Pagina 97 di 155 primaprima ... 47879596979899107147 ... ultimoultimo
Visualizzazione dei risultati da 961 a 970 su 1547
[ROM]JB 4.1.1 UMTS_EVEREST MZ601 Nightly
  1. #961
    Banned
    Valerio.. per ringraziare usa il tasto Thanks
    Bene .. vedo che stai prendendo dimestichezza, rispetto a ICS Stock , confermi le migliorie trovate?
    Androidiano L'avatar di GenX
    Airola (BN)
    Galaxy Nexus - Htc Desire
    Uscita la #109
    [CyanogenMod 10.1 Nightly JB 4.2.1]
  4. #963
    Banned
    Alleluja.. in sordina e senza dire nulla... ho visto solo per la serie Xoom
    EOS-umts_everest-20120826
    Changes
    Consolidate New SystemUI Actions
    Patch Set 2:
    - Move Heavy Tasks Handling To EosUtilities
    Patch Set 3:
    - Revert PS2
    - Move Tasks To ActionHandler
    Patch Set 4:
    - Modify EOSConstants
    Patch Set 5:
    - Properly implement ActionHandler
    Patch Set 6:
    - Keep Home button object from initializing in
    EosUiController. It was firing an extra haptic
    feedback.
    Patch Set 7:
    - Removed a couple more static keywords
    Change-Id: I89ca75a16699e4ec33d869626317593d05a56c83
    -- kevdliu / detail
    arm: config: stingray_defconfig revert back to Eos branding.
    Change-Id: I81a4bb7050b806f7e9135780ac3201fd20a20f56
    -- Chris Trotman / detail
    usb: gadget: Don't mess with the AHB Bus Clock
    This essentially reverts the part of f9ba61413 ("usb: gadget:
    Gadget USB optimization") that "Set[s the] AHB bus clock to
    240Mhz when USB1 gadget is enabled.". Turns out that we don't
    need to do this anyway as our OC efforts bump the AHB to 300MHz,
    plus on some Xooms just doing clk_get("sclk") hang their
    devices. We leave in the "STREAM DISABLE" part of the
    optimization, however (per the Tegra2 TRM: "helpful to avoid
    overrun/underruns with the system load is too high").
    Change-Id: Iac47af27225dfd2f130b7d9835a0f6f2e07028ed
    -- Kazuhiro Ondo / detail
    arm: switch to softfp if supported
    Change-Id: I825eea1876d770c4f6aa354edd8313844ae680b0
    -- Kenneth R. Crudup / detail
    arm: tegra: stingray: make CONFIG_LOCALVERION more like EOS
    Change-Id: I236940925dc7fb6d0e3c1637d9c8f527a876bc2d
    net: wireless: bcmdhd: Remove WIPHY_FLAG_SUPPORTS_FW_ROAM flag
    If driver advertises FW_ROAM, the supplicant wouldn't send
    the BSSID & Freq in the connect command allowing the driver
    to choose the AP to connect to. But unless we support ROAM_CACHE
    in firware this will delay the ASSOC as the FW need to do a full
    scan before attempting to connect.
    Change-Id: Iebc88a60243196b9ad27b8302f2b1473710308f6
    Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
    -- Dmitry Shmidt / detail
    Consolidate code from recent new Settings features
    Patch Set 2:
    Patch Set 3:
    - Create Abstract class for handling action
    selections
    Change-Id: I811672d7cb5db3278ba30bae6dca4867b08027a5
    -- Randall Rushing / detail
  5. #964
    Confermo, e molto fluido e rapido rispetto ics
    Inviato dal mio MZ601 usando Androidiani App
  6. #965
    La 109 va che e' una bellezza
    Inviato dal mio Xoom usando Androidiani App
  7. #966
    E uscita la 109??
  8. #967
    Praga qualcuno mi può spiegare a cosa serve aumentare e diminuire i valori dell over clocking
  9. #968
    Androidiano VIP L'avatar di birrez
    savona
    galaxy s2
    Ringraziato 344 volte in 275 Posts
    Quote Originariamente inviato da valerio93 Visualizza il messaggio
    Aumentare la fraquenza del processore rende il tablet più prestazionale e fluido a descapito magari della batteria
    Ti consiglio di non esagerare far comunque lavorare troppo il processore lo rende meno durevole
    inviato dal mio xoom jelly beannato
  10. #969
    Adesso sono a 312/1408 MHz mi consigliate di aumentare? ROM 108.
  11. #970
    Banned
    Ti consiglio per ora solo aggiornare alla #109 , stai con quei valori.. vanno bene.
