Pagina 50 di 164 primaprima ... 40484950515260100150 ... ultimoultimo
Visualizzazione dei risultati da 491 a 500 su 1639
[GUIDA] Reset counter TRIANGLE AWAY [ROOT]
  1. #491
    Quote Originariamente inviato da hiroshi976 Visualizza il messaggio
    mi pare che mettendolo in download mode dovresti vedere il counter.
    edit
    si confermo.
    Grazie tante, ora controllo!!
    EDIT Segna ancora 1...grrrrrrrrrrrrr!!! Non ho capito come risolvere!!!
    Ultima modifica di danguard1976; 05-01-13 alle 16:41
    Androidiano VIP L'avatar di illuminato67
    Samsung Galaxy S7 Edge
    Ringraziato 6,421 volte in 2,733 Posts
    3d su XDA chiuso da Chaifire
    I know trying to explain this is futile, so this will be the last time I bother trying. It's not like this hasn't been stated in this thread a couple of hundred times already.
    If you want the counter to stay 0 on various supported devices (including the S3 with the new bootloaders), you need to be running STOCK kernel and STOCK recovery, or the counter will reset to 1 automatically at each boot.
    This is because these bootloaders check the kernel and recovery signature at each boot. So if you using T/A with CUSTOM kernel or CUSTOM recovery, T/A will reset the counter to 0, but then the next boot the bootloader will detect the CUSTOM kernel/recovery and reset the counter to 1.
    If you're running a custom ROM, a custom kernel, a custom recovery, CWM, TWRP, etc, this will cause the counter to auto-reset to 1.
    Nothing but the same questions and statements. Nobody bothers to read the first post, nobody bothers to read the last few pages and find your answer. Nobody is asking a new question, it's just the same question on repeat. For most questions asked the past few pages, the answer is 23 posts before this one, if not, then the answer is in the first post.
    I'm closing this thread for the time being. Maybe I'll open it again next week when people have gotten used to the new S3 bootloader and perhaps learn to read. Then again, maybe not. This is the first time that I've had to resort to this, let us hope it is also the last.
  4. Il seguente Utente ha ringraziato illuminato67 per il post:
    Anna (05-01-13)
  5. #493
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    Quote Originariamente inviato da danguard1976 Visualizza il messaggio
    Devi fare il root, usare l'apk e poi flashare di nuovo
  6. #494
    Quote Originariamente inviato da illuminato67 Visualizza il messaggio
    Con il nuovo bootloader il counter si attiva ogni volta che si riavvia perché in automatico controlla il kernel e la recovery. Per essere 0 si deve mettere tutto stock. Oppure usare il vecchio bootloader ICS per il modding.
    E questo non solo con XELLA ma anche con altri bootloaders JELLY BEAN
  7. Il seguente Utente ha ringraziato Anna per il post:
    illuminato67 (05-01-13)
  8. #495
    Quote Originariamente inviato da JacOcaJ Visualizza il messaggio
    Hai super ragione io l'ho imparato a mie spese, leggendo su Chainfire XDA e ricevendo la conferma da Dieguccio.
    Il punto esclamativo lo avrete sempre se usate un kernel o una recovery non stock.
    Ma una cosa è certa: andando in download mode con la combo tre tasti noterete che è tutto originale (NO Custom) e counter a zero.
  9. #496
    No, non proprio corretto, anche il punto esclamativo Rosso è legato ai bootloaders jb anche se non tutti, con i vecchi bootloaders ics non viene fuori.
    La samsung sta introducendo poco alla volta modifiche...
  10. #497
    Giusto, ma il punto esclamativo sparisce con recovery e kernel stock
  11. #498
    Esattamente
  12. #499
    Ho risolto...ho rifatto tutto da capo e riflashato il fw originale H3G.
    Di quale punto esclamativo parlate?
  13. #500
    Ringraziato 37 volte in 14 Posts
    ragazzi cortesemente, qualcuno può condividere la versione 2.40 di TA non più scaricabile dal thread di xda perchè aggiornata alla 2.45?
    grazie in anticipo
