Pagina 173 di 380 primaprima ... 73123163171172173174175183223273 ... ultimoultimo
Visualizzazione dei risultati da 1,721 a 1,730 su 3794
[ROM][ICS 4.0.4] CyanogenMod 9.1 [Thread Ufficiale by carminelnx]
  1. #1721
    Androidiano VIP L'avatar di carminelnx
    Salerno
    Nexus 4
    Ringraziato 211 volte in 153 Posts
    Quote Originariamente inviato da cico87 Visualizza il messaggio
    Avete visto che changelog per la prossima nightly?
    Posta posta... Il sito risulta sempre down.. Quindi ;-)
    Sent from my GT-I9000 using Tapatalk 2
    Nexus 4 | Rom: Stock 4.4 | Kernel: Stock | Baseband: .97
    Senior Droid L'avatar di thcico
    Nexus 4
    Ringraziato 34 volte in 30 Posts
    Scusate ma sono da tapatalk!:
    Allow theming of framework UI elements. (android_frameworks_base) Power widget: Resize ring_on and ring_vibrate_on drawbles slightly (android_frameworks_base) Settings: Updated icons (android_packages_apps_Settings) Updated Hebrew Translation (android_packages_apps_Contacts) Power widget & tether: Restore ICS drawables, replace/create xhdpi drawables (android_frameworks_base) Prevent Sym key from showing the IME picker (android_frameworks_base) Update reboot and screenshot drawables (android_frameworks_base) Added a setting to do nothing/snooze/dismiss an alarm by flipping the device. (android_packages_apps_DeskClock) Use preferences from default launcher (android_packages_apps_Settings) Fix for wrong selection of sms template (android_packages_apps_Mms) opengl: remove tegra errata duplicates (android_frameworks_base) Add Hungarian predictive dictionary support - settings item (android_packages_inputmethods_LatinIME) Revert Hungarian keyboard to qwertz and add alternative qwerty layout (android_packages_inputmethods_LatinIME) Add Hungarian accents (required for the predictive dictionary to work) (android_packages_inputmethods_LatinIME) MemoryHeapBase: ifdef for gingerbread compatibility (android_frameworks_base) telephony: CDMA: fix ERI display when device is in airplane mode (android_frameworks_base) Additional fixes for button/keyboard backlight auto-brightness. (android_frameworks_base) Modified Torch string references for cleaner UX (android_packages_apps_Torch) PanoramaActivity: null pointer exception (android_packages_apps_Camera) Camera: sanity check for camcorder frame format parameter (android_frameworks_base) Extended quick controls for tablet-like controls on phones (android_packages_apps_Browser) Update korean translation (android_packages_apps_Settings) frameworks/base: surfaceflinger: Enable dither if needed (android_frameworks_base) FontRenderer: do not leak mIndexBufferID (android_frameworks_base) SurfaceTexture: Reset buffer values on disconnect. (android_frameworks_base) Surfaceflinger: Add Src orientation for the layer (android_frameworks_base) Handling EGL_BAD_ALLOC egl error as return from swap (android_frameworks_base) SurfaceFlinger: Return the current transform value when queried (android_frameworks_base) Add lookup in Call logs to lookupNumber (android_packages_apps_Contacts) Settings: Data usage: Linear chart option and 2GB to 100MB vertical axis limit. (android_packages_apps_Settings) use TARGET_RECOVERY_FSTAB location if defined (android_bootable_recovery) Settings - Update Italian Translation thanks to Francesco Margiotta (android_packages_apps_Settings) Fix sent SMS timestamp display (android_packages_apps_Mms) Updated Hebrew Translation (android_packages_apps_Mms)
    Ultima modifica di thcico; 13-05-12 alle 22:15
    Android: 4.4.2 KitKat
    Rom: Rastakat
    Kernel: Franco Kernel
  4. #1723
    Salerno
    Nexus 4
    Bene... direi le più importanti l'aggiunta di temi di default, e una redisegnazione del power widget, oltre ad un'altra marea di cose.... interessante!
  5. #1724
    Barcellona P.G. (ME)
    Samsung Galaxy S
    Effettivamente la prossima sembra molto succosa!
    Inviato dal mio GalaxyS con CyanogenMod9
  6. #1725
    Samsung Galaxy S8
    Ringraziato 112 volte in 99 Posts
    meno male... avevo in programma un update... da quella del 29...
    il tethering funziona dal changelog? non mi pare di vederlo...
  7. #1726
    Androidiano L'avatar di ComiLartista
    ROMA
    NEXUS 5
    quindi il changelog si riferisce a quella di stamattina 2012-05-14 07:01:22 se non ho capito male!!
    Phone: Nexus 5
    Android: 4.4.2
    ROM: stock
    Kernel: franco.Kernel r33-dt2w
    Launcher: Nova
  8. #1727
    Androidiano L'avatar di El GianGio
    Napoli
    SGS 1,2 e 3 :D
    Quote Originariamente inviato da ComiLartista Visualizza il messaggio
    Exactly.
    Inviato dal mio GT-I9000 con Tapatalk 2
  9. #1728
    Salerno
    Nexus 4
    Se hanno risolto il tethering wifi ritorno a cm9.. Altrimenti la mia permanenza con Samsung stock prosegue!
  10. #1729
    Napoli
    SGS 1,2 e 3 :D
    Quote Originariamente inviato da carminelnx Visualizza il messaggio
    Nessun tema alternativo di default, hanno rimesso le icone originali nel power widget e traduzioni in italiano nei menu impostazioni.
  11. #1730
    ROMA
    NEXUS 5
    Quote Originariamente inviato da El GianGio Visualizza il messaggio
    quindi un altro aggiornamento poco utile :P
    Phone: Nexus 5
    Android: 4.4.2
    ROM: stock
    Launcher: Nova
