note !
    We can’t guarantee you that this method will work, but it did work for us. Other users also confirmed that they managed to fix their bricked Galaxy Note with this method. Please note that we are not responsible for any damage this method does to your device. You do this on your own risk. How to unbrick Samsung Galaxy Note N7000 First you will have to download the PIT files for both the 16GB and 32GB versions. And make sure to use the appropriate version because otherwise you might do even more damage to your device.
    Then you will need to flash either a stock Gingerbread ROM from sammobile or a rooted KJ1 ROM here. You will also need Odin 1.85, the software used to flash the files on your device. You can download it here.
    You might need to unzip the files you download. Odin requires them to be in .pit and .tar file format and it cannot flash .zip files.
    Shut down your Galaxy Note and boot in download mode ( press volume down + home button + power button simultaneously ). Then press volume up to actually enter the download mode. While doing this the device has to be disconnected from the computer.
    Before you begin flashing the files, make sure that your antivirus and firewall software are open and there isn’t any Kies process open on your computer. You also require the latest Samsung USB drivers, which are included in the latest Kies version, so you should install it if you don’t have it on your computer.
    Now launch Odin, click PIT and open either the 16GB or 32GB pit file. Click PDA and open the downloaded ROM. Now you can connect the device to the computer and press start. It might take a few minutes and you should wait even if it appears to get stuck. Sometimes it can take even 20 minutes.
    Sent from my GT-N7000 using xda premium
    Ma è un pit moodato? Mi sembra che il metodo così come riportato è stato provato senza risultati.
  4. #83
    Apr 2010
    Droidland
    semplicemente un bad trip.... chissa cosa si era fumato il tipo
  5. #84
    Riserva Navajo
    ahah erba buona
  6. #85
    Non era erba.... ma meglio :P
    ahah erba buona
  7. #86
    Riserva Navajo
    Ultime news Samsung:
    stanno lavorando al problema e presto rilasceranno una soluzione.....
    speriamo in fretta
    XDA
    ATTENTION:
    We've contacted Samsung about the problem where performing a mmc erase could hardbrick your phone (i9100, i9100g, n7000, m250) if it's having a faulty emmc chip (MAG4FA, VYL00M, and KYL00M with firmware revision 0x19).
    They're working as hard as possible on a clean solution which will be ready soon.
    Please be patient and try to not flash any leaked kernels or kernels based on sources where MMC_CAP_ERASE is present.
  8. #87
    Androidiano VIP L'avatar di AlienwareAR
    Pavia & Milano
    Honor 8 Pro
    Ringraziato 337 volte in 303 Posts
    speriamo in fretta
    XDA
    ATTENTION:
    Ciao Andromeda!
    Thanks per la new..! Speriamo in bene..!!! Soprattutto sul presto..!
  9. #88
    Androidiano L'avatar di redragon87
    Sep 2010
    Battipaglia (SA)
    Google Nexus 5 Black 32GB
    finalmente!!!
    Studente nerd della magistrale di Ingegneria Informatica @ Unisa
    Gordon Freeman - Amministratore del forum degli studenti di Ingegneria Unisa r0x.
  10. #89
    Senior Droid L'avatar di pelerxws
    Jan 2011
    Samsung Galaxy Note
    Ciao. Volevo chiedere a thay o andromeda 2 chiarimenti :
    1) in parole povere il problema é dovuto al fatto ke una sorta di bios del device non é protetto da ics mentre da ginger si? (e sarebbe stato meglio che non risiedesse su emmc ma su chip separato)
    2) si legge in giro che il problema deriva da un problema hardware; ma dato che su ginger non si verifica xké non si può dire ke deriva da ics e quindi il problema é software?
    Samsung Galaxy Note 3 N9500
    ROM: Stock 5.0.0 BUILD PD3
    Samsung Galaxy Note 10.1 GT-N8000
    ROM: Stock JB 4.1.2 MD1 Rooted
    Operatore: Vodafone
  11. #90
    Apr 2010
    Droidland
    Quote Originariamente inviato da pelerxws Visualizza il messaggio
    Il problema e' di natura hardware ma con un software che non attiva alcune funzioni il problema pasa inosservato.Con ics il problema e' venuto alla ribalta dato che sono state inserite alcune istruzioni che su ginger non erano presenti.Detto cio' la soluzione pura non esiste,bisognerebbe flashare il firmware della emmc e questa e' un operazione non fattibile lato utente.L'unica soluzione resta un kernel che bypassi il problema come quello usato ad oggi su sgs2 e sulle rom aosp per N7000
  12. Il seguente Utente ha ringraziato thay per il post:
    pelerxws (08-06-12)
