Utente del giorno: kroko con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 27 di 44 primaprima ... 17252627282937 ... ultimoultimo
Visualizzazione dei risultati da 261 a 270 su 431
[RECOVERY][gemini] Lista TWRP per Xiaomi Mi 5 + installazione + permessi di root
  1. #261
    Androidiano L'avatar di androboy86
    flasha questo zip di supersu 2.79 SR3
    https://download.chainfire.eu/1021/S...0114223742.zip
    Grazie mille!!!! Adesso é tutto a posto!
    Moderatore L'avatar di BlackJack89
    Vault 105
    OnePlus 5
    Ringraziato 741 volte in 538 Posts
    Nuova build RC1 3.0.3-0
    Link al download QUI
    Changelog:
    - Built with android-7.1 tree
    - Fixed compatibility with systemless SuperSU flashing on F2FS (thanks to @Arter97 for the great finding)
    - Updated to the latest N crypto libs (backward compatibility with M preserved)
    Un Grazie è sempre ben accetto
  4. #263
    Nov 2016
    Xiaomi Mi 5
    Ringraziato 55 volte in 43 Posts
    uscita la TWRP v3.1.0-0
    Changelog:
    1. vold decrypt on a few select HTC devices, TWRP will now attempt to use the system partition’s vold and vdc binaries and libraries to decrypt the data partition (nkk71 and CaptainThrowback)
    2. adb backup to stream a backup directly to or from your PC, see documentation here: https://github.com/omnirom/android_b...863b15c16949d9 (bigbiff)
    3. tweak MTP startup routines (mdmower)
    4. support new Android 7.x xattrs for backup and restore to fix loss of data after a restore (Dees_Troy)
    5. support POSIX file capabilities backup and restore to fix VoLTE on HTC devices and possibly other issues (Dees_Troy)
    6. better indicate to users that internal storage is not backed up (Dees_Troy)
    7. improve automatic determination of TW_THEME (mdmower)
    8. minimal getcap and setcap support (_that)
    9. try mounting both ext4 and f2fs during decrypt (jcadduono and Dees_Troy)
    10. shut off backlight with power key (mdmower)
    11. timeout during FDE decrypt (Dees_Troy and nkk71)
    12. support for FBE decrypt and backing up and restoring FBE policies (Dees_Troy)
    13. boot slot support (Dees_Troy)
    14. TWRP app install prompt during reboot (Dees_Troy)
    15. support for AB OTA zips (Dees_Troy)
    16. support new Android 7.x log command (Dees_Troy)
    17. update recovery sources to AOSP 7.1 (Dees_Troy)
    18. numerous bugfixes and improvements by too many people to mention
    Ultima modifica di PEBKAC; 11-03-17 alle 14:06
  5. #264
    Nov 2016
    Xiaomi Mi 5
    Quote Originariamente inviato da PEBKAC Visualizza il messaggio
    l'hanno già ritirata per problemi ed è uscita la TWRP v3.1.0-1
  6. I seguenti 2 Utenti hanno ringraziato PEBKAC per il post:
    BlackJack89 (12-03-17),Wawalord (12-03-17)
  7. #265
    Vault 105
    OnePlus 5
    Bene, provvedo ad aggiustare il primo post!
    Sempre meglio aspettare un paio di giorni prima di installare nuove modifiche di sistema
    Inviato dal mio MI 5 utilizzando Tapatalk
  8. #266
    Nov 2009
    ciao a tutti ho un problema per fleshare la recovery, ho la global dev, quando vado a fleshare tramite fastboot la recovery twrp, l'ultima uscita, mi da FAILED invalid argument, cosa vuol dire? come risolvo?
  9. #267
    Nov 2016
    Xiaomi Mi 5
    Quote Originariamente inviato da ale93 Visualizza il messaggio
    i prerequisiti (bootloader sbloccato, debug usb, ecc) sono tutti soddisfatti?
    quando dai:
    codice:
    fastboot devices
    ti vede il telefono?
    l'ultima twrp ufficiale la trovi qua ...stai usando questa?
    in caso mettila così come l'hai scaricata nella stessa cartella di ADB e dai il comando:
    codice:
    fastboot flash recovery twrp-3.1.0-1-gemini.img
  10. Il seguente Utente ha ringraziato PEBKAC per il post:
    ale93 (14-03-17)
  11. #268
    Nov 2009
    Grazie ho risolto lasciando la recovery cosi com'è
  12. #269
    Perchè adesso quando entro in TWRP mi chiede una password (che non ho) per il decrypt data? Annullando questo passaggio, quando vado poi a ricercare i file da flashare non mi trova nulla....
    in poche parole mi chiede una password per montare le partizioni?
    Ultima modifica di androboy86; 16-03-17 alle 11:20
  13. #270
    Nov 2016
    Xiaomi Mi 5
    hai la partizione Dati criptata
    ci son mille discussioni a riguardo dove vengono suggerite le password e le soluzioni più improbabili
    non funziona nessuna.
    l'unica è fare un Format Data:
    ATTENZIONE che naturalmente perdi tutti i dati!!
