Ho provato anche con flash tool ma il cell non riesce a riavviarsi , poi ho notato che flashtool a volte da anche qualche errore , è inutile sono tre giorni che chiedo nessuno sà cosa devo fare
Orai il telefono dopo aver tentato il ripristino con pc companion non riesce neanche ad entrare in flash mode lampeggia di rosso
Ok ho riflashato questi i risultati 02/028/2013 17:28:51 - INFO - <- This level is successfully initialized
02/028/2013 17:28:51 - INFO - Flashtool Version 0.9.10.1 built on 2013-01-09 19:49:47
02/028/2013 17:28:51 - INFO - You can drag and drop ftf files here to start flashing them
02/028/2013 17:28:57 - INFO - Device disconnected
02/029/2013 17:29:01 - INFO - Selected LT18i_4.1.B.0.587_Kernel.ftf
02/029/2013 17:29:01 - INFO - Preparing files for flashing
02/029/2013 17:29:01 - INFO - Please connect your device into flashmode.
02/029/2013 17:29:23 - INFO - Flash canceled
02/029/2013 17:29:42 - INFO - Selected LT18i_4.1.B.0.587_Kernel.ftf
02/029/2013 17:29:42 - INFO - Preparing files for flashing
02/029/2013 17:29:42 - INFO - Please connect your device into flashmode.
02/030/2013 17:30:46 - INFO - Flash canceled
02/032/2013 17:32:12 - INFO - Device connected in flash mode
02/032/2013 17:32:45 - INFO - Selected LT18i_4.1.B.0.587_Kernel.ftf
02/032/2013 17:32:45 - INFO - Preparing files for flashing
02/032/2013 17:32:45 - INFO - Please connect your device into flashmode.
02/032/2013 17:32:46 - INFO - Opening device for R/W
02/032/2013 17:32:46 - INFO - Reading device information
02/032/2013 17:32:46 - INFO - Phone ready for flashmode operations.
02/032/2013 17:32:46 - INFO - Current device : LT18i - CB5A1HVZ0B - 1254-5982_R2I - 1253-8238_4.1.B.0.587 - WORLD-i_4.1.B.0.587
02/032/2013 17:32:46 - INFO - Start Flashing
02/032/2013 17:32:46 - INFO - Processing loader
02/032/2013 17:32:46 - INFO - Checking header
02/032/2013 17:32:46 - INFO - Flashing data
02/032/2013 17:32:49 - INFO - Loader : S1_Loader_Root_773f - Version : R4A066 / Bootloader status : ROOTED
02/032/2013 17:32:49 - INFO - Disabling final data verification check
02/032/2013 17:32:49 - INFO - Processing kernel.sin
02/032/2013 17:32:49 - INFO - Checking header
02/032/2013 17:32:49 - INFO - Flashing data
02/032/2013 17:32:52 - INFO - Ending flash session
02/032/2013 17:32:52 - INFO - Flashing finished.
02/032/2013 17:32:52 - INFO - Please unplug and start your phone
02/032/2013 17:32:52 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
02/032/2013 17:32:52 - INFO - Device connected in flash mode
ciao ragazzi, ho un problema che mi si è verificato sia nella 2.0.3 che ora nella 3.0.2:
praticamente una volta installata la rom, installo tutte le applicazioni partendo da link2sd e titanium backup e imposto tra le preferenze, l'installazione nella sd;
una volta finite le installazioni faccio una rassegna per spostare su sd quelle che non sono già state messe li.
metto i collegamenti sulla home ma una volta che spengo o riavvio, le icone delle app che ho spostato manualmente su sd spariscono dalla home; è come se non mi salvasse le preferenze! da cosa può dipendere? devo fare un qualche wipe che mi sfugge o modificare qualcosa?
Fatemi sapere
Esiste un usb dongle per i Sony?
a che serve una usb dongle?
Be ragazzi è qualche giorno che uso la 3.0.2 e devo dire che mi sembra un po instabile. Noto dei blocchi frequenti e soprattutto necessita di riavvii per risolvere dei rallentamenti imbarazzanti dopo circa una giornata di utilizzo... Qualcun'altro la sta usando?. Come vi trovate?
Inviato dal mio LT18i usando Androidiani App
io la sto usando da quando è uscita e mi trovo benissimo,magari prova a rifare un wipe dalvik e guarda se la situazione migliora![]()
Originariamente inviato da jio85
Mah! Ora ho provato a fare il wipe della dalvik... Vediamo un po!!!
Jio85 a me!? Ma esiste per i sony?! La usb dongle
