Visualizza i risultati del sondaggio: Quale ROM per z7 Max ti soddisfa di più?
Chi ha votato
74. Non puoi votare questo sondaggio
  • STOCK Nubia UI
    5 6.76%
  • Mod By BB72 "Phablet Experience"
    46 62.16%
  • Mod By BB72 "Phone Experience"
    16 21.62%
  • CM11/MOKEE
    2 2.70%
  • Altro....
    5 6.76%
Pagina 405 di 429 primaprima ... 305355395403404405406407415 ... ultimoultimo
Visualizzazione dei risultati da 4,041 a 4,050 su 4286
[ROM][KK 4.4.x] Stock modded by BB72 per Nubia Z7 Max | Basata su 1.62 [NX505J]
  1. #4041
    Sep 2014
    Grazie per le risposte che metterò subito in pratica e vi farò sapere
    Oct 2014
    Ringraziato 16 volte in 12 Posts
    I did the partitioning with method I do not suggest....instead this thread reports others experiences.
    You can focus on post #84, post #119 (in case you miss BT and WIFI after the repartition) and post #121 with detailed steps....
    Be aware that the pocedure is risky.....
    Hi BB72,
    Following steps i made for repartition for Z7 max
    As per instruction on post #84, i have made partition but in the second step it stuck in boot image chinese (I didn't get any message 'encription failed') then i press Volume down and power button to enter into recovery.
    I made data wipe, cache wipe and dalvice wipe and then i restore the Nandroid backup of BB1.64 rom which i used previously.
    After that i reboot the phone and stuck in again the boot image (Phone not go inside)
    Then i installed the official 1.59, Now phone is on and partition size increased, still facing problem in wifi and Bt.
    I put phone in recovery and when i click wifi.bat got error message phone not found, but when i go for mount USB storage phone in detected in CWM recovery.
    the Post of #119 link is broken, so i am unable to download.
    Please help me to restore wifi and BT and other help need sometime phone is off automatically every 10 mins once.
    Thanks in advance.
  4. #4043
    Nel thread per il partizionamento mastercut aveva postato uno zip da flashare direttamente da recovery per ripristinare WiFi e BT persi dopo partizionamento... Il link non è più attivo.... Qualcuno che l'ha scaricato può condividerlo appena possibile?... Grazie mille
    Inviato dal mio LG-D858HK usando Androidiani App
  5. Il seguente Utente ha ringraziato BB72 per il post:
    francj67 (02-04-15)
  6. #4044
    Oct 2014
    Hi BB72,
    I am looking for the same, post 119 link is not active so i am unable to download.
    Guys, if anyone have please share the wifi and BT recovery zip file flash in CWM....
  7. #4045
    Quote Originariamente inviato da niza2000in Visualizza il messaggio
    Hi BB72,
    Found it.... it should work on z7 max as well...l'm sure
    https://mega.co.nz/#!8gVlhAzB!mDrHX2...JDtPQ4721BUO78
  8. I seguenti 2 Utenti hanno ringraziato BB72 per il post:
    francj67 (02-04-15),niza2000in (02-04-15)
  9. #4046
    Oct 2014
    Hi BB72,
    You are so helpful man....Thank you very much for the support......
    You are really put effort like problem in own device....Hats off to you.... I am Happy now...My device is back.....once again 100 thanks...........
  10. Il seguente Utente ha ringraziato niza2000in per il post:
    BB72 (02-04-15)
  11. #4047
    Hi BB72,
    GREAT.... enjoy... ;0)...
  12. #4048
    Nov 2014
    qualcuno sa quali saranno i miglioramenti che apporterà la versione ufficiale di lollipop per nubia z7 max? inoltre nella beta prerilasciata in che cosa si distingue da kitkat ?
  13. #4049
    [quote name="olexandr" post=6738606]qualcuno sa quali saranno i miglioramenti che apporterà la versione ufficiale di lollipop per nubia z7 max? inoltre nella beta prerilasciata in che cosa si distingue da kitkat ?[/QUOTE]
    Che una è KK e l'altra è Lollipop....:0)....a parte gli scherzi....camera con interfaccia diversa...stile notifiche diverso (Lollipop) qualche diversità grafica.... e partizione unica
  14. #4050
    Senior Droid L'avatar di PIGTWO
    Jul 2014
    Meizu M1 Note Blue 32g
    Ringraziato 42 volte in 38 Posts
    Ciao tutti ragazzi, in particolare a BB72.
    Mi è tornato il max nuovo dalla cina stamattina (mandato indietro a fine dicembre 2014)...
    Avevo perso la speranza, tanto è vero che ho un meizu m1 note da paio di settimane.
    Lo so che non si dovrebbe fare ma vi chiedo un aiuto (e se puoi darmelo tu bb ancora meglio). Non ho più seguito da un certo punto in poi le evoluzioni della ROM, per cui avrei bisogno di una mini guida veloce su cosa installare per essere aggiornato all'ultimo grido
    Grazie!!!!
