Pagina 71 di 82 primaprima ... 2161697071727381 ... ultimoultimo
Visualizzazione dei risultati da 701 a 710 su 818
[ROM] Resurrection Remix® 4.4.2 KitKat [AOKP][CM][PA][Omni][OTA][ART][I9300]
  1. #701
    Androidiano L'avatar di Billycook
    Apr 2014
    Localitą
    Galaxy S3
    Voi avete avuto problemi con i temi?
    Quote Originariamente inviato da Nemen Visualizza il messaggio
    Problemi con launcher vari?
    No nessuno (uso nova)
    Scusate gli errori di ortografia ma sto scrivendo da cellulare
    LG G4 CARBONIO NERO
    In pensione:
    Usa il tasto thanks
    Senior Droid L'avatar di ammanna
    Localitą
    Modena
    Meizu M2 Note
    Ringraziato 228 volte in 129 Posts
    # Resurrection Remix KitKat 4.4.2 - v5.1.4-20140602 # Basic
    - Add gesture anywhere
    - Add equalizer tile
    - Add compass tile
    - On-The-Go mode & shake to turn on/off torch
    - Add system app remover
    - Added Power button to available NavigationBar buttons
    - Add on-the-go and volume as Default tile
    - Fliptile animation:For Compass Tile & On-The-Go Tile
    - SystemUI: Make wifi combo margin themable
    - Lockscreen: Avoid SystemUI crash due to NPE - fix all bıtmap derp
    - Fix resource leaks
    - Fix hiding ADB notification
    - CM11 Themes: Use package name from AndroidManifest
    - wm: Underp menu key release processing
    - Fix circle battery opaqueness for the low battery color
    - wm: Make the default menu longpress action configurable at build time
    - wm: Simplify menu action decision paths
    - quiethours: fix vibrate option
    - Keyguard : Fix album art sticking after playback is stopped
    - fix default lockscreen targets
    - CM11 Themes: Don't kill setup wizards
    - Fix wallpapers not applying in full screen
    - Added Non-Roaming for carrier BSNL in UP East and WEST INDIA
    - frameworks: allow Keyguard package to be defined in overlay
    - Keyguard: Make sure disabling Camera widget
    - perf: Don't persist the perf profile across a reboot
    - perf: Send a boost hint when a key on the navbar is pressed
    - Animate circle battery rotation back to 0 after unplugging
    - Bluetooth: Fix for device gets stuck in pairing
    - Bluetooth: Acquire wakelock to turn on lcd during Connection
    - settings: Move headset option, hide MoreDeviceSettings if empty
    - Settings: Remove screen rotation from accessibility
    - Settings: Allow access for external apps to launch ThemeSettings Fragment directly
    - Settings: read keyguard package name from overlays
    - Settings: Disable Battery status preference on ModLock.
    - Settings: Remove "Make pattern visible" regardless.
    - Settings: Device Maintainers: Remove janice & codina
    - Settings: Maintainer : add device Galaxy Note int
    - n7100 - Fix sensors - audio hal updates - Update fingerprint
    - i9300 - Add iso mode settings to the CameraWrapper - fix preview/camera crash after stopping video record
    - ResurrectionSetup updates
    - Trebuchet updates
    - Theme chooser updates
    - Camera app improvements
    - Calculator updates
    - MMS updates
    - Included lot of performance,sound and media updates
    - Included All CyanogenMod source updates and fixes
    - Check out the source activities for more updates https://github.com/ResurrectionRemix
  4. #703
    Samung Galaxy S6Edge
    ciao,
    dopo l'installazione dell'ultima versione va tutto bene... tranne "sblocco con il sorriso" in cui la fotocamera non si avvia (e quindi poi mi chiede di inserire il segno). se pero' provo ad attivare la fotocamera manualmente va tutto bene (sia quella di serie che la Google camera).
    succede a qualcun altro?
  5. #704
    Apr 2014
    Localitą
    Galaxy S3
    Sapete il motivo di questo ultimo update ? (04/06/2014)
    LG G4 CARBONIO NERO
    In pensione:
    Usa il tasto thanks
  6. #705
    Androidiano VIP L'avatar di maxxxy
    Localitą
    Lodi
    mate10pro-lepro3-OPO-s3-s2
    Ringraziato 68 volte in 55 Posts
    scusate se tiro in ballo ancora questo discorso ma non sono riuscito a risolvere
    io ho la mia versione "prime" di nova launcher
    se cerco di installarla mi da errore....
    mi avete scritto di cancellare da system/app con root explorer .....ma in system app non cč nulla che riguarda nova....come faccio???
    grazie a tutti per l'aiuto che mi date!!!!
    se sono stato d'aiuto vi ringrazio se premete il tasto THANKS..... č sempre cosa gradita!!
  7. #706
    Androidiano L'avatar di cavalieredelmare
    s3 - note 4
    nessun changelog su 20140603... non viene elencata nemmeno in xda... qualcuno l'ha scaricata? perchč questa nuova versione?... cmq vado a scaricarla e dopo un po s'impalla... provo dal pc e vediamo che succede
    ATTUALMENTE MONTO
  8. #707
    s3 - note 4
    Quote Originariamente inviato da cavalieredelmare Visualizza il messaggio
    a questo indirizzo mi da pagina inesistente... che sia un errore?
    http://fs1.d-h.st/download/00122/3su...0603-i9300.zip
    ATTUALMENTE MONTO
  9. #708
    s3 - note 4
    Il Download č stato ripristinato, ho scaricato e flashato ... il changelog porta quello del 20140602 e di novitą non ne trovo nessuna... qualcuno ha dei lumi per questa versione?
    ATTUALMENTE MONTO
  10. #709
    Nov 2013
    GT-i9300
    Io ho avuto problemi con il google play service, che si arrestava in modo anomalo. Ho dovuto flashare un backup precedente
  11. #710
    Apr 2014
    Localitą
    Galaxy S3
    Io l'ho provata e dato che non mi risolveva quei paio di problemini sono tornato alla .13
    LG G4 CARBONIO NERO
    In pensione:
    Usa il tasto thanks
