Pagina 234 di 380 primaprima ... 134184224232233234235236244284334 ... ultimoultimo
Visualizzazione dei risultati da 2,331 a 2,340 su 3794
[ROM][ICS 4.0.4] CyanogenMod 9.1 [Thread Ufficiale by carminelnx]
  1. #2331
    Galaxy S
    Ringraziato 22 volte in 14 Posts
    Quote Originariamente inviato da Mecomeco Visualizza il messaggio
    con l'ultima nightly del 30/05 ho avuto grossi problemi col wifi anche riflashando sopra. Sono tornato a quella del 27/05
    CIAO, anche io il tuo stesso problema.. flashata quella del 29 stavo impazzendo con il wifi ed i vari crash.. tornato al 27/05 credo che non cambiero' per un pezzo.....
    Arrivati a questo punto.. mi pare che le nuove release portino piu rogne che altro....
    Ultima modifica di Blackbeast360; 03-06-12 alle 02:45
    Androidiano L'avatar di CrazybikE
    Manziana (RM)
    Xiaomi Mi5 - Motorola Moto G
    changelog next nightly:
    allow dropbear execution from android apps (login as app uid) (android_external_dropbear)
    Fix an ICS DatagramPacket bug. (android_libcore)
    Revert "libhwui: Correct transform used for drawing text-shadow." (android_frameworks_base)
    Added a summary and enabled description for owner info setting. If there is a good reason why the summary was blank, then my apologies for this commit. I just found the Owner Info setting to look a bit empty without a proper description. (android_packages_apps_Settings)
    SurfaceFlinger: Set the transform value correctly (android_frameworks_base)
    stagefright: Turn off verbose logging in LPAPlayer (android_frameworks_base)
    Remove duplicate notifications (android_frameworks_base)
    String on Toast notification does not aligned to center (android_frameworks_base)
    FileInputStream is not closed in "UserManager.java : readUserList()" (android_frameworks_base)
    Fix wrong include on tablet layouts (android_frameworks_base)
    surfaceflinger: Fix top-bottom UI composition with S3D. (android_frameworks_base)
    libstagefright: Fix MPEG4 timestamp (android_frameworks_base)
    Fix a BadTokenException when user wakeuped device (android_packages_apps_Mms)
    Make the liftcycle of cursor under the Activity (android_packages_apps_Mms)
    Electron Beam Animation (2/2 Settings) (android_packages_apps_Settings)
    Electron Beam Animation (1/2 Frameworks) (android_frameworks_base)
    Enable Dock Battery Percentage (android_frameworks_base)
    Increase the aspect ratio tolerance (android_packages_apps_Camera)
    Turkish: Weather Forecast (android_frameworks_base)
    Added Trebuchet to eclipse projects (android_development)
    Set landscape orientation prop (android_frameworks_base)
    camera: Add parameters for HTC msm8960 (android_frameworks_base)
    aries-common: create /data/log (android_device_samsung_aries-common)
    libstagefright: LPAPlayer: Fix choppy playback on BT. (android_frameworks_base)
    SurfaceTextureClient : Reset buffer size to 0 after setting geometry (android_frameworks_base)
    init: Fix LPM for charging_mode_booting (android_system_core)
    audio/msm8660: slight code clenup (android_hardware_qcom_media)
    LockScreen Weather : Align City/Condition/Time text (android_frameworks_base)
    Lock Screen Weather: units changed to Uppercase (android_frameworks_base)
    Fix issue #18053 (android_packages_apps_Phone)
    audio/msm7x30: Fixes for compiling with LPA support (android_hardware_qcom_media)
    msm8660: Add support for Samsung voice devices (android_hardware_qcom_media)
    Add User Guide to DSPManager (android_packages_apps_DSPManager)
    Slight DSPManager parameter tuning (android_packages_apps_DSPManager)
  4. #2333
    pozzomaggiore (ss)
    p1000- p6200- g s- note-next
    Quote Originariamente inviato da Blackbeast360
    Io nessun problema avete per caso fatto wipe perché sono loro che portano rogne quando si fanno senza motivo .
    Inviato dal mio GT-P1000 usando Androidiani App
    ti ho aiutato?all'angolo a sinistra c'e il thanks cliccalo
  5. #2334
    Quote Originariamente inviato da cipo3282 Visualizza il messaggio
    no ho avuto problemi senza fare i wipe, cmq col semaphore 1.2.2 il wifi funziona perfettamente quindi è un problema del kernel stock della cyano
  6. #2335
    pozzomaggiore (ss)
    Io ho il kernel stock e funziona bene
  7. #2336
    Senior Droid L'avatar di SIRIOS.77
    In una ridente cittadina Veneta di nome Cittadella
    G i7500, G S, G Nexus, G SIII
    Ringraziato 106 volte in 91 Posts
    Ma il problema è che non aggancia e se aggancia poi si sgancio da solo?
    Inviato dal mio GT-P5110 usando Androidiani App
    My today's devices ...
  8. #2337
    Quote Originariamente inviato da punticci
    Originariamente inviato da Stantor91
    Riflashando. però ho il problema del volume!
    Ah ok allora avevo ragione ma il volume è basso o non c'è proprio?
    Il volume del suono al tocco é bassissimo..mentre quello della tastiera per scrivere é inesistente..non so come risolvere..magari é una cavolata..
  9. #2338
    Androidiano L'avatar di steevo
    Samsung Galaxy S
    anche a me a casa il wifi aggancia e sgancia..
    poi basta rimettere la password al wifi e tutto rimane stabile..
    non so.. provate e vedete se anche a voi funziona così!
  10. #2339
    a me dalla nigtly 28 alla 31 succede questo
    se accendo il telefono e attacco il wi-fi, bene , nn mi da nessun problema, poi se lo stacco per passare a 3G, sempre nessun problema
    però se poi voglio riattivarlo, non si riattiva, e se vado nelle impostazioni del wifi a smanettare un po' per cercare di attivarlo, incomincia ad attaccare e staccare ogni secondo, a volte si riavvia da solo, a volte devo riavviare io
    Nessuno sa cosa succede??
  11. #2340
    pozzomaggiore (ss)
    Quote Originariamente inviato da kalikalikali
    Prova a fare wipe cache e dalvik e riflasha
    Inviato dal mio GT-P1000 cyano 9 nightly p1
