ciao a tutti come mai non mi vede la sd esterna ? grazie
Il telefono mi porta un aggiornamento qualcuno lo ha aggiornato nuova versione del 28
SmartPhone:
Samsung Galaxy S3 4.1.2 stock White
Tablet:
Samsung Galaxy Note 10.1 3G White
changelog nuova versione 28-1-13
# Resurrection Remix KitKat 4.4.2 - 20140128 # Basic
-Enable build with linaro 4.7.4 toolchain (more info About Linaro: not-for-profit, open source engineering for ARM architecture)
-DownloadManager : Add live folder
-add SELinux status information (fixes about phone fc)
-add more animation scaling factors to developer settings
-remove 3-dot overlay checkbox
-update about RR :Add xenon92
-add checkbox for quick unlock
-Persist lock screen blur on reboots
-Fix one NPE in tethering setting
-Show memory full text only for internal storage
-Bleed keyguard widget picker list into translucent bars
-Dialer: Proposal to amendment the look of dialer to fit kk
-Re-add LoaderCallbacks to CyanogenMod dialer
-Dialer: restore full compatibility with theme chooser
-camera: Keep touch focus intact during back-to-back ZSL shots
-Camera: Change volume hard key button to zoom function
-Set default video quality to the highest
-camera: Make the popup menu transparent
-Camera2: implement exposure compensation settings in video mode
-Camera: separate settings for color effects
-Camera2: implement volume key zoom in video mode
-Move message blacklist to framework
-Telephony: implement noise suppression for phone calls
-lights: Add music light support
-Drop Lockscreen vibrate option
-don't disable lockscreen widgets on low memory devices
-Removed fast torch long press power button
-Glowpad Torch
-Last App Toggle from Omnirom
-TRDS: Dark DocumentsUI
-bring back rr carbon system background
-add AM-PM settings
-Add center clock
-Set Settings.Global.WIFI_SCAN_ALWAYS_AVAILABLE default value
-FB: Slim IME options
-fix multiuser bug in vibrator service
-add custom bootanimation colors support
-raise max keygaurd widgets from 5 to 20
-Framework: instant led test
-Notification : Fix app info long-press
mrciccio (28-01-14)
Fatto pieno wipe ,non parte
Scegli la lingua poi ti da errore
Chiedi anche qui:
Questa ROM eredita tutti i problemi della CM immagino, vero?
I due prblemi CM che NON sopporto più sono:
- battery drain osceno che non riesco a risolvere
- musica che "scatta" con il monitor spento
PIXEL 8 PRO
RICORDA ILQUI A SX!
Al3xI98O (29-01-14)
Lo sviluppatore ha appena consigliato che quando ci si trova nella pagina iniziale del setup della rom, bisogna tirare giù la tendina delle notifiche (credo intendesse i quick setting) e attivare il wifi e poi procedere con l' installazione
Aggiunge inoltre che questo bug verrà corretto della prossima versione
