Pagina 68 di 155 primaprima ... 1858666768697078118 ... ultimoultimo
Visualizzazione dei risultati da 671 a 680 su 1547
[ROM]JB 4.1.1 UMTS_EVEREST MZ601 Nightly
  1. #671
    leoeL
    La 100 modifica un po' di cose a livello radio (3g) e WiFi.
    P.S. che commento tecnico che ho fatto.
    Si passa pure a 4.1.1 r4
    Ultima modifica di leoeL; 08-08-12 alle 16:37
    Banned
    In Download... siamo al giro 100
    Build #100 (8-ago-2012 5.36.45)
    Prodotti della Build
    EOS-umts_everest-20120808-100.zip 112.68 MB
    Changes
    Merge tag 'android-4.1.1_r4' into aosp-4.1.1_r4
    Android 4.1.1 release 4
    -- Chris Trotman / detail
    tf101: Bring in vendor proprietary files from 9.2.1.27
    Change-Id: I5b3cdba344a9473ab7c8e28d82ee3b5519d2798c
    -- Donald Munn / detail
    Update to Stingray (MZ602) JB build fingerprints
    This is from a leaked build on XDA; subject to change
    Change-Id: I46043b7903b4908601896f141b09e88dd1b7470d
    -- Kenneth R. Crudup / detail
    Fix NPE on some phones at startup.
    Bug: 6877589
    Change-Id: I65ff37b4cf6b59a72a7aa665f252f5fb34f3b183
    -- Daniel Sandler / detail
    Fix 6804479: "Emergency calls only" in notification shade
    Add an additional codepath to the "no connectivity" logic in
    NetworkController to allow the PLMN bubble up from the
    GsmServiceStateTracker, where R.string.emergency_calls_only
    is returned if we're in emergency call mode.
    Bug: 6804479
    Change-Id: I0a77261e4393cc0dc32bae3e631ef196b2342f06
    Implement CMAS service category program results.
    Correctly handle CDMA Service Category Program Data requests,
    and send the SCPT response to the message center. Parcel SCPD
    operations as an ArrayList instead of an array (current version
    will throw ClassCastException when the array is cast).
    Bug: 6853691
    Change-Id: I949ea68891c78306059248832e59a593ab606e11
    -- Jake Hamby / detail
    Fix detection of CDMA cell broadcast messages.
    The bIsServicePresent field of an incoming CDMA SMS RIL message
    is not a reliable way to distinguish broadcast from point-to-point
    messages on some RILs. Change CDMA SmsMessage.getMessageType() to
    return MESSAGE_TYPE_BROADCAST when the service category is not 0,
    and MESSAGE_TYPE_POINT_TO_POINT when the service category is 0.
    Bug: 6853691
    Change-Id: I0d44a8ce0bb295da5125271db90652570d655bc1
    Fix our interpretation of apn setting's bearer.
    Between ICS and JB we changed it to use TelephonyManager's network type
    enumeration. This changes it back to represent the RIL's radio
    technology. The only diff between the two is 13 and 14 are swapped,
    so the change was causing problems with LTE and eHRPD.
    bug:6830908
    Change-Id: I85a7c8037f370f368e5cbf6dc2c9395c6889b541
    -- Robert Greenwalt / detail
    Persistant menu key for legacy apps (1 of 2)
    Change-Id: Ib74fb11e93752034553c1b9ef10fe67ed2ea7cb4
    -- Randall Rushing / detail
    tf101: config: change debug level and a few other things
    Change-Id: I48a7a1431c31fb66fd8439ce5732c129adf9ecc6
    Toro: Update USB gadget for DM feature
    1. Add RNDIS+DM composite for modem logging
    Change-Id: I21cd2809a9ffc48900e7fa188ff8cc471fffa301
    Signed-off-by: Benoit Goby <benoit@android.com>
    Signed-off-by: sujin119.kim <sujin119.kim@samsung.com>
    -- sujin119.kim / detail
    Persistent Menu Key for legacy apps (2 of 2)
    Change-Id: Idb66f3852ee362fc3c980e4dbaf4d27c91ebfb26
    Add option to change wifi regulatory domain
    Change-Id: I0e90cd1d9359dbdf371a4e2d78c22eacff8ff4eb
    JRO03L
    Change-Id: Id7ed9c1471c4986daa0598b74f8306d00b9cf18b
    Update to MZ602 VZW JRO03H
    Change-Id: I4ba6726781805f5c77b4aeb9057238dd442726c3
  4. #673
    Androidiano L'avatar di RUGGI
    Galaxy SIII, Motorola Xoom JBL
    Ringraziato 15 volte in 11 Posts
    Allora io stò continuando a flashare e poi mi tocca reistallare tutte le app.....qunalcuno mi aveva spiegato come fare il backup sul dispositivo e ho controllato ed è ancora come prima come posso fare per nn reistallare a mano tutto??? qualcuno mi aveva parlato di Titanium ma con il free....devo farlo una per una
  5. #674
    Banned
    Se flashi la rom di upgrade che operazioni fai ? per caso sempre i 3 wipe? o solo dalvik cache ?
  6. #675
    Io tre wipe e resinstallo rom e gaps...sbagli qualche cosa????
  7. #676
    Banned
    Quote Originariamente inviato da RUGGI Visualizza il messaggio
    Se leggi la prima pagina c'è:
    Note Installazione :
    Fare un wipe completo se si proviene da ROM differente e/o versione stock originale .
    Fare solo wipe dalvik cache se solo update della stessa ROM del Team Eos .
    Su info ora c'è:
    JRO03L
  8. #677
    Senior Droid L'avatar di robyroby
    Jul 2010
    Galaxy A7-2018
    Su info ora c'è:
    JRO03L
    Quindi questa e' la prima rom con info = a quella rilasciata ufficiale??
  9. #678
    Mar 2011
    Ringraziato 17 volte in 11 Posts
    Ma la 98 e le 99 hanno il touch reattivo secondo voi?
    Io a volte pigio pigio ma non lo prende...e prima non mi è mai successo.
  10. #679
    Androidiano L'avatar di bobster
    Spero di non tornare su un tema già trattato,
    nelle impostazioni non mi riesce di decidere come meglio
    settare il Governor, la CPU adesso la tengo a 1408 / 312 MHz
    ma ho dubbi sul governor.
    Vorrei un equilibrio tra performance e risparmio.
  11. #680
    leoeL
    Inizialmente usavo lagfree ma aveva una cosa che non mi piaceva.
    Per esempio, se stava a 1600 e poi xoom poteva riposarsi, prima di arrivare a 216 si faceva 2 minuti di ogni frequenza intermedia. Sprecando un sacco di batteria.
    Da un po' sta su interactive e non mi lamento.
