Pagina 59 di 70 primaprima ... 949575859606169 ... ultimoultimo
Visualizzazione dei risultati da 581 a 590 su 691
[Official] Nubia Z7
  1. #581
    Senior Droid L'avatar di REDHOOK7
    Feb 2014
    Note4/Jiayu/Allview X2 xtreme
    Ringraziato 376 volte in 280 Posts
    Quote Originariamente inviato da manuelb Visualizza il messaggio
    2G NetworkGSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
    3G NetworkHSDPA 850 / 900 / 1900 / 2100
    4G NetworkLTE 1800 / 2100 / 2600
    SIMDual SIM (Micro-SIM, dual stand-by)
    Announced2014, July
    StatusAvailable. Released 2014, July
    BODY
    Dimensions152.7 x 76 x 8.7 mm (6.01 x 2.99 x 0.34 in)
    Weight160 g (5.64 oz)
    DISPLAY
    TypeCapacitive touchscreen, 16M colors
    Size1080 x 1920 pixels, 5.5 inches (~403 ppi pixel density)
    MultitouchYes
    *- Nubia UI 2.0
    SOUND
    Alert typesVibration; MP3, WAV ringtones
    LoudspeakerYes
    3.5mm jackYes
    MEMORY
    Card slotmicroSD, up to 64 GB
    Internal32 GB, 2 GB RAM
    DATA
    GPRSYes
    EDGEYes
    SpeedHSDPA, HSUPA, LTE
    WLANWi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, DLNA, Wi-Fi hotspot
    Bluetoothv4.0, A2DP
    Infrared portYes
    USBmicroUSB v2.0
    CAMERA
    Primary13 MP, 4128 x 3096 pixels, autofocus, LED flash
    FeaturesGeo-tagging, touch focus, face detection, panorama, HDR
    Video2160p@30fps, 1080p@30fps
    Secondary5 MP, 1080p@30fps
    FEATURES
    OSAndroid OS, v4.4.2 (KitKat)
    ChipsetQualcomm MSM8974AC Snapdragon 801
    CPUQuad-core 2.5 GHz Krait 400
    GPUAdreno 330
    SensorsAccelerometer, gyro, proximity, compass
    MessagingSMS(threaded view), MMS, Email, Push Email, IM
    BrowserHTML5
    RadioFM radio
    GPSYes, with A-GPS, GLONASS
    JavaYes, via Java MIDP emulator
    ColorsBlack, White
    *- Active noise cancellation with dedicated mic
    - SNS applications
    - MP4/DviX/XviD/H.264/H.263/WMV player
    - MP3/WAV/FLAC/eAAC+/WMA player
    - Photo viewer/editor
    - Document viewer
    - Organizer
    - Voice memo/dial/commands
    - Predictive text input
    BATTERY
    *Li-Ion 3100 mAh battery
    Stand-by (2G) / Up to 720 h (3G)
    Talk time (2G) / Up to 40 h (3G)
    Inviato dal mio iOCEAN X7 usando Androidiani App
    All'inizio di questo thread, avevamo postato tutte le caratteristiche dei tre modelli Z7 Z7max Z7mini con relative funzioni bande di rete ecc.. "raimondomartire" quindi per quanti continuano a chiedere ( ma ha questo? ma fa quello?) ci sono info di specifiche su etotalk, tanto per citarne uno, e le varie prove eseguite dagli utenti... basta leggere le pagine indietro...
    ... basta un Thanks!
  2. Il seguente Utente ha ringraziato REDHOOK7 per il post:
    francj67 (17-09-14)
    Androidiano VIP L'avatar di manuelb
    Honor 6 Plus/Opo/Asus tf300t
    Ringraziato 670 volte in 497 Posts
    Volevo sapere un altra info. I video in rallenty niente ???
  5. #583
    Qui http://forums.hardwarezone.com.sg/an...702526-11.html ci sn un pò di foto ch rendono l'idea della qualita del display e dello smartphone in se stesso.
  6. #584
    Aug 2014
    Salve ragazzi, ho un problema sul mio ZTE NUBIA X7 Max. Inserendo le due sim (Wind e Tim) nelle slot me ne legge solo una. Ho provato a cambiare il posizionamento delle sim nelle slot ed il problema persiste, sia che essa sia Tim o Wind. Me ne legge solo una. La cosa strana che appena acquistato mi ha letto entrambe le Sim. Ho smanettato qualcosa che non avrei dovuto toccare? Grazie per l'aiuto.
  7. #585
    Sep 2013
    Ringraziato 46 volte in 40 Posts
    Quote Originariamente inviato da supersabre Visualizza il messaggio
    Potresti aver disattivato uno slot? Prova ad andare su "impostazioni" > "impostazioni Msim" > e vedi se entrambi gli "switch" delle sim sono attivi.
  8. #586
    Aug 2014
    Quote Originariamente inviato da Kyvanes Visualizza il messaggio
    Ciao, vado su mpostazioni ma non trovo "impostazioni Msim. Dove è?
  9. #587
    Sep 2013
  10. #588
    Ciao a tutti, mi é arrivato ieri il max, bello bello... dovró solo abituarmi ai 5,5 pollici... per ora credo lo terró in inglese, sempre se non tarderá troppo l'aggiornamento multilingua della zte...
    ho un piccolo dubbio, ieri come l'ho acceso ho visto che c'era un aggiornamento, alla 1.38 se non erro.. io ho la 1.29 (con playstore e credo rootato), l'ho scaricato e, dopo averlo caricato come consigliava con un messaggio, ho fatto il reboot per aggiornarlo, ma in realta mi ha dato error l'aggiornamento e mi é rimasta la 1.29... qualcuno ha consigli da darmi?? grazie
  11. #589
    Androidiano L'avatar di MARCOTNT
    Jul 2014
    Tra Carrara e Ferrara
    Nubia Z7 Max
    Ringraziato 36 volte in 31 Posts
    Gli aggiornamenti OTA non funzionano. Devi scaricare la ROM e fare il flash l'ultima versione è la 1.41
    Se sono stato utile...non dimenticare il "THANKS"..
  12. #590
    Una domanda nubia z7 max supporta le microsd di 128 gb ?????
