Pagina 56 di 70 primaprima ... 646545556575866 ... ultimoultimo
Visualizzazione dei risultati da 551 a 560 su 699
[KERNEL] Voodoo
  1. #551
    Senior Droid L'avatar di misterblonde
    Jun 2009
    napoli
    Samsung Galaxy S4 Bianco
    Ringraziato 300 volte in 203 Posts
    ragazzi allora ho questo piccolo problema
    in pratica non riesco a togliere il lagfix
    provato sia a creare un file con estensione tutti i file e sia una cartella entrambi denominati disable lagfix ma nada de nada
    ps.ho provato a riflashare il kernel ma mi ritrovo sempre nella stessa situazione...l'unica soluzione è fare un revirgin?
    codice:
    2011-06-02 20:52:03  model detected: 8GB
    2011-06-02 20:52:03  option: lagfix disabled
    2011-06-02 20:52:03  option: lagfix is allowed to convert /system to Ext4
    2011-06-02 20:52:03  option: debug mode enabled
    2011-06-02 20:52:03  filesystem detection on system:
    2011-06-02 20:52:03      Ext4 on /dev/block/stl9
    2011-06-02 20:52:03  filesystem detection on dbdata:
    2011-06-02 20:52:03      Ext4 on /dev/block/stl10
    2011-06-02 20:52:03  filesystem detection on cache:
    2011-06-02 20:52:03      Ext4 on /dev/block/stl11
    2011-06-02 20:52:03  filesystem detection on data:
    2011-06-02 20:52:03      Ext4 on /dev/block/mmcblk0p2
    2011-06-02 20:52:03  battery level: %
    2011-06-02 20:52:03  convert cache (/dev/block/stl11) from ext4 to rfs
    2011-06-02 20:52:03      ERROR: unable to call fat.format: cancel conversion
    2011-06-02 20:52:03  convert dbdata (/dev/block/stl10) from ext4 to rfs
    2011-06-02 20:52:03  convert data (/dev/block/mmcblk0p2) from ext4 to rfs
    2011-06-02 20:52:03  convert system (/dev/block/stl9) from ext4 to rfs
    2011-06-02 20:52:06  manage fat.format in /sbin
    2011-06-02 20:52:06  fat.format wrapper installed in /sbin
    2011-06-02 20:52:06  fat.format renamed to fat.format.real & symlink created to fat.format_wrapper.sh
    2011-06-02 20:52:06  running extension: apk_cleaner.sh
    2011-06-02 20:52:06  running extension: install_su.sh
    2011-06-02 20:52:06  secure su binary for Superuser apk cannot be installed
    2011-06-02 20:52:06  running extension: sdcard_cleaner.sh
    2011-06-02 20:52:06  sdcard cleaned up
    2011-06-02 20:52:06  running init !
    questo è il code che mi esce non appena creo la cartella e riavvio
    mi dice che il lagfix è disattivo sto andando in crisi
    Ultima modifica di misterblonde; 02-06-11 alle 23:56
    HTC DREAM---HTC HERO---SAMSUNG GALAXY S---GALAXY NEXUS BIANCO!
    Se ti sono stato utile ringraziami attraverso l'apposito tasto
    <------------- qui
    Androidiano L'avatar di leogalaxys
    s8+
    allora ragazzi volevo fare davvero i miei piu grandi complimenti al progetto voodoo per tutto l'impegno che mettono e per quello che fino ad oggi hanno dato alla comunity di android voodoo control plus rulez
  4. #553
    Ringraziato 71 volte in 65 Posts
    non ho capito se il color pack è gia uscito.qualcuno me lo può confermare ?
    ho la versione 5.5.3 (l'ultima) ma i colori mi sembrano sempre gli stessi.
  5. #554
    Senior Droid L'avatar di Peppegs
    Sep 2010
    Ringraziato 86 volte in 53 Posts
    Quote Originariamente inviato da misterblonde Visualizza il messaggio
    Allora prova a scaricare l'app voodoo dal market e vedi che t dice... Cosi provi a disabilitarlo tramite l'app (che cmq fà quello che hai fatto tu a mano)
    A quanto leggo ti da una serie di errori.. Per capire se è attivo o meno vai in recovery e nei sottomenu t appare se disabled o enabled.
    se sei su froyo è strano perche a nessuno ho letto di sti problemi.. Se ti trovi su Ginger.. Nn saprei.
    Ad ogni modo se nn riesci... Si ti serve riflashare revirgin
    sent by tapatalk GT-i9000
    Ultima modifica di Peppegs; 03-06-11 alle 09:54
    CIAO
  6. Il seguente Utente ha ringraziato Peppegs per il post:
    misterblonde (03-06-11)
  7. #555
    Jun 2009
    napoli
    allora il problema è proprio questo
    in pratica in recovery e nella voodoo control app il lag fix mi risulta attivo
    sono in gingerbread
    nel log sta scritto che il lagfix è disattivo ma in realtà le mie partizioni sono in ext4
    quando provo ad attivarlo o disattivarlo non fa nulla e non riesco a stabilizzarlo
    l'importante è che spiattellando (revirgin) il mio galaxy riesco a risolvere e ne volevo una conferma
    <------------- qui
  8. #556
    Sep 2010
    a
    Attenzione.. Nel log NON sta scritto che é disattivo.. T dice xt4 on.. E t da un errore nella conversione.. Per questo nn la fa... E rimane attivo.
    Si fai il revirgin e ristabilizzi tutto.
    CIAO
  9. #557
    Nov 2010
    Ringraziato 17 volte in 6 Posts
    Si sa nulla della versione stable per gingerbread?
  10. #558
    Sep 2010
    Quote Originariamente inviato da dorovan Visualizza il messaggio
    Ancora nulla.. ma quelli che usano la versione "prova" si trovano molto bene e non riscontrano nessun bug.
    CIAO
  11. #559
    Androidiano L'avatar di DeusEx
    Mar 2011
    ROMA
    Samsung Galaxy S4 Mini LTE
    Ringraziato 44 volte in 42 Posts
    Quote Originariamente inviato da Peppegs Visualizza il messaggio
    Confermo in pieno questo kernel è ottimo, mi ci sto trovando benissimo!
    Galaxy A5 2016 (SM-A510F): Firmware A510FXXU3BQA3 (6.0.1) | TWRP 3.0.2-1 | SuperSU 2.79 | Xposed By Wanam v87.1 SDK23[/SIZE][/FONT]
  12. #560
    Androidiano L'avatar di lucedixul
    Oct 2010
    intendi una versione stable per JVO?? se è così dove la trovo?? in prima pagina funziona solo quella JVH, quella JVO non mi scarica nulla..
    Samsung Galaxy S GT-I9000
    GINGERBREAD 2.3.6
    GT-I9000XXJVU
    SEMAPHORE2.5.0bm
