Pagina 239 di 696 primaprima ... 139189229237238239240241249289339 ... ultimoultimo
Visualizzazione dei risultati da 2,381 a 2,390 su 6953
[ROM][ICS] TIRAMISLIM Final V. 2.0 [OTA-AROMA-Aroma File Manager-SLIM]
  1. #2381
    Androidiano VIP L'avatar di Pietrone94
    Trento
    Samsung Galaxy S3 ; Galaxy S
    Ringraziato 2,012 volte in 1,502 Posts
    Quote Originariamente inviato da maxysoft Visualizza il messaggio
    ci arriverà tra poco. speriamo entro oggi..
    aaaah avevo capito testato da 3-4 gg
    Quote Originariamente inviato da HalfManHalfBiscuit Visualizza il messaggio
    Ola amigos
    Yup i can help you
    When you take Devil3 kernel stock mb RAM is 378,now you can change to 391 or 403mb RAM
    If you take 403mb RAM only video 720 wont work,rest works much faster.By 391mb RAM everything works perfectly.
    I made this thread on XDA Forum
    Link : xda-developers - View Single Post - [Kernel][ICS] Devil2_0.94 [24/05/12] - i9000 and i9000B
    For 391 mb RAM set number 1,for 403mb RAM set 2 and save it.After that REBOOT phone and there you have it.
    After you do that go to NSTools and set these values that i write you don´t now
    1st TWEAK : Set ACTIVE SCHEDULER to sio
    2nd CPU : SmartassV2,Min CPU freq 100MHZ,Max CPU freq 1200MHZ ---OC value 100%,TARGET LOW 800MHZ,TARGET HIGH 1400MHZ
    Put this settings down below
    awake ideal freq = 800000
    sleep ideql freq = 200000
    sleep wake freq = 800000
    min CPU load = 75%
    max CPU load = 45%
    ramp down step = 100000
    ramp up step = 100000
    down rate = 99000
    up rate = 24000
    3rd go to SETTING
    click on SET ON BOOT
    click Use init.d script
    save the settings
    last reboot phone
    Everytime you charge your phone it will be faster and faster,no lag no Fc,smooth as shit bro
    Tell me if you got it please
    you are pro!!
    when i come back home i will try it
    Sent from my GT-I9000 with Tiramislim...yes the new base is Slim
  2. Il seguente Utente ha ringraziato Pietrone94 per il post:
    HalfManHalfBiscuit (17-06-12)
    In attesa della Final ho riportato il GS al GB 2.3.6. e ho potuto "riscoprire" l'ottima qualità audio/video che non ha con le tue ROM (x DJ). Naturalmente lungi da essere una lamentela, ma è solo curiosità di sapere se anche altri hanno avuto la stessa sensazione. Da pseudo-inesperto chiedo: può essere che i video siano + fluidi con la RAM a 364???? ...aspettando la FINAL!!!!
    grazie a marcoperro74, da oggi anche io mi TIRAMISLIMMMMMMMMMMMMMMMMM
  5. #2383
    Androidiano VIP L'avatar di DjSound
    Mar 2011
    Ringraziato 2,715 volte in 1,217 Posts
    dj dopo aver testato la final mi fermo per qualche giorno per calibrare la batteria dato che mi dura mezza giornata.. posso prendermi 3-4 giorni di ferie?
    Vedremo... ma non sono retribuite però XD
    Ola amigos
    Yup i can help you
    min CPU load = 75%
    max CPU load = 45%
    down rate = 99000
    up rate = 24000
    3rd go to SETTING
    save the settings
    last reboot phone
    Thanks for share with all us
    Quote Originariamente inviato da juary Visualizza il messaggio
    In che senso qualità audio video?
    My Tiramislim Gold users: maxysoft, diegomattia
  6. I seguenti 5 Utenti hanno ringraziato DjSound per il post:
    diegomattia (17-06-12),HalfManHalfBiscuit (17-06-12),marcoperro74 (17-06-12),maxysoft (17-06-12),Pietrone94 (17-06-12)
  7. #2384
    Androidiano L'avatar di HalfManHalfBiscuit
    Croatia
    Samsung Galaxy S I9000
    Ringraziato 145 volte in 65 Posts
    Quote Originariamente inviato da Pietrone94 Visualizza il messaggio
    you are pro!!
    Thank you my dear (Pietrone)
    Seriously now,at first the phone wont lag at all.After every charging your battery will last longer and longer.
    When i set these values my battery lasted only for 1 day,now 3 days with heavy use .
    After 3-4 days you´ll see your phone go crazy fast,you put down the Statusbar,you can´t even see it coming down how fast it is
    DjSound hurry i want to test the BETA today you Tiramisu lover (i LOVE Tirami too )
    P.S. If you all here Italian guys be nice to me,i´ll tell you how to change your colors of screen.The default SGS I9000 screen colors are shit how they can be set amigos ALALALALALALLAAAAAAAAAAAAAA Then you´ll see what SGS i9000 can do all Allalalalaahahaaha
  8. I seguenti 3 Utenti hanno ringraziato HalfManHalfBiscuit per il post:
    DjSound (17-06-12),marcoperro74 (17-06-12),Pietrone94 (17-06-12)
  9. #2385
    In che senso qualità audio video?[/QUOTE]
    ...in effetti non mi sono spiegato bene! dopo aver installato le tue ROM ho riscontrato un calo qualitativo delle riprese fatte con la videocamera del GS, sia in termini di video sia di audio; a volte l'audio si blocca oppure non è sincronizzato e ciò accade usando diverse applicazioni (ho ottenuto i risultati migliori con lg camcorder free). adesso che ho rimesso la gb 2.3.6. gli stessi video risultano qualitativamente migliori...
  10. #2386
    Mar 2011
    ...in effetti non mi sono spiegato bene! dopo aver installato le tue ROM ho riscontrato un calo qualitativo delle riprese fatte con la videocamera del GS, sia in termini di video sia di audio; a volte l'audio si blocca oppure non è sincronizzato e ciò accade usando diverse applicazioni (ho ottenuto i risultati migliori con lg camcorder free). adesso che ho rimesso la gb 2.3.6. gli stessi video risultano qualitativamente migliori...[/QUOTE]
    mmm personalmente non ho notato questa cosa... o non in maniera cosi eclatante insomma... e nemmeno gli altri utenti fino a ora sembrano aver notato questa cosa...
  11. Il seguente Utente ha ringraziato DjSound per il post:
    juary (17-06-12)
  12. #2387
    Androidiano VIP L'avatar di maxysoft
    GS, SII, S III, S5 | Nexus 7
    Ringraziato 1,547 volte in 1,008 Posts
    Quote Originariamente inviato da DjSound Visualizza il messaggio
    io nn l'ho notato forse perchè l'ultima volta che ho registrato un video (oppure visto) e stato l'anno scorso xD comunque e normale che la qualità sia inferiore dato che ics e solamente un "porting" e i driver nn sono ottimizzati come su gb
    REIMPOSTATE IL LIMITE DEI CARATTERI A 1000. 500 SONO TROPPO POCHI!
    Regalami 500mb di spazio su DropBox
  13. Il seguente Utente ha ringraziato maxysoft per il post:
    juary (17-06-12)
  14. #2388
    ... meglio così, ciò servirà per gustarmi meglio l'attesa della FINAL!!
  15. #2389
    Androidiano VIP L'avatar di Tex99
    Ringraziato 1,277 volte in 807 Posts
    volevo chiedere che kernel posso mettere su questa rom che abbia integrato o che supporti il voodoo color ?
  16. #2390
    Quote Originariamente inviato da Tex99 Visualizza il messaggio
    mi pare che l'unico sia devil..
    ecco il link se ti serve:
    http://forum.xda-developers.com/atta...7&d=1339365258
  17. Il seguente Utente ha ringraziato maxysoft per il post:
    Tex99 (18-06-12)
