Utente della settimana: elmegio con ben 7 Thanks ricevuti negli ultimi sette giorni
Utente del mese: megthebest con ben 17 Thanks ricevuti nell'ultimo mese
Pagina 1 di 10 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 99
[ROM]Darky's v9.4 Extreme Edition Stable
    Androidiano VIP L'avatar di Kikko2000
    Ringraziato 793 volte in 485 Posts
    Download
    Multiupload.com - upload your files to multiple file hosting sites!
    Changelog
    Based on latest XWJS8
    Faster UI, smoother experience.
    Introducing Dark Voodoo Kernel
    - Made by ficeto [Team Darky Dev]
    - Based on Voodoo 5.5 [by supercurio]
    - Voodoo Sound 5.5
    - Usual Tweaks and Hacks like BLN etc.
    - Rewritten Recovery [mount scripts, other more reliable scripts, new graphics, new UI]
    - Reported very good battery life [3.5 days with heavy use]
    - Speed of Voodoo, means: blazing speed
    Included my RAM Hack Script [more free RAM and less lags]
    Dozens of my new build.prop scripts [faster, more stable, better]
    Reworked zipalign binary and scripts [faster startup, apps use less RAM // thanks Bo$s]
    Cleanued up /system [sysctl etc.]
    4 completely new Ringtones / Alarm Sounds and 1 new SMS sound [I spent more hours on those than on the ROM]
    Speed Improvements for internal & external SD-Card // up to 1.5x speed [faster mediascanner etc. // thanks ickyboo]
    Fixed Bluetooth A2DP Connectivity [thanks ickyboo and spoidar@xda]
    New Bootanimation by Goldieking [best he has done so far! you'll be impressed...]
    New HQ 960 x 800 Wallpapers I've custom collected
    Disabled increasing ringtone [like it was in v9.2]
    Changed call connect / disconnect sounds [Samsung default now]
    Updated update-script
    Implemented FuguTweaks for more speed [Gingerbread 2.3.3 smoothness]
    *ATTENZIONE* Pare ci siano problemi ad installare le applicazioni sulla SD (quindi il restore delle app che giravano sulla SD fallisce)
    Ultima modifica di Kikko2000; 21-03-11 alle 16:06
    Se ti ho aiutato schiaccia Thanks.
  2. I seguenti 5 Utenti hanno ringraziato Kikko2000 per il post:
    briorbrio (21-03-11),gattten (05-04-11),reclo (21-03-11),Squalex (21-03-11),stefanom82 (21-03-11)
    Androidiano L'avatar di EddardStark
    Jan 2010
    Bari
    grazie per la segnalazione, subito in download
    ..cavolo ho fatto un bel wipe + restore giusto ieri, a saperlo avrei aspettato
    Winter Is Coming...
  5. #3
    Nov 2010
    qualcuno può dire la sua su questa rom? pareri, opinioni..screen??
  6. #4
    Senior Droid L'avatar di wilcomir
    Oct 2010
    Pisa
    Galaxy S, Nexus 7
    Ringraziato 110 volte in 102 Posts
    ma è la versione italiana?
  7. #5
    Quote Originariamente inviato da wilcomir Visualizza il messaggio
    Tutte le Darky sono anche in italiano.
  8. Il seguente Utente ha ringraziato Kikko2000 per il post:
    wilcomir (21-03-11)
  9. #6
    Oct 2010
    Pisa
    Galaxy S, Nexus 7
    vado con il flash...
  10. #7
    Per chi volesse flashare pur avendo delle app spostate su SD può provare a spostarle di nuovo nella memoria interna (con Titanium ad esempio), fare il backup e poi flashare.
  11. #8
    Androidiano L'avatar di daniele89
    Ringraziato 31 volte in 22 Posts
    ho fatto un bel backup per sicurezza, ho installato prima la 9.4 e poi il kernel voodoo 5.5.1 e poi riavvio:
    mi parte la vocina metallica che non so che voleva comunque tutto ok
    poi inizia a caricare, fa l'animazione e mi rimane sulla scritta Darky's rom lampeggiante per quasi un'ora, a un certo punto mi arriva una telefonata e mi squilla!!!
    allora capisco che c'era qulcosa di strano (infatti premendo il tasto di blocco mi si blocca come se fosse acceso!) quindi lo spengo e riaccendo...
    pare che tutto vada bene, se non fosse che dopo un po' mi ritrovo un FC delle impostazioni... spero che sia l'unico...
    nonostante ciò non sembra andare male anzi... (ogni tanto mi scatta forse però a causa di quello che è successo prima)
    comunque vada alla prossima rom importante e STABILE, ovvero una tra:
    Darky's 10
    Cyanogenmod 7
    MIUI
    un bel revirgin fatto per benino ci sta...
  12. #9
    Senior Droid L'avatar di confa88
    Jul 2010
    Ringraziato 37 volte in 24 Posts
    raga come faccio a salvare le app? con titanium? e devo fare qualcosa prima o basta flasharla sulla 9.3?
  13. #10
    Quote Originariamente inviato da daniele89 Visualizza il messaggio
    Una delle feature è il Dark Voodoo Kernel, perchè c'hai messo sopra il Voodoo?
    Credo che la voce metallica sia quella che abilita il lagfix (ti converte il filesystem in ext3), lo avevi disabilitato prima?
    Ultima modifica di Kikko2000; 21-03-11 alle 18:19
