Pagina 50 di 75 primaprima ... 40484950515260 ... ultimoultimo
Visualizzazione dei risultati da 491 a 500 su 749
[ROM][DirtyDev] CM10.1 - CM10.2
  1. #491
    Samsung Galaxy Ace Plus (SGAP)
    Quote Originariamente inviato da Giugiu19 Visualizza il messaggio
    non ne sono sicuro ma penso dal'app conta che non è stata sviluppata per il nostro terminale ma ce solo su i top gamma XD
    provo ad installarne un'altra versione e vi faccio sapere
    Baby Droid L'avatar di bbivan
    Sep 2013
    Hi [TEAM] Dirty Developers,
    First i need to thanks from you all.. you guys is really great. i found one of the proplem is Whatsapp on CM10.2 "Can't verify phone number. on CM10.1 is working properly. Hope developers able to solve this problem.. whatspp is one of the important for me for conversation with family or friend member.
    You support is much appreciate. Thanks.
    https://play.google.com/store/apps/d...d=com.whatsapp
  4. #493
    Androidiani Power User L'avatar di imre
    Bologna
    Nexus 5
    Ringraziato 1,000 volte in 466 Posts
    @capo93 svoice fa proprio parte della rom....
    @bbivan i've had the same problem 2 times, first time i choose the call to confirm, second time i've deleted all whatsapp data and reinstalled it. In both cases whatsapp work....try and report if no work
    Alchemy ROM per Samsung Galaxy Ace Plus
    se vuoi ringraziarmi usa il tasto thanks
  5. #494
    Sep 2013
    Hi imre & capo93
    So finally is work for me , I've deleted all whatsapp file in sdcard0 and reinstalled it. please make sure backup everthing to ur sdcard1 first. Thank you. Currently i much like [TEAM] Dirty Developers cm10.2. please keep develope and update. Thanks.
  6. #495
    Ringraziato 271 volte in 209 Posts
    Quote Originariamente inviato da bbivan Visualizza il messaggio
    Hi imre & capo93
    Hi bbivan! So finally you found us Pleased to have you also here
    ROM: CyanogenMod 11 by DirtyDev
    KERNEL: 3.0.101 Dirty Kernel
    E se ti sono stato d'aiuto non dimenticare il tasto thanks
  7. #496
    Bologna
    Nexus 5
    Hi imre & capo93
    I'm glad that you solved.....pls next time can you use our github for bug? And attach a logcat
    Hope to see your comment again
  8. #497
    Androidiano VIP L'avatar di smartandroidtech
    Ringraziato 163 volte in 114 Posts
    Quote Originariamente inviato da imre Visualizza il messaggio
    Ma anche noi oppure i bug e i logcat possiamo lasciarveli anche qui ?
    PC:
    *CPU: Intel Core I5 3470 3.2GHz.
    *RAM: 8GB.
    *GPU: ZOTAC GeForce GTX 970 AMP! Extreme Core Edition
    *HDD: 1TB WD.
    *MotherBoard: Asus P8H77.
    Google Nexus 5:
    *Versione Android: 6.0.0
    *Rom: Stock
    *Kernel: Elemental X 6.00
  9. #498
    Senior Droid L'avatar di SergiX44
    Verona
    Galaxy Note II + Ace Plus
    Ringraziato 33 volte in 32 Posts
    Io se posso essere sincero non ho capito come segnalare i bug si github XD
    Galaxy Note II:
    ROM: Android Revolution HD 4.4.2 Kitkat
    KERNEL: 3.0.101 Agni pureStock
    Galaxy Ace Plus:
    ROM: SpeedMod KK by GiuGiu19
    KERNEL: 3.0.101 giugiu@SpeedMod-PC
  10. #499
    Bologna
    Nexus 5
    Mi fa piacere vedere che leggete i commenti che lascio XD......bug segnalazioni e quant'altro vanno lasciati su github con tanto di logcat
  11. #500
    Ok con la prossima build farò così, grazie
    PC:
    *RAM: 8GB.
    *HDD: 1TB WD.
    Google Nexus 5:
    *Rom: Stock
