Pagina 8 di 9 primaprima ... 6789 ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 87
[ROM] [OmniROM 4.4.x] [Team Canjica]
  1. #71
    Androidiano VIP L'avatar di tommi77
    C'è il Mare e la Montagna...
    Ringraziato 1,497 volte in 944 Posts
    Quote Originariamente inviato da andrea9671 Visualizza il messaggio
    il debug ho risolto...mentre su impostazioni-->memoria premo il tasto ma non appare nulla
    Ma se hai risolto....sei a posto no?....
    Init.d
    (needs ROM with init.d access and busybox, open empty file, insert header #!/system/bin/sh and put these there, save in /system/etc/init.d and name it something like 77tweaks)
    1. strict minfree handler tweak
    echo "2048,3072,6144,15360,17920,20480" > /sys/module/lowmemorykiller/parameters/minfree
    2. Tweaks internet veloce
    echo "0" > /proc/sys/net/ipv4/tcp_timestamps;
    echo "1" > /proc/sys/net/ipv4/tcp_tw_reuse;
    echo "1" > /proc/sys/net/ipv4/tcp_sack;
    echo "1" > /proc/sys/net/ipv4/tcp_tw_recycle;
    echo "1" > /proc/sys/net/ipv4/tcp_window_scaling;
    echo "5" > /proc/sys/net/ipv4/tcp_keepalive_probes;
    echo "30" > /proc/sys/net/ipv4/tcp_keepalive_intvl;
    echo "30" > /proc/sys/net/ipv4/tcp_fin_timeout;
    echo "404480" > /proc/sys/net/core/wmem_max;
    echo "404480" > /proc/sys/net/core/rmem_max;
    echo "256960" > /proc/sys/net/core/rmem_default;
    echo "256960" > /proc/sys/net/core/wmem_default;
    echo "4096,16384,404480" > /proc/sys/net/ipv4/tcp_wmem;
    echo "4096,87380,404480" > /proc/sys/net/ipv4/tcp_rmem;
    3. Tweaks gestione VM
    echo "4096" > /proc/sys/vm/min_free_kbytes
    echo "0" > /proc/sys/vm/oom_kill_allocating_task;
    echo "0" > /proc/sys/vm/panic_on_oom;
    echo "0" > /proc/sys/vm/laptop_mode;
    echo "0" > /proc/sys/vm/swappiness
    echo "50" > /proc/sys/vm/vfs_cache_pressure
    echo "90" > /proc/sys/vm/dirty_ratio
    echo "70" > /proc/sys/vm/dirty_background_ratio
    4. Tweaks kernel misc
    echo "8" > /proc/sys/vm/page-cluster;
    echo "64000" > /proc/sys/kernel/msgmni;
    echo "64000" > /proc/sys/kernel/msgmax;
    echo "10" > /proc/sys/fs/lease-break-time;
    echo "500,512000,64,2048" > /proc/sys/kernel/sem;
    5. Tweaks batteria
    echo "500" > /proc/sys/vm/dirty_expire_centisecs
    echo "1000" > /proc/sys/vm/dirty_writeback_centisecs
    6. Tweaks EXT4 (aumentano notevolmente gli I/O)
    (needs /system, /cache, /data partitions formatted to EXT4)
    a) Rimuove la pubblicità ( attenzione molti siti e sviluppatori vivono quasi esclusivamente di pubblicità)
    tune2fs -o journal_data_writeback /block/path/to/system
    tune2fs -O ^has_journal /block/path/to/system
    tune2fs -o journal_data_writeback /block/path/to/cache
    tune2fs -O ^has_journal /block/path/to/cache
    tune2fs -o journal_data_writeback /block/path/to/data
    tune2fs -O ^has_journal /block/path/to/data
    b) Le opzioni migliori di montaggio
    busybox mount -o remount,noatime,noauto_da_alloc,nodiratime,barrier =0,nobh /system
    busybox mount -o remount,noatime,noauto_da_alloc,nosuid,nodev,nodir atime,barrier=0,nobh /data
    busybox mount -o remount,noatime,noauto_da_alloc,nosuid,nodev,nodir atime,barrier=0,nobh /cache
    7. Flags blocks as non-rotational and increases cache size
    LOOP=`ls -d /sys/block/loop*`;
    RAM=`ls -d /sys/block/ram*`;
    MMC=`ls -d /sys/block/mmc*`;
    for j in $LOOP $RAM
    do
    echo "0" > $j/queue/rotational;
    echo "2048" > $j/queue/read_ahead_kb;
    done
    8. Tweak velocità microSD
    echo "2048" > /sys/devices/virtual/bdi/179:0/read_ahead_kb;
    9. Deframmenta i file del database
    for i in \
    `find /data -iname "*.db"`
    do \
    sqlite3 $i 'VACUUM;';
    done
    9. Rimuove il logger
    rm /dev/log/main
    10. Tweaks governor Ondemand
    SAMPLING_RATE=$(busybox expr `cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_transition_latency` \* 750 / 1000)
    echo 95 > /sys/devices/system/cpu/cpufreq/ondemand/up_threshold
    echo $SAMPLING_RATE > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/sampling_rate
    11. Modifica automatica di governor e I/O Scheduler
    a) I/O Scheduler ( i migliori: suo - sioplus -
    echo "vr" > /sys/block/mmcblk0/queue/scheduler
    o
    echo "sio" > /sys/block/mmcblk0/queue/scheduler
    b) Governor (i migliori: )
    echo "governor-name-here" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
    12. Auto-zipalign all'avvio
    13. Tweak uniformità Loopy
    14. Disable normalize sleeper
    mount -t debugfs none /sys/kernel/debug
    echo NO_NORMALIZED_SLEEPER > /sys/kernel/debug/sched_features
    16. OOM groupings and priorities tweaks - SuperCharger
    GPS.conf
    (create or edit your /system/etc/gps.conf with a file manager with root access)
    For improving GPS lock time and signal.
    a) European NTP server (replace for america or asia in your case)
    NTP_SERVER=europe.pool.ntp.org
    XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
    XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
    XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
    b) SE supl for A-GPS (better than Nokia's or Google's)
    SUPL_HOST=supl.sonyericsson.com
    SUPL_PORT=7275
    Other tweaks or guidelines
    1. Patch your hosts file for blocking Ads
    (please think before doing this; many developers are supported through this way)
    You can use AdFree application for this or changing manually your hosts file.
    Here are some databases:
    http://www.mvps.org/winhelp2002/hosts.txt
    http://pgl.yoyo.org/adservers/server...stformat=hosts
    2. Use CyanogenMOD's APN list file - it's one of the most complete.
    It's located in /system/etc/apns-conf.xml
    3. Use UOT kitchen for basic theming on your device.
    4. Use Google's dns servers
    Create an empty file, name it resolv.conf and put there these 2 lines:
    nameserver 8.8.8.8
    nameserver 8.8.4.4
    Save to /system/etc/.
    5. Update Superuser and su binary to latest version (3.0 beta)
    6. Disable sync feature in sqlite
    (author: ownhere - needs a source for your device so you can compile the /system/lib/libsqlite.so)
    7. Do not use task killers.
    Alright, I think this is it for now.
    If you have any other tweaks or better values, you can PM me and I'll include them.
    Ultima modifica di tommi77; 21-07-14 alle 17:25
    Quote Originariamente inviato da tommi77 Visualizza il messaggio
    ora si è risolto anche l'altro problema ahahahaha magia ahahhah grazie mille lo stesso
  4. #73
    Molto bene....fai con calma che si risolve tutto.....per qualsiasi cosa siamo qua....
    On my ROMs adventure I've been collecting some tweaks and scripts and seems to me it's now time to share it. While some values in terms of optimization might fluctuate from device to device, I've found these pretty consistent throughout many.
    Build.prop
    (edit your /system/build.prop with a file manager with root access)
    Careful for already existing settings. In this case, just change the values.
    1. Force launcher into memory
    ro.HOME_APP_ADJ=1
    2. Raise JPG quality to 100%
    ro.media.enc.jpeg.quality=100
    3. VM Heapsize; higher the RAM, higher the hp can be
    dalvik.vm.heapsize=48m
    4. Render UI with GPU
    debug.sf.hw=1
    5. Decrease dialing out delay
    ro.telephony.call_ring.delay=0
    6. Helps scrolling responsiveness
    windowsmgr.max_events_per_sec=150
    7. Save battery
    wifi.supplicant_scan_interval=180
    pm.sleep_mode=1
    ro.ril.disable.power.collapse=0
    8. Disable debugging notify icon on statusbar
    persist.adb.notify=0
    9. Increase overall touch responsiveness
    debug.performance.tuning=1
    video.accelerate.hw=1
    10. Raise photo and video recording quality
    ro.media.dec.jpeg.memcap=8000000
    ro.media.enc.hprof.vid.bps=8000000
    11. Signal (3G) tweaks
    ro.ril.hsxpa=2
    ro.ril.gprsclass=10
    ro.ril.hep=1
    ro.ril.enable.dtm=1
    ro.ril.hsdpa.category=10
    ro.ril.enable.a53=1
    ro.ril.enable.3g.prefix=1
    ro.ril.htcmaskw1.bitmask=4294967295
    ro.ril.htcmaskw1=14449
    ro.ril.hsupa.category=5
    12. Net speed tweaks
    net.tcp.buffersize.default=4096,87380,256960,4096, 16384,256960
    net.tcp.buffersize.wifi=4096,87380,256960,4096,163 84,256960
    net.tcp.buffersize.umts=4096,87380,256960,4096,163 84,256960
    net.tcp.buffersize.gprs=4096,87380,256960,4096,163 84,256960
    net.tcp.buffersize.edge=4096,87380,256960,4096,163 84,256960
    13. Disable blackscreen issue after a call
    ro.lge.proximity.delay=25
    mot.proximity.delay=25
    14. Fix some application issues
    ro.kernel.android.checkjni=0
    15. Phone will not wake up from hitting the volume rocker
    ro.config.hwfeature_wakeupkey=0
    16. Force button lights on when screen is on
    ro.mot.buttonlight.timeout=0
    17. Disable boot animation for faster boot
    debug.sf.nobootanimation=1
    18. Miscellaneous flags
    ro.config.hw_menu_unlockscreen=false
    persist.sys.use_dithering=0
    persist.sys.purgeable_assets=1
    dalvik.vm.dexopt-flags=m=y
    ro.mot.eri.losalert.delay=1000
    19. Specifics to some LG devices
    persist.service.pcsync.enable=0
    persist.service.lgospd.enable=0
    user.feature.flex=true
    user.feature.lgdrm=false
    user.feature.lgresource=false
    user.feature.lgpoweroff=false
    user.feature.ls_event=false
    user.feature.ls_normal=false
    user.feature.sui=false
    Ultima modifica di tommi77; 28-07-14 alle 17:54
  5. Il seguente Utente ha ringraziato tommi77 per il post:
    Teo0593 (28-04-14)
  6. #74
    ragazzi io ho un problema..la rom non mi riconosce la sim, o meglio la linea c'è ma non mi fa visualizzare la rubrica della sim e io ho tutti i numeri li, ho controllato la sim su altri telefoni e i numeri ci sono =( in più al momento di installare whatsapp mi compariva la scritta che la rom non supporta tali sistemi di messaggistica e per avviarlo non vi dico quanto ci ho messo perchè non ci credereste XD
    so che non è la sezione giusta ma qualche anima pia mi saprebbe indirizzare alla sezione per il ripristino alle impostazioni native del telefono?
    GRAZIE in anticipo..
  7. #75
    Quote Originariamente inviato da peten Visualizza il messaggio
    Che la ROM non legge i contatti della SIM è cosa risaputa, nel senso che nessuna ROM ( per lo meno le 4.4.x) li leggono, li devi sincronizzare con l'account di google, o farne un backup con app di terze parti.....se vuoi ripristinare il tel come appena uscito di fabbrica ti consiglio questo procedimento https://www.androidiani.com/forum/sh....php?p=5475415
  8. Il seguente Utente ha ringraziato tommi77 per il post:
    peten (01-05-14)
  9. #76
    Yamaha G2
    Non vorrei generalizzare ma anche altre ROM non leggono i contatti salvati sulla SIM.
    Comunque travasali da un altro telefono con il bluetooth e memorizzali sulla memoria telefono sincronizzata a google (così non li perdi più)
    La morizzazione su SIM è un sistema obsoleto e molto limitante Liberatevene !
  10. Il seguente Utente ha ringraziato gianpassa per il post:
    peten (01-05-14)
  11. #77
    Senior Droid L'avatar di theyonut
    Nov 2013
    Nexus 4, Nexus 7
    Ringraziato 192 volte in 145 Posts
    "May the Force be with you"
  12. Il seguente Utente ha ringraziato theyonut per il post:
    tommi77 (29-05-14)
  13. #78
    AGGIORNAMENTO
    NUOVA BUILD
    Come preannunciato da "theyonut" è stata rilasciata una nuova build.
    Non ci sono changelog al momento e nemmeno commenti più o meno positivi, quindi non resta che provarla...
    Download: http://d-h.st/xeN
    Buon proseguimento......
  14. #79
    Nov 2013
    Nexus 4, Nexus 7
    AGGIORNAMENTO
    NUOVA BUILD
    Un cambiamento dovrebbe essere la hotword "Ok, google" personalizzabile, ma si può usare solo con launcher3. Chi come me usa GEL non cambia nulla
    Poi come ho detto pure su XDA a me non funziona il Hotspot WiFi. E nemmeno il tethering USB e Bluetooth
  15. I seguenti 2 Utenti hanno ringraziato theyonut per il post:
    Belegos (30-05-14),tommi77 (29-05-14)
  16. #80
    Samsung Galaxy S Advance
    il link per il download della rom avvia un download che non supera la velocità di 20 KB/s e posso assicurare che la mia connessione al momento funziona bene
