Pagina 27 di 82 primaprima ... 1725262728293777 ... ultimoultimo
Visualizzazione dei risultati da 261 a 270 su 818
[ROM] Resurrection Remix® 4.4.2 KitKat [AOKP][CM][PA][Omni][OTA][ART][I9300]
  1. #261
    Androidiano L'avatar di Maxtone
    HUAWEI MATE 10 PRO
    Quote Originariamente inviato da Moskyz Visualizza il messaggio
    Si a tutte e 2
    un link per la fix della fotocamera?
    grazie.
    Senior Droid L'avatar di Moskyz
    Associazione Cazzeggiatori Anonimi
    Galaxy S3
    Ringraziato 74 volte in 65 Posts
  4. #263
    Senior Droid L'avatar di ammanna
    Modena
    Meizu M2 Note
    Ringraziato 228 volte in 129 Posts
    Update: # Resurrection Remix KitKat 4.4.2 - v5.0.5-20140309 # Basic
    NOTE - To all Device Maintainers - Send a PM to 'xenon92' or 'westcrip' at XDA
    containing the link to your ROM thread if you want your name to be added
    in Device Maintainers list.
    - We are releasing a new Official Resurrection Remix Custom Recovery
    based on the latest CWM non-touch recovery. You can download it from the
    respective ROM threads for your device.
    - Completely redesigned Resurrection Tools
    - Added the new Slim Recents (can be toggled back to stock recents in Resurrection Tools)
    - Added Slim's Notification Reminder feature
    - Added Device maintainers
    - Added an Xposed Setting in Resurrection Tools (it will show up only if Xposed-Installer is installed)
    - Added Suspend Actions
    - Added Wakelock blocker
    - Added a new Location Tile - Port from SlimROMs (thanx to rodman01)
    - Updated Resurrection Walls to v7.0
    - Added Toast Animation settings
    - Resurrection setup-switch to holo theme
    - Added an option to toggle status bar visiblity on lock screen
    - i9082: Add multi-user support
    - Added an option to disable camera sounds
    - switch back to cm camera
    - Base: fix icon overflowing with centre clock
    - Base: Added support for Lightbulb app from Paranoid Android
    - SystemUI: open quick settings panel if there are no notifications
    - SystemUI: Fix displaying of user photo.
    - Settings: Added more options in AppOps
    - Settings: SD card partition info menu
    - Added day and week on data usage cycles
    - Enabled status bar brightness control for tablets
    - Base: Do not force notification vibrations in Vibrate Mode
    - Base: Decrease volume panel transparency
    - VolumePanel: Don't force navigation bar
    - Improved Pitch Black (removed red buttons on holo light theme)
    - fixed issue system background not changing on installed custom themes
    - Bluetooth: Added new key to store last connected A2dp Sep type
    - SystemUI: Only show H+ if config_hspa_data_distinguishable is set
    - Base: Fix graphics corruption caused by HWUI caches
    - Fixed upgrading from forward-lock application to system application
    - Updates to Privacy Guard
    - InCallUI: fix non intrusive incallui black on black font
    - SF: Determine if virtual display can use HWC for composition
    - SF: Fix invalid reduction of transparent region from a layer.
    - AV: add .mov extension support
    - AV: fix mute issue for h.264 and MPEG4
    - AV: add Sony camera parameters
    - AV: alot of other updates and fixes
    - Merged latest fixes and commits from CyanogenMod
    - Many more fixes and updates...
  5. #264
    Modena
    Meizu M2 Note
    Scusate doppio post,
    comunque sono "fuori sede" non riuscirò ad aggiornare il primo post prima di giovedì sera/ venerdì
    Ultima modifica di ammanna; 10-03-14 alle 09:06
  6. #265
    ciao ragazzi!!!ma il fix della fotocamera va fatto anche con quest ultima versione??? oppure funziona senza??
    inoltre nella pagina dove è presente il fix, precisamente in questa,
    Gerrit Code Review
    dove c'è la 2.3 consigliata dsa moskyz non riesco a trovare dove scaricare....chi mi aiuta??
  7. #266
    Ringraziato 46 volte in 43 Posts
    Veramente contento di questa rom, sono riusciti a migliorare qualcosa di già perfetto. P.S. per aggiornare non c'è bisogno della nuova official Resurrection Remix Custom Recovery , io ho usato la vecchia PhilZ touch
  8. #267
    Quote Originariamente inviato da rickardsat Visualizza il messaggio
    Gerrit Code Review
    Se usi la stock potrebbe servire, con awesome camera non ne sento il bisogno, la camera non va mai in crash
  9. #268
    Galaxy S3
    Si può aggiornare senza fare full wipe? Le GApps sono le stesse?
  10. #269
    Si ad entrambe
  11. Il seguente Utente ha ringraziato matrix360 per il post:
    Moskyz (10-03-14)
  12. #270
    trento
    Samsung S III ed ora HTC one
    ragazzi scusate....per quanto riguarda le chiamate in arrivo, come si fà ad impostarla a tutta schermata....Mi spiego meglio !! Se sei con un app aperta, la chiamata in arrivo viene visualizzata alla base, io vorrei invece che venisse visualizzata a schermo intero...Qualcuno mi spiega come fare ?!?!?! Grazie
