Pagina 19 di 42 primaprima ... 9171819202129 ... ultimoultimo
Visualizzazione dei risultati da 181 a 190 su 416
[ZOPO 980/990/C2/C7][WIP]ROM CM11 KK 4.4.3 (unofficial)
  1. #181
    Jul 2014
    Hi, Paolo! I’m happy to welcome you on behalf of branch ZP980/C2/C3 forum.china-iphone
    I’d like to thank you for ROM CyanogenMod 11 and kernel 4.4 you shared with us.
    We use your ROM eagerly.
    We have some ideas and suggestions for you.
    The idea is as follows:
    - The person compiling Boot.img could easily compile a new UBoot(lk.bin) .
    The following would need corrections:
    1. The possibility to enter Recovery with phone being switched off and power cable disconnected.
    2. Expanding section Recovery and use of the complete full-function Recovery, the aforesaid is applicable to TWRP 2.5.0 as well as to TWRP 2.7.1 but currently you cut a lot thereof!
    3. Getting multiboot feature, i.e., the possibility to choose out of the two ROMs installed to be run during booting.
    On our part, we are ready to create related files ( scatter.txt , MBR , EBR1 , EBR2 ) for the change of section sizes in order to use the full Recovery and MultiBoot.
    UPD. MultiBoot is a rather complicated issue and the idea could be postponed for further implementation.
    We suggest at least the first two items should realized.
    We have people able to compile boot.img and lk.bin themselves but no sources are available.
    Best regards & thanking you in advance.
  2. Il seguente Utente ha ringraziato arkadiy68 per il post:
    gigiesse (05-07-14)
    zopo has not released the kernel sources
    I have compiled a compatible kernel using sources of other phones (a mix of iocean and Jiayu) but I do not have the sources for the uboot
    so...no lk source, no uboot
    Nubia Z7MAX
  5. #183
    Nox
    Nox non è in linea
    Baby Droid L'avatar di Nox
    Sep 2013
    Newcastle upon Tyne
    Galaxy Note 4 / Lenovo K3 Note
    Paolo ma è possibile che il doppio tap a schermo spento faccia riavviare il telefono col kernel 7.1? Mi è capitato un paio di volte già...
  6. #184
    Quote Originariamente inviato da Nox Visualizza il messaggio
    sulla cm11 ?
    sulla cm11 non l'ho provato...può essere anche se è molto strano
    dovresti provare a disabilitare il pocket detect (l'ho scritto nella discussione del kernel come fare) per vedere se lo fa ancora
    Nubia Z7MAX
  7. #185
    Nox
    Nox non è in linea
    Sep 2013
    Newcastle upon Tyne
    Allora disabilitando il pocket detect e facendo molteplici prove sia con lo swipe che col doppio tap, il telefono non si riavvia, quindi direi risolto!
  8. #186
    umh...però non dovrebbe farlo
    è sicuramente dipendente dal sensore di prossimità...magari sulla cm11 viene usato in modo strano
    vediamo se altri con altre rom hanno lo stesso problema oppure no
    Nubia Z7MAX
  9. #187
    Nov 2013
    Ringraziato 21 volte in 21 Posts
    E' uscita una nuova versione della CM11 del wiko .... Vai Paolo
  10. #188
    Quote Originariamente inviato da Almerino Visualizza il messaggio
    vero, però niente di interessante come changelog
    e in più non c'è ancora il file da scaricare
    Nubia Z7MAX
  11. #189
    io la 0.10 non riesco ancora a scaricarla...
    dice sempre "The file you requested was not found" come ieri sera
    Nubia Z7MAX
  12. #190
    Nov 2013
    A m'è mi fa questo scherzetto:
    -telefono spento
    -metto in carica
    -il telefono si accende senza nessuna connessione dati
    -tolgo il cavo e si spegne
    Capita solo a m'è ?
