Pagina 66 di 97 primaprima ... 1656646566676876 ... ultimoultimo
Visualizzazione dei risultati da 651 a 660 su 965
[ROM] DarkyROM v.9.0 ITALIAN - It's just pure awesome!
  1. #651
    Androidiano VIP L'avatar di Kikko2000
    Ringraziato 793 volte in 485 Posts
    Quote Originariamente inviato da SirJack Visualizza il messaggio
    Dunque, riepilogando, il Galaxy S è bloccato e tocca reinstallare un firmware pulito originale... possibilmente senza perdere la Recovery CWM.
    La pagina di SamFirmware.com è questa per il Galaxy S.
    Come procedere senza perdere la Recovery CWM?
    E' uscita la Darky 9.2, di cui esistono due edizioni:
    Per la Resurrection leggo:
    This Odin package is aimed at users that are on stock or other ROMs and want to switch painlessly to Darky, or have some current problems with their installation (boot loops, apps misbehaving, Market disappearing, and other file system related issues).
    Che sembra proprio fare il caso tuo.
    LA 9.2 contiene già il CSC italiano.
    * Introducing Darky's Resurrection Edition [Odin flashable package // secure base]
    * Supporting all SGS devices now [use the new Darky App options]
    * Fixed WiFi Connection [stable now]
    * Fixed WiFi Notification pop-up [remember that it only scans all 2 minutes]
    * Fixed Samsung Apps [XEU CSC now]
    * Fixed Market [Paid Apps]
    * Reduced the WiFi Scan Interval [now 2 Minutes]
    * Adjusted ROM Tweaks [build.prop]
    * Changed Settings to Green // by Darkyy [use the new Darky App options for the old style]
    * Added Ad-Hoc Driver [optional - use the new Darky App options]
    * Added Eclair Modem (I9000 only) [optional - use the new Darky App options]
    * Added /system/bin/bash [more flexibility & options]
    * Added Italian CSC [ITV]
    * Added Missing Samsung Apps [Social Hub + Feeds & Updates]
    * Updated Voodoo App [v4.1]
    * Updated our Scripts
    * [I9000] Updated Voodoo Kernel to v5.4.1
    * [I9000] Updated SpeedMod Kernel to K12T 500MHz
    * [I897] Updated Kernel to SpeedMod K12T 500MHz
    Kernel & Modem Info
    I9000
    kernel: Voodoo5.4.1 / SpeedMod K12T 500MHz
    modem: JPY / JM4
    I897
    kernel: SpeedMod K12T 500MHz
    modem: JL3
    Ultima modifica di Kikko2000; 04-02-11 alle 09:47
    Se ti ho aiutato schiaccia Thanks.
  2. Il seguente Utente ha ringraziato Kikko2000 per il post:
    SirJack (04-02-11)
    Jan 2011
    Samsung galaxy s3
    Quote Originariamente inviato da Kikko2000 Visualizza il messaggio
    Che differenza ci tra le due versioni?
  5. #653
    Quote Originariamente inviato da fabiettomi Visualizza il messaggio
    La Resurrection serve per resuscitare terminali con problemi.
  6. #654
    Nov 2009
    Ringraziato 65 volte in 39 Posts
    Ho aggiornato il primo post con i link.
  7. #655
    Nov 2009
    Che differenze ci sono tra la 9.1 e la 9.2?
    Puoi leggere il changelog prima dei link.
    Come già detto in precedenza stiamo lavorando solo sui driver wifi per ottimizzare il risparmio della batteria.
  8. #656
    Quote Originariamente inviato da darkm20 Visualizza il messaggio
    Darkm non riesco a trovare il configurator aggiornato sul markket, hai mica un link diretto da cui installarlo? Onestamente preferisco aspettare il nuovo configurator così mi scelgo tutte le opzioni.
  9. #657
    Nov 2009
    Lo so...lo sto completando Lo rilascerò in mattinata.
  10. #658
    Me lo mandi con posta prioritaria o in contrassegno?
    Edit: Apparte gli scherzi, meglio il modem Eclair rispetto all'ultimo? Tu quale metti?
    Ultima modifica di Kikko2000; 04-02-11 alle 12:30
  11. #659
    Nov 2009
    Apparte gli scherzi, meglio il modem della 8 rispetto all'ultimo. Tu quale metti?
    Perchè dici che è meglio il modem della 8 ?
  12. #660
    No, scusa, era una domanda.
    Leggendo nel changelog:
    volevo chiederti quale è meglio o perlomeno quale sceglierai tu.
