Pagina 17 di 51 primaprima ... 7151617181927 ... ultimoultimo
Visualizzazione dei risultati da 161 a 170 su 505
[Guida] Rom Froyo per Motorola Milestone
  1. #161
    May 2010
    Re: froyo per milestone
    Quanto notevole l'aumento della batteria? Dexter mica ha detto a quando il prossimo update?
    Sent from my Milestone using Tapatalk
    Androidiano L'avatar di Azhad
    Jun 2010
    Ringraziato 54 volte in 41 Posts
    Quote Originariamente inviato da Emanuele3000 Visualizza il messaggio
    Direi un 40%
    Dexter aveva un update pronto ieri, ma gli si è corrotto il backup nandroid qundi lo stà rifacendo da capo.
    1. CAMERA - WORK IN PROGRESS, not working at the moment. We have a couple of people looking into it, all attempts so far have failed - STATUS RED, biggest issue at the moment
    2. Notifications LED doesnt work - WORK IN PROGRESS. We fixed it for SMS (workaround below), but cannot fix it for the other notifications due to the FRF91 image which supports the nexus' trackball. Once we use a different build (FRF84 or FRG01), they work again, BUT!! this will limit the languages to English and Spanish. Since there are aftermarket apps out there (MIssed Call etc), this is nothing we can fix without giving up the multi-language support. So the issue will most likely remain.
    Status CLOSED (for now), workaround exists
    3. Wifi Tethering: Found workaround, will be included in next fix.
    STATUS GREEN
    4. Music Apk. New image will contain new Music with Gestures support from start.
    STATUS GREEN
    5. Missing icons in lockscreen bars: Will be fixed, work in progress:
    STATUS ORANGE ( high likelyhood of FIX)
    6. Apps2sd and Memhack:
    Native support from Kernel not possible, will be possible with -fufu-s workaround. He is looking into it.
    STATUS ORANGE (high likelyhood of FIX)
    Ovviamente il wifi tethering e il memhack lo potete fixare da subito con il mio script (link in prima pagina)
  4. #163
    Androidiano VIP L'avatar di danilos2k
    Jul 2009
    Ringraziato 91 volte in 76 Posts
    Quote Originariamente inviato da Azhad Visualizza il messaggio
    https://www.androidiani.com/forum/mo...tml#post158043
    in quel post ho linkato una modifica alla rom di Thyrus, confermo un marcato miglioramento nel consumo della batteria.
    posso farlo avendo il backup di iaio72 ?
  5. #164
    Jun 2010
    Quote Originariamente inviato da danilos2k Visualizza il messaggio
    Se hai la barra delle notifiche nera (quindi la rom internazionale di Thyrus) si.
  6. #165
    Jul 2009
    NERISSIMA come il carbone !!!
  7. #166
    May 2010
    Ma rispetto alla 2.1 la batteria diminuisce di molto? O il 40% rispetto alla 2.1? Quindi per ora per la camera e er le notifiche led siamo ancora a 0 ma per il resto c'e quasi tutto? Ma per la camera non si vedono per ora soluzioni o non ci saranno mai?
  8. #167
    Androidiano VIP L'avatar di iaio72
    Jul 2009
    Ringraziato 618 volte in 346 Posts
    Quote Originariamente inviato da emanuele3000 Visualizza il messaggio
    ma rispetto alla 2.1 la batteria diminuisce di molto? O il 40% rispetto alla 2.1? Quindi per ora per la camera e er le notifiche led siamo ancora a 0 ma per il resto c'e quasi tutto? Ma per la camera non si vedono per ora soluzioni o non ci saranno mai?
    Sent from my milestone using tapatalk
    work in progress
    OnePlus 3T
    Meizu Mx6
  9. #168
    Mar 2010
    Ciao a tutti!
    Ireri sera ho provato di mettere la ROM completa con queste caratteristiche -overclock 1000 vsel56
    memhack della delvik
    multilingua
    barra di stato nera( come nello screen qui sotto)
    wifi tethering
    L'ho scaricata nella prima pagina...l'installazione è andata tutta bene ma ho avuto 2 problemi:
    1)il principale è il consumo ECCESSIVO di batteria...circa il 10% ogni mezzora stando in stanby!!
    2)facendo test con linpack mi dava risultati a caso del tipo prima 5 poi 7 poi 13 e poi di nuovo 5...bha...
    Qualcuno mi puo aiutare?? soprattutto con il problema della batteria!
    Grazie!!
  10. #169
    Jun 2010
    Quote Originariamente inviato da cant92 Visualizza il messaggio
    Ciao a tutti!
    Grazie!!
    Consumo decisamente esagerato, ed a giudicare dal test linpack penso che il problema sia questo:
    Hai per caso fatto un restore con titanium backup o simili?
    Facendo il restore dei dati di alcune applicazioni di sistema, tipo sms, gmail e simili, android impazzisce ed alcuni processi vanno a 98% della cpu in pianta stabile (controlla con OSMonitor), in questo caso reinstalla la rom e fai il restore solo delle applicazioni utente
  11. #170
    Mar 2010
    Facendo il restore dei dati di alcune applicazioni di sistema, tipo sms gmail e simili, android impazzisce ed alcuni processi vanno a 98% della cpu in pianta stabile (controlla con OSMonitor), in questo casi reinstalla la rom e fai il restore solo delle applicazioni utente
    Si ho fatto il backup con mybackup pro!
    Però dopo aver notato questo eccessivo consumo ho fatto un altro wipe e ho ripetuto tutta la procedura senza però fare il backup...e la batteria scendeva velocissima comunque...
    Per quanto riguarda il restore...cosa sono le applicazioni utente??
    Grazie ancora!
