ciao volevo sapere come fare il backup dell'app originale note oppure dove vengono salvati i dati per poter fare lo slocco. grazie
ho trovato questo
Notes are stored in SQLite database /data/user/0/com.miui.notes/databases/note.db and therefore the file is not accessible to user without root.
You can find your notes in Mi Cloud if MIUI account is allowed to sync.
in pratica o le salvi sul cloud Mi con l'utility backup, o per tirarle fuori e rimettere poi, dovresti fare con adb o avere il rootQuote:
According to this post the data is also not stored in Internal Storage/Android/Data/com.miui.notes. That leaves only the app-private storage under /data/data/com.miui.notes/ where you only have access to on rooted devices. If you have adb access you can try adb backup com.miui.notes
