Pagina 398 di 614 primaprima ... 298348388396397398399400408448498 ... ultimoultimo
Visualizzazione dei risultati da 3,971 a 3,980 su 6140
[MOD][12][GHWC2][G973/75F] ☼ CarHDMod V.10.0 ☼ [14/04/23]
  1. #3971
    lissone(MI)
    HD Rom by Carotix
    Twrp official 3.4.0.2
    S10+
    https://eu.dl.twrp.me/beyond2lte/twr...d2lte.img.html
    S10-plus Cardhdrom
  2. I seguenti 4 Utenti hanno ringraziato yuri76 per il post:
    carotix (20-11-20),hobin (20-11-20),Q.dino (20-11-20),usitaly (21-11-20)
    Androidiano VIP L'avatar di Q.dino
    Terracina (LT)
    omnia hd.s2.s4.S6 edge s10+
    Ringraziato 1,314 volte in 1,006 Posts
    Cruel V3.9 rc1
    CruelKernel v3.9-rc1 (testing release)
    Models: G970F/N, G973F/N, G975F/N G977B/N, N970F, N975F, N971N, N976B/N
    OS Patch Date: 2020-11 (install script will change it if required during installation)
    Build config: magisk, nohardening, force_dex_wqhd, ttl, cifs, ntfs, sdfat, nodebug, noaudit, noksm, nomodules, wireguard, usb_serial, sched_powersave, sched_performance, morosound, boeffla_wl_blocker, fake_config
    ChangeLog:
    - G977N, G973N models added
    - G970F/G975F/G973F updated to DTJA
    - N976B/N970F/N975F updated to DTJ4
    - Magisk v21.1 version
    - vendor lock for dp cable for DEX removed (thanks, fart1-git)
    - zip installer implemented
    - automating os_patch_level level patching in installer (https://github.com/CruelKernel/clone_header)
    New configs in sources:
    - "reiser4" added for Reiser4 filesystem
    reiser4progs (https://github.com/CruelKernel/reiser4progs/releases)
    - "empty_vbmeta" added to include vbmeta in installer zip
    - "force_dex_wqhd" - always use WQHD resolution for DEX (disable vendor check)
    - "dtb" - build dtb and include them in zip installer
    New cruelbuild commands:
    - ./cruelbuild pack ... - to create zip installer
    - mkimg is now default command for cruelbuild
    - if there is no model=<MODEL> parameter, the script will try to detect model from connected by usb phone
    - Multiple models: ./cruelbuild model="G973F,G975F,G970F"
    - All models: ./cruelbuild model="all"
    - NODEFAULTS=y ./cruelbuild +samsung ... - disable all defaults
    - ./cruelbuild flash ... - removed
    - FLASH=y ./cruelbuild ... - to flash img file during build
    - FLASH_ZIP=y ./cruelbuild pack ... - to flash zip file during build
    Github Actions changes:
    - will create installer by default
    - change "INSTALLER: yes" to "INSTALLER: no" if you need raw images
    http://www.mediafire.com/file/782ugx...9-rc1.zip/file
    Inviato dal mio SM-G975F
    S 10 + G975 F
    S 23 ULTRA
  5. I seguenti 5 Utenti hanno ringraziato Q.dino per il post:
    carotix (21-11-20),DreamReaper (21-11-20),hobin (23-11-20),usitaly (21-11-20),yuri76 (21-11-20)
  6. #3973
    Androidiano VIP L'avatar di usitaly
    Sep 2013
    Avellino
    S22Ultr;N20Ultr,S20+,S10+,N9
    Ringraziato 930 volte in 704 Posts
    Quote Originariamente inviato da Q.dino Visualizza il messaggio
    Cruel V3.9 rc1
    ChangeLog:
    CruelKernel-v3.9-rc1
    kernel installato... funge... non mi sembrano ci siano problemi .. vediamo come saranno i consumi della batteria... vi aggiorno.
    edit:
    ...sto avendo problemi con l'app Always ON... non mi permette di spegnere lo schermo... si riaccende sempre.
    Ultima modifica di usitaly; 24-11-20 alle 01:00
  7. I seguenti 3 Utenti hanno ringraziato usitaly per il post:
    carotix (23-11-20),DreamReaper (21-11-20),hobin (23-11-20)
  8. #3974
    Terracina (LT)
    TWRP 3.4.0.4
    Changelog
    v3.4.0-4_ianmacd for G97[035]F [inc. DTJA kernel] (2020-11-17)
    Rebase kernel on Samsung's DTJA source code.
    Merge all outstanding fixes and enhancements from the TWRP source tree.
    This version is intended for use only with Android 10.
    https://www.mediafire.com/download/8x8p42su6gfj162
    S 10 + G975 F
    S 23 ULTRA
  9. I seguenti 4 Utenti hanno ringraziato Q.dino per il post:
    carotix (23-11-20),hobin (23-11-20),usitaly (24-11-20),yuri76 (23-11-20)
  10. #3975
    Sep 2013
    Avellino
    OT: vi do una dritta...
    per flashare up_param.bin modificato, cioè senza i vari warning.... è sufficiente sostituire il file up_param.bin.lz4 con il file up_param.bin, ovviamente, opportunamente modificato... nel file BL e flashare questultimo, anche nella rom stock con odin.
    Ultima modifica di usitaly; 24-11-20 alle 22:13
  11. I seguenti 2 Utenti hanno ringraziato usitaly per il post:
    Q.dino (25-11-20),yuri76 (25-11-20)
  12. #3976
    Terracina (LT)
    Quote Originariamente inviato da usitaly Visualizza il messaggio
    Passa lo zip gia modificato
    Inviato dal mio SM-G988B utilizzando Tapatalk
    S 10 + G975 F
    S 23 ULTRA
  13. #3977
    Russi - RA
    Ringraziato 12,228 volte in 4,787 Posts
    ciao Umberto , scusa ma c'è già l'opzione nella Mod .... devi solo spuntarla in aroma
  14. #3978
    Sep 2013
    Avellino
    ma certo, caro Franco che so dell'opzione nelle tue mods... infatti, ho postato in OT perché se non hai una TWRP che ti permette di flashare i files .zip e mi riferisco ad altri devices, tipo i Note20 5g, anche con rom stock potrai, come da me suggerito, eliminare tutti i warning che ricevi dopo il root dei devices di cui non possiedi il TWRP....
  15. Il seguente Utente ha ringraziato usitaly per il post:
    carotix (26-11-20)
  16. #3979
    Sep 2013
    Avellino
    Q.dino, come ha precisato Franco, esiste la modifica già nella sue mods... se invece la tua richiesta è riferita ad altri terminali diversi dal S10+ ...dimmi per quale terminale ti serve.
  17. #3980
    Terracina (LT)
    Me so autoquotato
    Ultima modifica di Q.dino; 26-11-20 alle 06:22
    S 10 + G975 F
    S 23 ULTRA
