Pagina 44 di 130 primaprima ... 3442434445465494 ... ultimoultimo
Visualizzazione dei risultati da 431 a 440 su 1298
[ROM LOLLIPOP Android 5 Mod By BB72 & Cuoco92] ZTE Nubia Z7 Max |COMBO ROM|
  1. #431
    Oct 2014
    Ringraziato 16 volte in 12 Posts
    I tried extracting from this tool - Ext4 Unpacker
    After selecting the file, not responding and tool got closed.
    Please share the apk file or please provide the steps to modify contactsprovider.apk.
    Thanks in advance..
    Oct 2014
    Finally extract from the system.img, Thanks for the support...
  4. Il seguente Utente ha ringraziato niza2000in per il post:
    BB72 (07-05-15)
  5. #433
    Oct 2014
    Quote Originariamente inviato da niza2000in Visualizza il messaggio
    Hi,
    I extract contactsProvider.apk from the combo beta1 and replace file in system - pvt app and reboot done.
    But still its showing stock format. What other thing need to done. Please dont mistake me, your are the great developer so i am seeking your help.
    Thanks in advance.
  6. #434
    [quote name="niza2000in" post=6826172]Finally extract from the system.img, Thanks for the support...
    Hi,
    Thanks in advance.[/QUOTE]
    You are my nightmare :0)....you have to cancel data for the contact storage (or something similar) app into settings/app....please do not ask me further details since I do not have z7 phone with me....
    Inviato dal mio LG-D858HK usando Androidiani App
  7. Il seguente Utente ha ringraziato BB72 per il post:
    niza2000in (07-05-15)
  8. #435
    Oct 2014
    Hi,
    Thanks in advance.
    Inviato dal mio LG-D858HK usando Androidiani App[/QUOTE]
    Hey you the real supportive guy...Even you got tensed but you provided the solution...
    That's why people like me disturbing BB ....
    Finally done..All working..... Thanks for the continuous support...
  9. #436
    [quote name="BB72" post=6826327]Hi,
    Thanks in advance.
    Finally done..All working..... Thanks for the continuous support...[/QUOTE]
    ;0))))))...…
  10. #437
    Permettemi questo OT....sconvolgente.... https://www.youtube.com/watch?v=b6sL_5Wgvrg
  11. I seguenti 4 Utenti hanno ringraziato BB72 per il post:
    bytezx (08-05-15),francj67 (08-05-15),genge (08-05-15),mrgiaco (08-05-15)
  12. #438
    Androidiano VIP L'avatar di pesa1234
    Nubia Z11 MAX - Z7Max
    Ringraziato 1,530 volte in 848 Posts
    Con la combo beta 1 non é possibile salvare i contatti nella rubrica exchange... Ma solo su google o locale... Con la ROM originale é invece possibile...
    Nubia Z7 Max - Z11 Max...
  13. #439
    .....Ho fatto la scelta di togliere il client Nubia mail stock (oltre al fatto che a me non piace ma anche perchè non è in italiano) e di:
    1. Mettere il client Android stock per IMAP/POP
    2. Mettere Exchange in Gmail (ormai il client unico di android è diventato Gmail)
    Purtroppo un solo service Exchange può esistere sul cell quindi avendo messo quello Gmail ho dovuto togliere quello stock Nubia.
    Non voglio stare a fare configurazioni diverse per chi vuole uno e per chi preferisce l'altro, quindi fatemi sapere se l'attuale struttura mail non vi piace così nella prossima release lascio tutto stock Nubia....
  14. #440
    Quote Originariamente inviato da pesa1234 Visualizza il messaggio
    Non credo cambi qualcosa ma se vuoi puoi provare ad installare la nuova versione del service Exchange google che trovi qui
    sotto system\app\Exchange3Google cnacella l'app attuale e sostituisci con quella nuova
