Pagina 212 di 242 primaprima ... 112162202210211212213214222 ... ultimoultimo
Visualizzazione dei risultati da 2,111 a 2,120 su 2417
[ROM] - UltimaROM - Sammy based [AROMA]
  1. #2111
    Androidiani Power User L'avatar di Promez
    Localitā
    Samsung Galaxy S3
    Ringraziato 1,724 volte in 1,012 Posts
    UltimaROM - v13.0 Ramuh
    Updated to latest Jelly Bean Firmware XXEMD3
    Updated ALL Mods to XXEMD3 base
    Added 1% Battery Mod to Advanced Settings
    Added AOSP Contacts and Dialler
    Added HTC Lockscreen
    Added Rotary Lockscreen
    Removed Bottom 25 Toggles postion
    Added Transparent/Colour Notification picker
    Added Alarm Icon Toggle
    Added Tab Slider and AOSP styled Tab Slider Lockscreen
    Added Battery BarAdded Toggles, Signal Icon and Battery Colour chooser
    Removed many things from the installer to save space.
    Xperia Z Keyboard, WeatherLove Widget (get from market), LG Weather
    Rotating Lockscreen removed as it messes with newer Lockscreens (sorry!)
    Fixed S4 icons
    Fixed S4 Sounds
    Updated SuperSU
    Updated a number of other apps
    Updated and fixed Samsung Link
    Added Google Hangouts (replacing Talk) and themed version.
    Removed Swipe Dialler (unnecessary now with the AOSP Contacts)
    Stock Google 4.1.2 Calculator replaces Samsung one (smaller, better RAM footprint)
    Added Video Editor from Nexus 7 ROM
    Fixed AOSP Vibration and IME Toggle (no longer have to toggle on and off to make it work)
    Added Wakelag fix toggle - read the information carefully and decide if it's for you. YMMV.
    Fixed Lockscreen torch. Now you hold the home button to activate. The screen doesn't go off while you have the Torch running.
    Fixed Call Recording mod (including the delay). You can now switch off the recording button.
    Added battery full notification toggle and low battery warning toggle.
    Added TricksterMOD app for configuring Kernels (alongisde their respective apps, if any)
    Added Blocking Mode toggle in settings
    Added ExternalSD2InternalSD toggle in settings
    Ultima modifica di Promez; 21-06-13 alle 12:17
    OnePlus One 64Gb : Dirty Unicorns V10.5 05/08 (6.0.1 MTC20F) / Banks Dynamic Gapps
    Google Nexus 7 32Gb : Nougat AOSP 11/08 (7.1.2 NZH54D) / OpenGapps Pico
    Ex Samsung Galaxy S3 Murble White, Google Nexus 4
    Androidiano L'avatar di ciccius
    Galaxy S3,Htc Desire S
    Ringraziato 34 volte in 32 Posts
    Qualcuno l'ha giā flashata??? Commenti???al momento sono a lavoro e non posso flasharla
  4. #2113
    Androidiano L'avatar di ryuxxx
    appena installata,prime impressioni ottime (come sempre) la vedo fluida,unico neo non riesco a fare la videochiamata,non vedo l'icona...
  5. #2114
    Apr 2011
    Localitā
    FOGGIA
    GALAXY NEXUS
    Ringraziato 27 volte in 22 Posts
    Installata con kernel adam, eccezzionale. RAM sempre 200 liberi, fluiditā al top. Per sonalizzazione impressionante.
  6. #2115
    Senior Droid L'avatar di lukas78
    Mar 2011
    Samsung Galaxy S3, S4, S5
    Ringraziato 19 volte in 13 Posts
    che differenza c'č tra la ultimate e la standard (al dil la che la standard sono molti meno mega..)
  7. #2116
    Apr 2011
    Localitā
    FOGGIA
    GALAXY NEXUS
    Quote Originariamente inviato da lukas78 Visualizza il messaggio
    Nella ultimate devi tramite aroma sceglierti tutto quello che desideri, dal modem al kernel e alle app ecc... Mentre lo standard ha tutto preimpostato ma cmq puoi installare tutto quello che vuoi basta andare nel programma ultimarom e scaricati i pacchetti di apk che ti interessano. Io ho installato lo standard e poi mi sono installato cosa mi serviva. L'unico problema che ho avuto era la fotocamera, non funzionava, cambiato il kernel tutto č ritornato a funzionare.
    Ultima modifica di curtise77; 22-06-13 alle 10:03
  8. #2117
    Apr 2011
    Localitā
    FOGGIA
    GALAXY NEXUS
    Quote Originariamente inviato da ryuxxx Visualizza il messaggio
    Prova a fare lo screenshot e dimmi se ti funziona, a me fa errore nel salvataggio.
  9. #2118
    Mar 2011
    che significa:
    "Errore durante il recupero delle informazioni dal server. [RPC:S-5:AEC-0]"
    Mi esce quando voglio scaricare qualsiasi app dal google play
  10. #2119
    ragazzi esiste un modo x cambiare la visualizzazione contatti?nella versione precendete della rom c'era la possibilitā di chiamare i contatti in rubrica direttamente scorrendo il dito verso destra,mentre scorrendo il dito verso sinistra si poteva entrare nei messaggi.ditemi che c'č un rimedio...
  11. #2120
    Androidiano VIP L'avatar di ventu87
    Ringraziato 99 volte in 96 Posts
    Hai scelto quelli aosp in fase di flash della rom?
  12. Il seguente Utente ha ringraziato ventu87 per il post:
    ryuxxx (24-06-13)
