[ROM/KERNEL][JB][09/09/2012] AniDroid-N7000 (CM10|Linaro GCC 4.7.1| Kernel 3.0.15)
    Nexus S, Galaxy Note
    [ROM/KERNEL][JB][10/09/2012] AniDroid-JB-N7000 (CM10|Linaro GCC 4.7.1| Kernel 3.0.15)
    Salve a tutti,
    segnalo la nuova versione della AniDroid precedentemente segnalata da Sfattucci per ICS, ma questa volta il nostro Novic ci regala la versione per Jelly Bean!
    Personalmente l'ho provata per ICS e devo dire che ne rimasi molto soddisfatto, sono curioso di vedere stavolta se la stabilità che c'era con la versione precedente sia confermata anche in questa versione.
    Short ROM/Kernel information:
    AniDroid-JB-N7000 is AOSP JellyBean ROM based on the latest CM10 source.
    AniDroid-JB-N7000-Kernel is a kernel for AOSP JellyBean ROMs. It was built with the latest Linaro Toolchain (GCC 4.7.1)
    Provided Features:
    Linux Kernel version 3.0.15 (safe to use, without MMC_CAP_ERASE-related BUG)
    Kernel built with the latest Linaro Toolchain (GCC 4.7.1)
    CWM Recovery v6.0.1.3
    SLQB Memory Allocator instead of default SLUB
    CPU Overclocking (OC) and Underclocling (UC) support from 100 MHz to 1600 MHz with 100 MHz step
    GPU MAX Frequency changed to 250 MHz to save more battery
    GPU Voltages are decreased to save more battery
    NEW CPU Frequence Scaling Governors: PegasusQ, Adaptive, MinMax, SmartAssV2, InteractiveX, ConservativeX, LagFree, LulzactiveV2, Intellidemand, Scary, LionHeart, Wheatley, SavagedZen, BrazilianWax
    CPU Voltage Control - Undervolting/Overvolting (UV/OV, use with NSTools App)
    Automatic Process Group Scheduling
    USB OTG support (please use with special USB Host OTG Cable)
    EXT4, CIFS filesystems support
    init.d support
    2048 Kb ReadAhead
    PegasusQ
    Adaptive
    Conservative
    Userspace
    Powersave
    Ondemand
    Performance
    MinMax
    SmartAssV2
    InteractiveX
    ConservativeX
    LagFree
    LulzactiveV2
    Intellidemand
    Scary
    LionHeart
    Wheatley
    SavagedZen
    BrazilianWax
    IO Schedulers:
    CFQ
    Noop
    Deadline
    Simple IO (SIO)
    VR (Default)
    Installation instructions:
    If you are coming from the previuos version of AniDroid-N7000:
    Download ZIP file with the version of AniDroid-JB-N7000 and put it on Internal/External SD-card
    Download ZIP file with Google Apps and put it on Internal/External SD-card
    Boot into ClockworkMod Recovery
    Choose "Install ZIP from SD-card/External SD-card"
    Choose ZIP file AniDroid-JB-N7000 ROM you've just put on SD-card
    Choose "Yes" to flash the ZIP
    Flash ZIP file with Google Apps in the same way (you must do it after flashing every new version of AniDroid-N7000!!!)
    If you are coming from another ROM:
    If you are on a leaked ICS kernel, please flash a known safe kernel from the sticky in the development section!!!
    Do a Nandroid Backup to make full backup of your currently installed firmware
    Choose "Wipe Data/Factory Reset" and choose "Yes" to do a full wipe
    Choose ZIP file with AniDroid-JB-N7000 ROM you've just put on SD-card
    Changelog:
    AniDroid-JB-N7000 v0.1 - v0.2:
    Initial version
    AniDroid-JB-N7000 v0.2 - v0.3:
    Fixed BUG with CPU Frequency Scaling Governors availability
    AniDroid-JB-N7000 Kernel v0.3 - v0.4:
    CPU Overclocking (OC) and Underclocling (UC) support from 100 MHz to 1600 MHz with 100 MHz step added
    AniDroid-JB-N7000 Kernel v0.4 - v0.5:
    CPU Overvolting and Undervolting FIX
    AniDroid-JB-N7000 Kernel v0.5 - v0.6:
    CPU UnderClock to 100 MHz temporarely removed
    CPU voltage for 1600 MHz increased to improve stability
    Support for Triangle Away enabled
    KSM support enabled (Kernel Samepage Merging) to optimize memory usage
    SIO I/O Scheduler support added
    Download Links:
    Current ROM Binaries:
    AniDroid-JB-N7000-v0.5_10092012.zip
    AniDroid-JB-N7000-v0.5_10092012.md5
    Current Kernel Binaries:
    AniDroid-JB-N7000-Kernel_v0.6_14092012_CWM_Flashable.zip
    AniDroid-JB-N7000-Kernel_v0.6_14092012_CWM_Flashable.md5
    Previous versions:
    Previous versions binaries
    Kernel Source Code:
    AniDroid-JB-N7000-Kernel on GitHub
    Google Apps:
    GApps
    Ultima modifica di Daere; 14-09-12 alle 11:28
  2. Il seguente Utente ha ringraziato Daere per il post:
    Sfattucci (10-09-12)
    Androidiano VIP L'avatar di Sfattucci
    Caserta
    Tab S2 T715, S8 Plus, Gear S
    Ringraziato 6,165 volte in 2,803 Posts
    altra bella rom. per non parlare del kernel
    Delirium n9005 MMport 6.0.1 S7Edge - Note 5 - NewUX full features
    Delirium n9005 Kernel mmport 6.0.1 Linaro 6.0 Experimental + Patch Uber CortexA15
    Delirium Tab S2 T715 mm 6.0.1 ITV
    Delirium Tab S2 T715 Kernel mm 6.0.1 Linaro 6.0 Experimental
  5. #3
    Quote Originariamente inviato da Sfattucci Visualizza il messaggio
    La rom è ottima, tu hai provato il nuovo kernel in firma? Facci sapere come va
    p.s. Ho aggiornato i link col nuovo kernel OC/UV
  6. #4
    Caserta
    Quote Originariamente inviato da Daere Visualizza il messaggio
    Lo sto provando da un paio di ore, ho piallato il note, messo su la mia JB 4.1.1 e l'anidroid JB 0.4 ( 100-1400mhz ondemand/noop ) vediamo al secondo ciclo ... ora sono ancora a smanettare sulla rom, quindi è sotto, ma troppo sotto stress
  7. #5
    E' uscita una nuova versione del kerne a quanto pare è interessante perchè aggiunge un nuovo scheduler, la compatibilità con triangle away e il supporto per il KSM
  8. #6
    Androidiano L'avatar di rouch4
    Nexus S
    Ringraziato 24 volte in 21 Posts
    ragazzi..mi fareste capire un po'?
    ho visto che il kernel è stato compilato con linaro toolchain...questo implica che dovrebbe avere tutte quelle migliorie prestazionali di cui si parla?(dai 30% ai 100%) e poi con l installazione del nuovo kernel ho incompatibilità con app? (si, non ho mai installato un nuovo kernel ) e infine il nuovo kernel si installa come una rom, ossia flashando il file.zip?
