Io i pornazzi in flash li vedo benissimo con il browser stock della cm9.
Qualcuno sarebbe cosi Gentile da dirmi come cambiare lo sfondo del blocca schermo?ê tt la sera ke lo cerco ma no km trovo...help help help:-)
Ok grazie :-)
Ma in teoria cambia ,se cambio km sfondo?
Aiuto ragazzi il wifi non va più!
L'icona rimane sempre grigia e non diventa blu e internet non va.
Ho il kernel stock e ultima NIGHTLY.
Ho già fatto wipe cache e dalvik
Buondì, in firma la versione aggiornata della Radio FM
cari pargoli questo è il corposo changelog della prossima nightly:
Bugfix: reboot needed for dock audio checkbox 2/2 (android_packages_apps_Settings)
Bugfix: reboot needed for dock audio checkbox 1/2 (android_frameworks_base)
Settings : NavigationBar Customization (android_packages_apps_Settings)
NavigationBar : Customization (android_frameworks_base)
correct phone number format for non contact number (android_packages_apps_Contacts)
Camera: fix Thai app name (android_packages_apps_Camera)
Vibrator/airplane overrides (2/2 Settings) (android_packages_apps_Settings)
InputManager: Add system setting to define keyboard locales (android_frameworks_base)
Load a device specific key handler (android_frameworks_base)
Vibrator/airplane overrides (1/2 Frameworks) (android_frameworks_base)
hardware/libhardware: Send correct channel count on input (android_hardware_libhardware)
Add an option to disable the transformation from SMS to MMS when the lenght of the message is > 3 sms. (android_packages_apps_Mms)
wifi.c: allow devices to specify driver delay if needed (android_hardware_libhardware_legacy)
Settings missing hungarian traslation (Corrected) (android_packages_apps_Settings)
Updated Torch icons for ICS and xhdpi (android_packages_apps_Torch)
LatinIME missing hungarian traslation (android_packages_inputmethods_LatinIME)
french: accelerometer flip action (android_packages_apps_DeskClock)
LatinIME: Add Czech QWERTY, enable predictive dictionary (android_packages_inputmethods_LatinIME)
Updated Torch widget (android_packages_apps_Torch)
audio/msm7630: Add support for STRATEGY_ENFORCED_AUDIBLE (android_hardware_qcom_media)
audio/msm7627a: Add support for STRATEGY_ENFORCED_AUDIBLE (android_hardware_qcom_media)
libstagefright: Remove assert failure for kKeyHfr (android_frameworks_base)
Camera: Restart preview if video resolution changes in application (android_packages_apps_Camera)
camera: Add debug logging when setting parameters (android_packages_apps_Camera)
RIL: Qualcomm: Unbreak LTE (android_frameworks_base)
frameworks: Fix audio routing when plugged to docks (android_frameworks_base)
Urca... Uscirà oggi... Ma devo attendere perché sto testando la batteria. Sarà difficile.
Ragazzi ho notato che con la build del 1705 se non si imposta l'opzione 'data e ora automatiche', l'orologio di sistema rimane disallineato.
Questa notte ho messo in carica il celle alle 01.30 e questa mattina facendo caso all'ora segnava le 01.45 (erano le 07.15 circa)
Succede anche a voi?
Sent from my Cyanogened SGS2
Edit: ovviamente con le build precedenti di maggio non lo faceva (io flasho quasi ogni giorno se il changelog é interessante)
