Utente del mese: megthebest con ben 44 Thanks ricevuti nell'ultimo mese
Pagina 1 di 855 1231151101501 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 8547
[ROM][7.0][G920/25F/I][5EQAC] ☼ CarHDRom V.28 ☼ [17/03/17]
    Russi - RA
    Ringraziato 12,193 volte in 4,764 Posts
    CarHDRom V.30.3 - 7.0 Nougat - 27/04/17
    for G920F and G925F
    BASED ON OFFICIAL FIRMWARE XXU5EQCK
    *DEODEXED
    *ZIPALIGNED
    *ROOTED
    *PARTIALLY DEBLOATED
    *FEATURES
    *BUILD.PROP TWEAKS
    *AROMA
    *TUNE2FS/EXT4
    *ALL THE APPS UPDATED
    *VIRTUAL LOCK BUTTON ON TOP-LEFT
    *STOCK KERNELS
    NUOVO BOOTLOADER E MODEM ANCHE SE NON SERVE
    Nougat Bootloader e MODEM flashabile via TWRP
    per G925F download
    per G920F download
    nessun problema per ritornare a Marshmallow
    CarHDRom Nougat Download Center
    *virtual buttons lock-recents-home in statusbar
    -fixed Private Mode
    -updated SBrowser with private mode
    -added 10 fonts
    -added multi GPS
    -fixed Smart View thanks to @bunty_parona
    -fingerprint fixed
    -added netwok traffic
    -added Quicklauncher in recents
    -added Potato Clock
    -added virtual button home and recents in statusbar
    -fixed AppLock
    -Updated all the apps
    -added init.d
    -added twlauncher transition effects
    -wifi-signal left or right in rom control
    -removed popup warning high light
    -added 3minit working with AdAway enabled
    -updated all the apps
    -disabled safe volume warning
    -notification panel background with image
    -added Recovery button in power menu
    -added enable/disable USB wakeup
    -added multi csc
    -fixed Netflix
    -added choise ro.securestorage.support true/false
    AROMA THEME V.30.3
    Download in CarHDRom Control app/menu/OTA and Links/OTA with Mega .... AROMA THEMES
    thanks to @iBotPeaches for apktool
    thanks to @Ticklefish for tool TMA
    1) THEMES AND APPS:
    MAIN THEME INVERTED
    - framework
    - SBrowser
    - SecSettings
    - SystemUI
    - TWLauncher
    - ClockPackage
    - Contacts
    - Samsung IME
    - Messaging_Common
    - Calculator
    - Teleservice
    - SecMyFiles
    - Samsung Video
    - SMusic
    - Phonesky
    THEMES
    Need to flash Main Theme Inverted before
    -SYNPHONY BLUE
    -FANTASY
    -UNDERWATER
    -METAL BLACK
    -GOLD
    -ORANGE
    -RED
    -GREEN
    -Dark3D
    2) BACKGROUNDS:
    - 8 POPUP MENU BACKGROUNDS
    - 8 NOTIFICATION BACKGROUNDS
    - 10 BACKGROUNDS FOR HEADER IN PULLDOWN
    - 12 STATUSBAR BACKGROUNDS
    3) MODS: for ROM also
    - EMOJIS: AOSP, IOS, SAMSUNG
    4) STATUSBAR ICONS:
    - STATUSBAR SMALL TRUE ICONS
    - 11 SIGNAL ICONS
    - 4 DATA ICONS
    - 12 WIFI ICONS
    - 5 WIFI/DATA ARROWS ICONS
    - 6 GPS ICONS
    - 6 ALARM ICONS
    - 10 BLUETOOTH ICONS
    - 3 SOUND ICONS
    - 6 AIRPLANE ICONS
    - 10 BATTERIES
    5) CONTACTS DIALPAD:
    - 8 DIALPAD BACKGROUNDS
    - 9 NUMBER BUTTONS
    - 9 ICON BUTTONS
    6) MESSAGES KEYBOARD:
    - 6 KEYBOARDS
    7) LOCKSCREEN DIGITAL CLOCK:
    - 20 CLOCK STYLES
    8) TEXTS COLOR:
    - 15 STYLES PRIMARY AND SECONDARY TEXTS
    9) COLORS:
    - 15 STYLES TOGGLES COLORS
    - 15 STYLES SLIDER COLORS
    Ultima modifica di carotix; 27-04-17 alle 10:04
  2. I seguenti 22 Utenti hanno ringraziato carotix per il post:
    Alessioks (28-05-15),Andrewgp (20-05-15),andtraini (11-07-15),bluflight13 (01-03-16),chicco30 (06-11-16),dmnk91pe (26-12-15),dore (15-02-16),DreamReaper (07-05-16),emilio1962 (18-05-15),ermitraglia33 (12-03-16),gabriosan75 (07-11-15),Gac400 (22-09-15),guidogt (22-03-17),Hancock (25-07-16),ilcapitano (18-05-15),lmello (16-12-15),MaRkO72 (02-10-15),Q.dino (18-05-15),Tinuccio (10-04-16),usitaly (20-03-16),yuri76 (10-07-15),Zangetsu (21-01-17)
    Russi - RA
    CarHDRom V.27.3 - 6.0.1 MarshMallow - 14/02/17
    BASED ON OFFICIAL FIRMWARE 5DPL4
    *DEODEXED thanks to @svadev for tool
    *ZIPALIGNED
    *BUSIBOX
    *SUPERSU 2.79 SR3 credit to @Chainfire
    *DEBLOATED
    *FEATURES
    *ROM CONTROL v.2 credit to @Wuby986 and @daxgirl
    *TOOLBOX thanks to @xperiacle
    *3MINIT BATTERY thanks to @gharrington
    *QUICKLAUNCHER IN RECENTS
    *GRADIENT STATUSBAR thanks to @mariozawa
    *OTA
    *VIPER4
    *AROMA THEME in OTA
    *5WAY REBOOT thanks to @Repulsa and @kep2008
    *POTATO CLOCK thanks to @mariozawa
    *ALL APPS IN MULTIWINDOWS
    *22 TOGGLES
    *SETTING TORCH ON VOL UP
    *NETFLIX FIXED
    *AUTOBRIGHTNESS FIXED
    *TOUCHKEY LIGHT DURATION
    *MOD OUT DOOR
    *TWSwipe thanks to @daxgirl
    *OPEN WITH
    *SAFE VOLUME WARNING
    *VOLTE SUPPORT
    *SWIPE LEFT BORDER TO OPEN LOCKSCREEN
    *SOUND BOOST
    *MULTI PDI
    *TWEAKS BATTERY LIFE
    *MULTIUSER ENABLE/DISABLE
    *LTE ONLY MODE
    and more ....
    GitHub source code
    special thanks to my friend @tdunham
    for his mods and awesome thread
    Download CarHDRom
    you can select in aroma:
    -full wipe or not
    -Models of devices
    -Multi CSC
    -Multi GPS
    -Ambient Display
    -LTE icon instead of 4G
    -Data Usage
    -NFC Statusbar Icon
    -Arter kernel G920-G925 F/I/S/L/K/TW8 credit to awesome @arter97
    -Stock kernel G920-G925 F/I/S/L/K/TW8
    -All other options are in Aroma Theme ... post #2
    Warning:
    if you run a stock kernel , you can flash a custom one over it
    but if you run a custom kernel and you want to flash a stock kernel , you need to make a full wipe
    AROMA REMOVED APPS v.3 in OTA
    little guide to flash a custom rom here
    fix for Reversed touch 920F here
    AROMA THEME V.27.3-A
    Video from YouTube thanks to @cobra11111
    1) THEMES AND APPS:
    MAIN THEME TRANSPARENT INVERTED
    - framework
    - twframework
    - InCallUI
    - Theme Store
    - Play Store
    - Wallpaper Picker S7
    - Calculator
    - TWSwipe
    - Potato Clock
    - Potato Gradient
    - SBrowser Nougat
    - SecSettings
    - SystemUI
    - SecGallery N7
    - TWLauncher
    - SVideo
    - SecMyFiles
    - Weather Widget
    - SMusic
    - ClockPackage
    - SPlanner
    - SecContacts
    - Samsung IME
    - TeleService
    - SecEmail
    - Smart Manager
    - Rom Control
    - AccuweatherPhone2015
    - XDA Lab
    - Velvet (Google Search)
    - SMemo
    - CocktailBarService
    - People Stripe
    - AirMessage
    - EmergencyModeService
    - TouchWizHome
    - ViPER4Android_FX_A4
    - PersonalPageService
    - 3MinitBatterySettings
    - Tapatalk
    EXTRA APPS
    -Ambient Display
    -RootExplorer Inverted
    -Tapatalk
    -Teleservice full features
    -SmartManager C5
    -SmartRemote
    THEMES
    -SYNPHONY BLUE
    -BLACK NEON
    -FANTASY
    -UNDERWATER
    -METAL BLACK
    -GOLD
    -ORANGE
    -CHRISTMAS
    -RED
    -GREEN
    -Dark3D
    2) BACKGROUNDS:
    - 9 BACKGROUNDS FOR PULLDOWN
    - 12 MAIN APPS BACKGROUNDS
    - 10 BACKGROUNDS FOR TOGGLES IN PULLDOWN
    - 10 BACKGROUNDS FOR SLIDER IN PULLDOWN
    - TWLAUNCHER WITH BRIEFING OR 6THGEAR
    - HIDE/SHOW QUICK LAUNCHER IN RECENTS
    - HIDE/SHOW WEATHER IN LOCKSCREEN
    - TRAFFIC METER AND SIGNAL-WIFI OPTIONS
    4) GENERAL ICONS:
    - 3 MAIN ICONS: True, Gold and Chrome
    5) STATUSBAR ICONS:
    - 11 SIGNAL ICONS
    - 4 DATA ICONS
    - 12 WIFI ICONS
    - 6 GPS ICONS
    - 6 ALARM ICONS
    - 3 SOUND ICONS
    - 6 AIRPLANE ICONS
    - 10 BATTERIES
    6) SETTINGS:
    - TRUE ICONS
    - STOCK ICONS
    - STOCK ICONS WITH BLUE CIRCLE
    - TRUE ICONS DARK
    - TRUE ICONS YELLOW
    7) TEXT COLOR:
    - 9 CLOCK ACCUWEATHER HOME COLORS
    - 9 PRIMARY TEXT COLORS
    - 9 SECONDARY TEXT COLORS
    8) CONTACTS DIALPAD:
    - 9 NUMBER BUTTONS
    - 9 ICON BUTTONS
    9) MESSAGES KEYBOARD:
    - 6 KEYBOARDS
    10) TOGGLE BACKGROUNDS:
    - 11 ROUND BACKGROUNDS
    - 11 SQUARE BACKGROUNDS
    11) LOCKSCREEN DIGITAL CLOCK:
    - CONFIGURATIONS FOR ROM OR MAIN THEME:
    1) Clock, Weather, Barometer, Sunrise
    2) Clock, Weather, Sunrise
    3) Clock, Weather
    4) Clock
    - 20 CLOCK STYLES
    12) LOCKSCREEN ANALOGIC CLOCK:
    1) Clock, Old Weather Widget
    2) Clock, Weather, Barometer
    3) Clock, Weather
    4) Clock
    -14 CLOCK STYLES
    13) ANIMATIONS:
    8 STYLES ANIMATION BAR PULLDOWN
    -Hide Animation
    -Blue Light Supercar Bar
    -Green Supercar Bar
    -Red Supercar Bar
    -Yellow Supercar Bar
    -Blue Supercar Bar
    -Christmas Light Bar
    -Snow Bar
    2 STYLES SNOW ANIMATION IN PULLDOWN AND LOCKSCREEN
    -Hide Animation
    -Show Snow Animation Style 1
    -Snow Snow Animation Style 2
    CHRISTMAS TREE ANIMATION IN PULLDOWN AND LOCKSCREEN
    -Hide Christmas Tree Animation
    -Show Christmas Tree Animation
    CONTACTS DIALPAD ANIMATION
    -Hide Animation
    -Show Animation dialer buttons colored
    -Show Animation woman
    -Show Animation Gold Christmas
    14)TWLAUNCHER ICONS BG:
    -5 square bg (transparent included)
    -3 circle bg
    Ultima modifica di carotix; 18-03-17 alle 17:55
  5. I seguenti 8 Utenti hanno ringraziato carotix per il post:
    chicco30 (06-11-16),DreamReaper (07-05-16),Gac400 (04-09-15),Hancock (24-07-16),MaRkO72 (02-10-15),Q.dino (20-07-15),yuri76 (18-05-15),Zangetsu (21-01-17)
  6. #3
    Russi - RA
    Ultima modifica di carotix; 14-11-16 alle 13:55
  7. I seguenti 4 Utenti hanno ringraziato carotix per il post:
    DreamReaper (07-05-16),MaRkO72 (02-10-15),pluviet (18-10-16),Zangetsu (21-01-17)
  8. #4
    Ringraziato 17 volte in 13 Posts
    CIAO CAROTIX ho scaricato la rom ma prima di procedere all'installazione volevo alcuni chiarimenti:
    1) io ho rootato con pingpomg posso installare direttamente da odin la recovery?
    2) C'E' la possibilita' di un tema stock?
  9. #5
    Russi - RA
    Quote Originariamente inviato da massarone Visualizza il messaggio
    ciao massarone ,
    1)non saprei .. non ho seguito la modalità di pingpong
    2)se intendi con sfondi bianchi , no , non è nel mio stile .. ma in giro ci sono già rom stock su xda
  10. Il seguente Utente ha ringraziato carotix per il post:
    massarone (19-05-15)
  11. #6
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    Off topic cancellati
    La prossima volta che vedo tanti post inutili, parto con le infrazioni
  12. #7
    Russi - RA
  13. Il seguente Utente ha ringraziato carotix per il post:
    emilio1962 (20-05-15)
  14. #8
    Androidiano VIP L'avatar di Q.dino
    Terracina (LT)
    omnia hd.s2.s4.S6 edge s10+
    Ringraziato 1,299 volte in 992 Posts
    Certo che puoi flashare là recovery via odin, pingpong serve x non perdere la garanzia ma se flashi la recovery knox si attiva
    S 10 + G975 F
    S 23 ULTRA
  15. Il seguente Utente ha ringraziato Q.dino per il post:
    Andrewgp (20-05-15)
  16. #9
    giorno carotix per favore mi puoi dare una spiegazione? allora o messo vareie rom sul mio edge e ho un problema quando faggio un video in verticale e lo vado a vedere sul pc o sulla tv si vede in orizzontale e l'immagine e storta. da cosa puo dipendere difetto del cell??
  17. #10
    Russi - RA
    no .. anche il mio fa cosi ... va utilizzato in orizzontale
  18. Il seguente Utente ha ringraziato carotix per il post:
    massarone (25-05-15)
