Utente della settimana: megthebest con ben 3 Thanks ricevuti negli ultimi sette giorni
Utente del mese: megthebest con ben 41 Thanks ricevuti nell'ultimo mese
Pagina 10 di 12 primaprima ... 89101112 ultimoultimo
Visualizzazione dei risultati da 91 a 100 su 115
[ICS ROM] CodeNameAndroid | ICS 4.0.3 [Thread Ufficiale by DjSound]
  1. #91
    Androidiano L'avatar di EnricoM
    Ringraziato 27 volte in 19 Posts
    Scusate ma che differenza c'è tra la nuova uscita: 1.5.0, e le nightly???
    Terminale: Samsung Galaxy S i9000
    Android: Jelly Bean 4.2.2
    Rom: SlimBean Build 5
    Kernel: Semaphore JB 2.9.24s
    Clock: 1140mhz
    Governor: SmartassV2 con Smooth_UI
    Scheduler: ROW
    Ricordatevi il THANKS!!
    Androidiano VIP L'avatar di DjSound
    Mar 2011
    Ringraziato 2,715 volte in 1,217 Posts
    Quote Originariamente inviato da EnricoM Visualizza il messaggio
    Pff hai voglia, rispetto all'ultima nightly su cui é basata la Tiramisu oltre 50 bug... ecco te li riporto tutti con anche la risposta di cos'é una nightly:
    With the 1.5.0 release of Codename Android, we bring you support for even more devices and nightly builds. We’ve added the Galaxy S, Fascinate, Vibrant, Captivate, Incredible, Transformer EEE Pad, Transformer Prime, Xoom Euro and 3G to our list of supported devices, bringing the total number to 15. A full changelog is listed below.
    We’ve added Nightlies, what exactly are those?
    A “nightly” is a bleeding edge release that is built on a daily basis, usually at night after a full day’s worth of new code has been committed. Nightlies are often times unstable and not properly tested. However, nightly builds eventually evolve into alphas, betas, and finally stable releases. These releases are not meant for the masses, but are loved and flashed by a very large portion of the Android community.
    1.5.0 Changelog:
    * common: added support for the Galaxy S, Fascinate, Vibrant, Captivate, Incredible, Transformer EEE Pad, Transformer Prime, Xoom Euro and 3G
    * common: notably, even smoother and faster
    * Update to Power Menu Options:
    * Improved torch toggle graphics and strings
    * Made power off on power menu optional
    * Add error message to power menu when all power menu options are disabled
    * Added NavBar Buttons in Power Dialog (Zaphod-Beeblebrox)
    * Improve navbar on power dialog logic:
    * Separated hide navbar option from nav buttons
    * Nav actions on power menu replaces the silent toggle when enabled
    * Improved nav on power menu graphics
    * Added recents button to nav actions
    * Only show nav buttons when the navbar is hidden
    * Disabled nav buttons when the lock screen is showing
    * Added reset of hidden nav bar on reset (not reseting causes issues)
    * Disabled power menu nav buttons the the lock screen is enabled
    * Added the ability to either place the nav actions on the top or bottom of the power menu
    * common: Added SMS Split by encoding and counter at end of message with settings (Mike Wielgosz)
    * common: Added option to display contact pictures in Mms notifications (dragonzkiller)
    * common: Display contact name if available in delivery report mms notifications (kshlm)
    * common: updated the phone and contacts with the latest from CM
    * common: added optional lockscreen before the security lockscreen option (tmoskowite)
    * common: new advanced testing menu in settings (Development settings, Spare Parts settings, and Testing settings)
    * common: use the volumer rocker as a cursor while you type (romanbb)
    * common: added the ability to long hold to uninstall the the launcher (nebkat)
    * common: Allow unlinking of notification sound and ringtone volume (gsarrica, romanbb) slightly modified layout codenamedroid
    * common: custom lockscreen wallpapers (romanbb)
    * common: gave power menu its own category in the interface settings (everything on the power menu is now configurable)
    * common: the ability to enable rotation on the lockscreen (romanbb)
    * common: reverted back to previous rotation settings for full 180 degree rotation
    * common: fixed big brother, little brother menu button issue when all nav buttons are enabled
    * common: the lockscreen settings menu has been updated and reorganized
    * common: added the lights level editor to the automatic backlight settings
    * common: fixed the processor settings crashing with kernels with non-configurable governors
    * common: reworked lockscreen menu unlock (tpruvot – replaces romans, better logic)
    * common: removed romanbb’s version of volume key wake lock and long press volume and updated with the ones from CM
    (longpress to change tracks works with volume wake enabled)
    * common: fix alarm not setting properly with a voice action (romanbb)
    * common: fix for lockscreen unlocking after dismising an alarm (Danesh)
    * common: added support for more tag types to the nfc reader (doug yeager)
    * common: updated the LTE and WiMax toggle
    * Closed out over 50 issues on the bug tracker
    * Galaxy Nexus (GSM/CDMA): Codename Android Kernel 1.7.3 – patched to 3.0.23, updated color code, stock volatges by default, and fast charge mod
    Inviato dal mio GT-I9000 usando Tapatalk
    My Tiramislim Gold users: maxysoft, diegomattia
  4. Il seguente Utente ha ringraziato DjSound per il post:
    EnricoM (06-03-12)
  5. #93
    WOW! Immagino che una nuova tiramisù stia bollendo in pentola...
    Clock: 1140mhz
    Scheduler: ROW
  6. Il seguente Utente ha ringraziato EnricoM per il post:
    DjSound (06-03-12)
  7. #94
    Mar 2011
    Hihihi
  8. #95
    Baby Droid L'avatar di zanflank
    La sto già provando
    Finalmente fixato il problema della SD eterna
  9. #96
    Androidiano L'avatar di apollo11
    Ringraziato 38 volte in 38 Posts
    Provata la 1.5.0 cna:orrore... sono immediatamente tornato alla tiramisu ics, tramite nandroid restore...
  10. Il seguente Utente ha ringraziato apollo11 per il post:
    DjSound (06-03-12)
  11. #97
    Mar 2011
    Quote Originariamente inviato da zanflank Visualizza il messaggio
    La sto già provando
    Beh funzionava anche nella Tiramisu 1.3
    Quote Originariamente inviato da apollo11 Visualizza il messaggio
    Addirittura? Caspita ma hai installato seguendo il tutto alla lettera?
  12. Il seguente Utente ha ringraziato DjSound per il post:
    apollo11 (07-03-12)
  13. #98
    Androidiano VIP L'avatar di verygoodsek
    Piacenza
    Ringraziato 190 volte in 182 Posts
    Questa si che si chiama gratitudine... ahahahah
    Samsung Galaxy SII with [Rom - ICS] ICS STUNNER - The best for Galaxy Note - Thanks huhuhu
    Versione Android 4.0.4
    PER ME E' LA CIPOLLA
  14. Il seguente Utente ha ringraziato verygoodsek per il post:
    DjSound (07-03-12)
  15. #99
    Quote Originariamente inviato da DjSound Visualizza il messaggio
    Ciao, ho fatto wipe data factory, wipe cache, wipe data, data data, dalvik. Insomma tutto tranne wipe boot. E la 1.5.0 mi e' apparsa lenta, molto lenta.
  16. Il seguente Utente ha ringraziato apollo11 per il post:
    DjSound (07-03-12)
  17. #100
    Pure gli stessi cuochi per le altre CNA consigliano di partire da Ginger... Quindi ti consiglio di spendere 5 minuti in più e partire da rom stock
    A me va che è una bellezza (bug-market a parte)...
  18. Il seguente Utente ha ringraziato zanflank per il post:
    apollo11 (07-03-12)
