Pagina 88 di 124 primaprima ... 3878868788899098 ... ultimoultimo
Visualizzazione dei risultati da 871 a 880 su 1237
[MODDING] Zopo zp910 Thread ufficiale discussioni e tutto cio' che serve al modding
  1. #871
    Androidiano L'avatar di ivanpiffer
    Segnalo la nuova ROM degli spagnoli "Demandroid Kit Kat 4.2.1 v1.1" .
    Io non l'ho ancora provata...c'e' qualcuno che l'ha fatto?
    features:
    Visual style similar to Kit Kat system.
    Keyboard , gallery , camera, calendar, launcher with Voice Recognition and now google , hangouts , fonts , tones, settings and phone icons and wallpapers (only google home launcher ) from Kit Kat.
    Based on Official version 4.2.1 zopo June.
    Deodexada .
    Zipaligned .
    Rooteada .
    Supports init.d
    Busybox .
    Bravia Engine 2 .
    Tweaks picture and video quality .
    3g Speed ​​Tweaks .
    Tweaks speed web browsing.
    Tweaks camera flash .
    Tweaks video streaming.
    Battery saving tweaks in wifi.
    Spanish Language by default.
    All times changed Europe / Brussels
    Changed region to Spain .
    Added access to engineer mode from development options .
    Contacts Holo Dark style .
    Transparent notifications curtain .
    Enabled horizontal lockscreen .
    Lockscreen clock centered.
    Added support multiple users.
    Restart option in the shutdown menu translated into Spanish .
    Animation screen off CRT OFF.
    Removed some applications zopo .
    Added Root Explorer apps , Whatsapp and Youtube .
    Added new notification tones .
    New boot animation .
    No sound on startup.
    Original wallpapers added AOSP 4.2.
    Sun Beam Live Wallpaper from google edition (Phase Beam red ) .
    Removed animated backgrounds , bubbles and spiral.
    Notification bar with speed meter and clock on the left by default.
    Applications with Zipalign every boot.
    Changelog Updated v1.1
    Fixed bug that prevented use widget Play Music on the lock screen .
    Popups style kit kat. I mean the popups that appear when you put the alarm as you indicate lack to sound or when an application gives you superuser permissions .
    Watch modified to look a little further kit kat , hours are no longer displayed in bold , including widget , and other changes.
    http://ivanpiffer.weebly.com/
    - Sony Xperia M2
    - Meizu M2 Note
    - Maze Alpha
    - Vernee Mars Pro
    - Kobo Glo HD
    - Teclast X10 3G
    - Onda Obook11
    - Hp Elitebook
    Pisa
    Xiaomi Mi5S
    Qualcuno può dirmi la procedura di installazione della classic dimid? Si va di flashtool o di recovery?? grazie a chi mi aiuterà
    Xiaomi Mi5S : S P E T T A C O L A R E
  4. #873
    ZP910
    Vai di recovery
  5. Il seguente Utente ha ringraziato pakyred per il post:
    damianos (27-11-13)
  6. #874
    Ringraziato 98 volte in 76 Posts
    aggiunta la kit kat spagnola al main thread
    ma qualcuno ha provato le ultime release miui per caso? io sono fermo all'ultimo porting fatto da stalingrad
  7. Il seguente Utente ha ringraziato phoenix530 per il post:
    ivanpiffer (28-11-13)
  8. #875
    Ho provato la miui 3.11.15 A me sembra buona anche se non ho mai utilizzato la miui in precedenza, solo Dimid. Mi sembra fluida da profano.
    Inviato dal mio JY-G3 usando Androidiani App
  9. #876
    raga si hanno novita' in merito al trasporto di app sulla memoria sd e il launcher che sballa? la mia speranza e' sempre che fixino sta cosa con le nuove versioni....io sto quasi per esaurire la memoria interna, mi restano 180 mega xD
  10. #877
    Ma qual'è il parametro che azzera tutte le impostazioni ad ogni riavvio? È snervante ogni volta selezionare : metodo di immissione, launcher predefinito, app per la musica, video, ecc. Ecc. :banghead:
  11. #878
    dimid ha rilasciato da poco colorOS 1.0... non so di preciso da cosa si differenzi dalla classic rom dal momento che non scrive nulla a riguardo...comunque sia eccovi il link se qualcuno volesse provarlo: https://disk.yandex.com/public/?hash...iNpSis/rGCo%3D
  12. #879
    Ringraziato 27 volte in 20 Posts
    Quote Originariamente inviato da phoenix530 Visualizza il messaggio
    Oggi l'ho provata e devo dire che se non fossi pazzamente innamorato della MIUI lo potrei diventare di questa rom ...
    E' un porting fatto dall'Oppo R819 in italiano che promette molto bene ... il 3G funziona su entrambe le sim ... non ha molte app di sistema ma sono molto ben fatte.
    Tutto il sistema è un pò un mix tra Lewa e Miui come parte grafica e concezione di sicurezza/sistema ...
    Nessun difetto ...
    Una rom da tenere sicuramente sotto controllo per il futuro. Unica cosa negativa come sempre delle rom russe ... non si sa se verrà supportata in futuro e con che frequenza ci saranno gli aggiornamenti.
  13. #880
    Mix tra lewa e miui? Sti ibridi mi lasciano sempre un po' scettico xD tu hai aggiornato la miui alle versioni recenti? Io mi sa che di sto passo la dovro' abbandonare....mi sono rimasti 180 mb liberi sulla memoria interna per le app...se non implementano la gestione su sd sara' un bel problema per me coninuare ad usare la miui....cmq ho notato che ogni tanto il sensore di luminosita' si impalla. Ho ancora la isomin fatta da te. Dopo il casino dell'ultima volta non ho piu installato altri porting russi della miui
    Inviato dal mio ZP900H usando Androidiani App
