Pagina 67 di 1205 primaprima ... 17576566676869771171675671067 ... ultimoultimo
Visualizzazione dei risultati da 661 a 670 su 12043
[ROM] CyanogenMod 11 Official Builds [4.4][GT-I9300]
  1. #661
    Senior Droid L'avatar di Federicogs3
    Padova
    S3 (i9300) & now s5 (g900F)
    Ringraziato 94 volte in 75 Posts
    Nightly del 18 CHANGELOG:
    Since Tue Dec 17 13:21:45 UTC 2013
    external/koush/ion
    •*72f0f6a Fix translation/cropping?
    •*de2f44a Add test around issue #96
    •*eb9873d Fix upload progress bars.
    •*44bcd66 Merge pull request #121 from hborders/ion-test_res_dir
    •*e2264f7 Add custom parser feature
    •*42ca35f Merge remote-tracking branch 'koush/master' into cm-11.0
    •*8d1661a Do not use VideoLoader prior to SDK Version 12.
    •*d95bdf9 Revert "Revert "Add VideoLoader.""
    •*2389891 Revert "Add VideoLoader."
    •*27f6bfc Add VideoLoader.
    •*8bb9729 Merge pull request #122 from hborders/ant_build_instructions_ANDROID_HOME
    •*85c9017 Use an empty .gitignore for required directories.
    •*279bad1 Typo. Sorry.
    •*0609676 Clean up loading of error resource.
    •*a8869b2 Merge pull request #113 from soundrop/fix/drawable-instrinsics-query
    •*d7e8c6e Added hidden empty file so that res will be created on checkout.
    •*80a1596 Merge pull request #120 from hborders/eclipse_instructions
    •*f8cd3f1 Merge pull request #119 from hborders/ant_build_instructions_ANDROID_HOME
    •*2420fb4 Added instructions for Eclipse setup.
    •*a8f2ed8 Improved ant build instructions.
    frameworks/av
    •*cf8d8ab Merge "Increase kFastTrackMultiplier from 1 to 2" into cm-11.0
    frameworks/base
    •*d57ac56 Fix ResTable_config::CONFIG_* typo (MCC vs MNC)
    •*dc35b02 Merge "systemui: Use the same color for circle battery than clock color" into cm-11.0
    •*d9dc0d7 Merge "systemui: Fix hidden battery icon style" into cm-11.0
    •*d3c0b77 Merge "systemui: fix circle battery percentage alignment for low dpi devices" into cm-11.0
    •*b0fde04 BatteryService: Restore the original parcel order
    •*0094b1e Merge "SystemUI: Forward port Statusbar Clock and Date actions" into cm-11.0
    •*c5510b1 SystemUI: Forward port Statusbar Clock and Date actions
    •*39c8d15 systemui: Use the same color for circle battery than clock color
    •*563e864 Merge "base: added national roaming info for Pepephone in Spain" into cm-11.0
    frameworks/native
    •*d7065ba BatteryService: Restore the original parcel order
    hardware/qcom/audio-caf
    •*ae3ac46 legacy/msm8660: fix VoIP in call audio transmission
    packages/apps/CMFileManager
    •*b478f38 Save scrolling position and restore it when going back
    packages/apps/CMWallpapers
    •*48b09af Update wallpaper app UI
    packages/apps/Mms
    •*86387d4 Mms: Option to delay SMS Sending
    packages/apps/Settings
    •*f85ae18 Merge "Add option for switching between UMS and MTP/PTP mode. (2/2)" into cm-11.0
    •*082170e Merge "Settings: Add missing up navigation in menus" into cm-11.0
    •*dc60337 Add option for switching between UMS and MTP/PTP mode. (2/2)
    packages/services/Telephony
    •*77273f6 Telephony: Dismissable voicemail notifications
    vendor/cm
    •*07e8f87 Merge "Fix custom unofficial build tags" into cm-11.0
    •*e5d12df Merge "Add CM Legal (1 of 2)" into cm-11.0
    •*3bf9ba8 Fix custom unofficial build tags
    vendor/lge
    •*2f37cf0 v500: Updated camera and sensor blobs
    Androidiano VIP L'avatar di EneaMeeta
    Lograto (BS)
    Nexus5
    Ringraziato 307 volte in 256 Posts
    Quote Originariamente inviato da StevenRed Visualizza il messaggio
    Grazie! Io ho trovato il lavoro già fatto su un thread di xda... C'era uno zip già pronto che ho estratto nella cartella media del telefono... Funzionano e non le ho doppie...
    Ottimo allora lo faccio pure io, perché stamattina dopo il flash dell'aggiornamento con cyandelta tutto è tornato come prima, niente più doppie :thumbup: ma anche niente più quelle che ho inserito io
    Probabilmente il procedimento che ho fatto io prima funziona solo per le non Nigtly.
    Vado a scaricarmi il file zip su xda.
    Posta il link per tutti
    Ultima modifica di EneaMeeta; 18-12-13 alle 14:54
    Inviato dal mio tostapane utilizzando tapatampax 😜
    Nexus5 Black
    ROM AICP
    Kernel ..........
    Se pesti una merda ... porta fortuna ... se il giorno dopo ne pesti un'altra ... doppia fortuna ... ma ... un pò meno furtuna non guasterebbe!!! Andrea Moretta
  4. #663
    ~Malpensa
    Google Pixel 8 Pro
    Quote Originariamente inviato da Federicogs3 Visualizza il messaggio
    ATTENZIONE: col BOEFFLA di oggi (ma fatto PRIMA della nightly) ho ancora un problema con la batteria... segna fisso 1% e le impostazioni sono sparite... ora prove senza boeffla!
    EDIT: dopo 4 flash vari conferma: col BOEFFLA di oggi si rompe di nuovo la batteria
    PIXEL 8 PRO
    RICORDA IL QUI A SX!
  5. #664
    DDR
    DDR non è in linea
    Androidiano L'avatar di DDR
    Ringraziato 26 volte in 22 Posts
    Con il telefono in standby premendo il tasto home fa vedere le app aperte di recente, invece di risvegliare soltanto il telefono...c'è modo di risolvere?
  6. #665
    ~Malpensa
    Google Pixel 8 Pro
    Quote Originariamente inviato da DDR Visualizza il messaggio
    Eh sì direi bug...
    Io ho risolto disabilitando la cosa dalle impostazioni
    PIXEL 8 PRO
  7. #666
    Lograto (BS)
    Nexus5
    Ora che lo fai notare mi ricordo che è capitato anche a me ieri qualche volta ma non gli ho dato più di tanto peso, ho appena provato e non lo fa più, forse hanno risolto con l'ultimo aggiornamento, l'hai fatto?
    Nexus5 Black
    ROM AICP
    Kernel ..........
  8. #667
    ~Malpensa
    Google Pixel 8 Pro
    Quote Originariamente inviato da Al3xI98O Visualizza il messaggio
    Allora, ho delle news semi-OT ma visto che se ne parla...:
    pare che il team cyano abbia fatto un revert (tornati indietro con una parte dei sorgenti) quindi il BOEFFLA beta5 e beta6 ha i problemi della batteria mentre il beta4 pare funzioni...
    EDIT: il mitico Lord Boeffla mi ha detto (vabbeh l'ha detto a tutti ma rispondendo a me) che sta scaricando la nightly e quindi...)
    Ultima modifica di Al3xI98O; 18-12-13 alle 15:29
    PIXEL 8 PRO
  9. #668
    Senior Droid L'avatar di StevenRed
    Borgo Valsugana
    Samsung Galaxy Note 8
    Quote Originariamente inviato da EneaMeeta Visualizza il messaggio
    Ecco qui http://forum.xda-developers.com/show....php?t=1663591
    Tra i tanti link ce n'è uno che funziona...
  10. #669
    Borgo Valsugana
    A me non lo ha mai fatto... Io aggiorno con Cyandelta e faccio sempre wipe cache e dalvik... Forse influisce... Tra l'altro uso ART...
  11. #670
    Padova
    Hai risolto col boeffla beta 4?
