Pagina 98 di 256 primaprima ... 488896979899100108148198 ... ultimoultimo
Visualizzazione dei risultati da 971 a 980 su 2557
[KERNEL JB dual boot] SIYAH - one kernel to rule them all (GS3)
  1. #971
    Androidiano VIP L'avatar di illuminato67
    Samsung Galaxy S7 Edge
    Ringraziato 6,421 volte in 2,733 Posts
    Gokhan said:
    this is the second reupload for 1.8.5. first change was in the ramfs and it was a typo (in /init, "CM10" -> "CM101")
    the second change was a little fix in /kernel/power/main.c to prevent spikes to 1800MHz, which was the reason of unexpected reboots
    Se a qualcuno interessa, funziona perfettamente
    Siyah 1.85
    Changelog:
    a temporary kernel-side fix for exynos-mem security hole until Samsung fixes it IMPORTANTE
    added ROW I/O scheduler and set it as default
    lowered GPU thresholds a bit
    fixed GPU voltage initialization (thanks to AndreiLux)
    fixed power saving mode not working (thanks to AndreiLux)
    changed “pleasant for ears” preset and set it default
    boots on cm10.1 but do not use dual-boot support. it will not work yet.
    Edit:
    The ROW scheduling algorithm will be used in mobile devices as default block layer IO scheduling algorithm.
    ROW stands for "READ Over WRITE" which is the main requests dispatch policy of this algorithm.The ROW IO scheduler was developed with the mobile devices needs in mind. In mobile devices we favor user experience upon everything else,
    thus we want to give READ IO requests as much priority as possible.
    The main idea of the ROW scheduling policy is:
    If there are READ requests in pipe - dispatch them but don't starve the WRITE requests too much.
    In definitiva: aumentate le performances in lettura a lieve discapito della latenza di scrittura.
    Andrebbe provato
    Ultima modifica di illuminato67; 21-12-12 alle 14:06
  2. I seguenti 3 Utenti hanno ringraziato illuminato67 per il post:
    blasf70 (21-12-12),lorenzo63 (21-12-12),N1m0Y (25-12-12)
    Androidiano VIP L'avatar di blasf70
    galaxy s4, galaxy s5, gear2neo
    Ringraziato 115 volte in 105 Posts
    Illuminato quindi dici che dall'1.8.4 conviene mettere il nuovo?...ma poi i due zip degli script battery e governor vanno ancora bene?...
  5. #973
    Quote Originariamente inviato da blasf70 Visualizza il messaggio
    Io uso soltanto lo script governor (performance) e funziona.
    Il nuovo scheduler è interessante e va provato.
    E poi ci sarebbe il fix per la sicurezza exynos, che non deve essere trascurato.
    Con Omega 35, flashato da un'ora, nessun problema e fila via liscio e fluido, senza nessun microscatto.
  6. I seguenti 2 Utenti hanno ringraziato illuminato67 per il post:
  7. #974
    Quote Originariamente inviato da illuminato67 Visualizza il messaggio
    Insomma... Si o no?
    Trollallero Trollallá
  8. #975
    Quote Originariamente inviato da JacOcaJ Visualizza il messaggio
    Insomma... Si o no?
    Si
    Edit:
    ma non si capiva
    Jaco, stai perdendo colpi ultimamente
    Edit2: una percentuale di deep sleep mai vista fino ad ora
    Quindi fixed power saving mode not working (thanks to AndreiLux) FUNZIONA
    Ultima modifica di illuminato67; 21-12-12 alle 14:53
  9. #976
    Androidiano VIP L'avatar di alegu
    MILANO
    NOTE3
    Ringraziato 2,319 volte in 1,584 Posts
    Si
    Edit:
    ma non si capiva
    No...sembrava un forse che si forse che no (cit.)
    INVIATO DA ? CON IL MIO S?
  10. #977
    Si
    Edit:
    ma non si capiva
    Non sono io che perdo colpi ma tu che parli come un vecchio saggio Rincoglionito che dice e non dice....
    Sono costernato ma dovrò bannarti!!
    T. V. B.
  11. #978
    T. V. B.
    Io di più
    Allora: io consiglio di flashare il Siyah 1.85.
    Perchè: non me lo ricordo più
    Inviato con il mio S3 ROM Omega 35
    Ultima modifica di illuminato67; 21-12-12 alle 15:46
  12. #979
    Io di più
    La menata è che non va il dual boot
  13. #980
    MILANO
    NOTE3
    Tele+
