Utente della settimana: bluemask con ben 11 Thanks ricevuti negli ultimi sette giorni
Pagina 1 di 35 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 342
[ROM]Darky's v9.5 Extreme Edition
    Androidiano VIP L'avatar di Kikko2000
    Ringraziato 793 volte in 485 Posts
    Download
    Multiupload.com - upload your files to multiple file hosting sites!
    Changelog
    New Kernel >> Dark Core v1.0 inside! I9000, I9000M, I9000T ONLY (Cappy users choose speedmod or skip kernel)
    Customized and built by ficeto [Team Darky Dev Crew]
    http://www.darkyrom.com/apk/Dark_Core_1.0.tar < Odin
    http://www.darkyrom.com/apk/Dark_Core_1.0.zip < CWM
    Based on supercurio’s latest voodoo sound 6, lagfix and color - thanks a ton, Mr. Supercurio
    Leaner and faster build (a lot smaller too)
    Includes fully working Nandroid Backup and Restore
    Includes BLN support
    Includes Zip and Zipalign
    RAM is set to default 304MB (which is just fine)
    Custom CWM Recovery (mount scripts, logs and battery backup always on)
    Improved battery life
    ROM Features
    Fixed Bluetooth Connection Issues
    Fixed Market Error -18 [Apps not installing]
    Fixed non-installing apps outside from Market [TitaniumBackup etc.]
    Fixed RAM Hack [RAM Booster] permissions & converted from MSDOS to UNIX
    Fixed ascending ringtone
    Fixed phone freezing and Force Close when finishing a call with record ON
    Fixed Issue with earpiece not working during calls.
    Fixed tiny dots in TouchWiz Launcher
    Rewritten update-script
    Rewritten installation and tweak scripts
    Changed ringtone & sms sound to something more neutral, but still awesome
    Changed Modem from JQ1 to JVE (much better - Gingerbread Modem)
    >> Just select JQ1 in the DarkyROM Configurator and it will flash JVE.
    Se ti ho aiutato schiaccia Thanks.
  2. I seguenti 12 Utenti hanno ringraziato Kikko2000 per il post:
    auron86 (26-03-11),bakx79 (26-03-11),daniele89 (26-03-11),Irvineon (01-04-11),Mando (26-03-11),Max92 (26-03-11),Mikypan81 (05-04-11),reclo (30-04-11),salvatore73 (28-03-11),Squalex (28-03-11),turefrenchorn (26-03-11),uniblack (26-03-11)
    Senior Droid L'avatar di auron86
    Napoli
    i9300
    sto scaricando =)
    *EDIT* ma anche a voi con la darky se lanciate il "browser di default " e premete sempre back invece di killare il processo rimane aperto in background e consuma "memoria/dati 3g/batteria" inutilmente ?
    Ultima modifica di auron86; 26-03-11 alle 09:42
    Alessio Piromallo
    Web design e Programmatore Java, C++ e PHP
  5. #3
    Senior Droid L'avatar di Max92
    Jan 2011
    Ringraziato 92 volte in 90 Posts
    Quote Originariamente inviato da auron86
    sto scaricando =)
    Lo fa anche con la rom che monto io.
    GT-I9000 - Androidiani App
    Note 3 N9005 MIUI Wonitor
  6. #4
    Baby Droid L'avatar di XxBrigantexX
    Feb 2011
    Ringraziato 10 volte in 6 Posts
    Sfornano peggio dei panettieri!!!
    Bene bene ...
    Attendo prime impressioni da chi sta scaricando
    Samsung Galaxy S3 LTE GT I9305 VODAFONE
  7. #5
    Androidiano L'avatar di daniele89
    Ringraziato 31 volte in 22 Posts
    sono in download più tardi la installo... qualcuno che la installa con il loro kernel mi può dire come va?
    io ormai mi trovo troppo bene con voodoo e non mi va di cambiare inutilmente...
  8. #6
    Jan 2011
    Scusate, proprio ieri ho messo la Serendipity facendo un bel ReVirgin ..... ora é pulita pulita .....
    Volendo provare la Darky 9.5 secondo voi devo rifare il revirgin da capo ? Per fare una installazione pulita ? Oppure faccio un wipe e carico la darky con CWM ?
    grazzzie
  9. #7
    Jan 2011
    Quote Originariamente inviato da mrforty72
    grazzzie
    Io lo faccio sempre per avere un installazione priva di qualsiasi problema.
  10. #8
    AlexForTomorrow
    un altra? in meno di una settimana? machecccazz.....
    bah io l'errore di flashare di nuovo per curiosità non lo faccio più.
    per ora mi tengo la serendipity e basta.
    l'unica cosa è il kernel, che potrebbe essere interessante.
    per il resto, l'ennesima rom di darky
    come ha detto ChanceM (creatore della serendipity): tutti si concentrano a fare una rom su js6, js7 js8, fino alla js64. Io faccio "one hell of a js7"
    darò un occhiata comunque, per vederne i progressi
  11. #9
    Jan 2011
    Quote Originariamente inviato da AlexForTomorrow
    Ti faccio sapere come si comporta in confronto alla serendipity, alle 12 flasho.
  12. #10
    Allora ho appena flashato sulla 9.4 che mi dava qualche piccolo problemino, però devo dire che questa già mi soddisfa, la vedo più fluida e stabile, adesso non posso fare una super recensione ma così a primo impatto vi consiglio di flashare :-)
    Sent from my Galaxy S
