[ROM][P311X][JB][10-28-12] ButterNutz
BUTTERNUTZ ROM
eccovi una rom tutta da provare
x3110 3100 3113
FONTE XDA
[ROM][P311X][JB][10-28-12] ButterNutz - xda-developers
Changelog
9/24
Initial Release
10/1
Pull-down toggles
Launcher2 now obeys the system auto-rotate preference
Set the external SD Card to be external storage and internal SD Card to be secondary storage.
10/19
Updated Google Apps
Updated to 4.1.2
Switched from Launcher2 to Trebuchet
Increased time required to disable touch on screen due to the "water detection" feature change didn't work
Few framework changes from CM10
10/23
Revert back to Launcher2
Change in how the kernel boots, see Github for details
10/24
Initial release for P511X
Fix layout in Settings.apk
10/28
Fixed a couple device asserts to prevent problems with flashing
INSTALLAZIONE
mettere il file scaricato nella sd card esterna
permessi di root e cwm richiesti
riavviare in recovery mode
effettuare i tre wipe
install zip from sd card /installare la rom
riavviare
non mi assumo responsabilita su danni al vostro tablet
chi vuole provi a suo rischio
buon modding
DOWNLOAD 3110
http://www.imnuts.org/downloads/espr...0_10-28-12.zip
DOWNLOAD 3100 ALPHA
http://www.imnuts.org/downloads/espr...0_10-19-12.zip
DOWNLOAD 3113
http://www.imnuts.org/downloads/espr...3_10-28-12.zip
