Pagina 95 di 130 primaprima ... 45859394959697105 ... ultimoultimo
Visualizzazione dei risultati da 941 a 950 su 1298
[ROM LOLLIPOP Android 5 Mod By BB72 & Cuoco92] ZTE Nubia Z7 Max |COMBO ROM|
  1. #941
    Quote Originariamente inviato da manuelb Visualizza il messaggio
    [quote name="ChupaChups10Dolla" post=6892645]E allora boh....
    fai un wipe cache e poi flasha questo pacchetto che é la baseband della 3.09 ed hai risolto...
    https://mega.co.nz/#!N9hzCL7Q!3rUzS8...884DI9HsF8f140
    se vuoi aggiornare alla 3.15 puoi farlo tranquillamente, riflasha poi la baseband della 3.09[/QUOTE]
    Fatto, upgradato a 3.15 e flashato baseband 3.09. Pare vada bene. Grazie milleeee!!!
    Oct 2014
    Ringraziato 16 volte in 12 Posts
    Hi,
    I am on 3.09, i want to flash again with 3.09 with Nubia tool V2. I had many times flash with Nubia tool but now when i tried to flash in three second, I am facing Internal Modem error and flash got stopped.
    BB i have check your solution but this applicable to while downgrading to 1.64 right. For 3.09 reflash what i have to do for this same error. In my EMMDownload.ini following files are there:
    Version\Internal\Modem\Intrinsic=NX505J_Z0_CN_DSXP K1JD11H164;NX505J_Z0_CN_DSXPK1JD11J213;NX505J_Z0_C N_DSXPK1JD11J308;NX505J_Z0_CN_DSXPK1JD11J309;;
    Version\Internal\Modem\Extrinsic=NX505J_Z0_CN_DSXP K1JD11H164;NX505J_Z0_CN_DSXPK1JD11J213;NX505J_Z0_C N_DSXPK1JD11J308;NX505J_Z0_CN_DSXPK1JD11J309
    Please tell me what files need to select and delete the in third step. Can you please little elaborate.
  4. #943
    Quote Originariamente inviato da niza2000in Visualizza il messaggio
    Hi,
    I think you can follow the same process by deleting those lines....to be honest I do not understand why to use so often the Nurbia tool....
    Inviato dal mio Lenovo K50-t5 usando Androidiani App
  5. Il seguente Utente ha ringraziato BB72 per il post:
    niza2000in (08-06-15)
  6. #944
    Oct 2014
    You mean i need to delete following entire lines, suppose if i delete will i not stuck some where during flash right..?
    Version \ Internal \ Modem \ = Intrinsic NX505J_Z0_CN_DSXP K1JD11H164; NX505J_Z0_CN_DSXPK1JD11J213; NX505J_Z0_C N_DSXPK1JD11J308; NX505J_Z0_CN_DSXPK1JD11J309 ;;
    Version \ Internal \ Modem \ Extrinsic = NX505J_Z0_CN_DSXP K1JD11H164; NX505J_Z0_CN_DSXPK1JD11J213; NX505J_Z0_C N_DSXPK1JD11J308; NX505J_Z0_CN_DSXPK1JD11J309
    I want to take nandroid back up of 3.09 stock, thathz why i want to flash again..
  7. #945
    I Posted a nandroid backup of the 3.15 stock in the manuelb thread....you can use that one for the OTA....
  8. Il seguente Utente ha ringraziato BB72 per il post:
  9. #946
    Oct 2014
    Hi,
    I need Stock 3.09 Nandroid backup if you have please share...
  10. #947
    Oct 2014
    Stock 3.09 can help to reflash with tool in case any problem in future with my phone.
    Thats why i am seeking stock 3.09 Nandroid backup...
  11. #948
    Androidiano VIP L'avatar di manuelb
    Honor 6 Plus/Opo/Asus tf300t
    Ringraziato 670 volte in 497 Posts
    niza this is a backup of 3.15 stock https://mega.co.nz/#!R9NjgYiB!PvhjKg...QZVGlVu1qXujeM you can flash on this the 3.16 but before you must flash original stock recovery
  12. Il seguente Utente ha ringraziato manuelb per il post:
  13. #949
    Oct 2014
    Thanks brother....
  14. #950
    A new Combo Rom for 3.16 ?
    Or are possibile to upgrade on 3.16 ?
    Ho scaricato l'update 3.16 ma da quanto ho capito ho bisogno della recovery originale ?
    O semplicmente con la 3.15 combo non posso andare con la 3.16 ?
