Pagina 53 di 75 primaprima ... 343515253545563 ... ultimoultimo
Visualizzazione dei risultati da 521 a 530 su 749
[ROM][DirtyDev] CM10.1 - CM10.2
  1. #521
    Ace Plus GT-S7500
    Ringraziato 95 volte in 66 Posts
    Quote Originariamente inviato da bbivan
    Hi Lox,
    I just install Real racing 3 Hd games to CM10.2, Unfortunately is lag seriously even not able to play as well. last time when i still in stoc rom android 2.3.6 is able to play. please let me explain abit about the RR3 games, for the latest RR3 now is no longer support android 2.3.x anymore. now is android 4.0 and above and games data files is mush bigger size about 1GB Plus. i always put in sdcard1 of the games data files. so all RR3 data files folder will be in my sdcard1, meanwell sdcard0 also got RR3 folder, is just the folder same names as my sdcard1 of RR3 games inside is no data files. so what i do is combined both directory together using foldermouth apps from playstore. previously i using directorybind apps in android 2.3.6. now is not workable in cm102. cause directorybind can't found the Sdcard1. so i am 100% sure bind the both directory is working properly for RR3.
    Now the problem is seriously lag of RR3 in cm10.2. Hope Dirly dev able to find out the solutions. Again really appreciate you guys work hard all the time. Thank you
    Directorybind- not workable in cm10
    [TOOL] DirectoryBind - move data to external_sd (GameLoft, Shadowgun etc.) ROOT req. - xda-developers
    Foldermout- workable in cm10
    https://play.google.com/store/apps/d...evasque.fmount
    as I reported long ago, Link2SD wirks well with this ROM. This shoild allow you to move app and its data to the SD card. Wouldn't that help?
    Inviato dal mio GT-S7500 usando Androidiani App
    (se vi sono stato d'aiuto premete il tasto "thanks"; se ho detto una scemenza, premete il tasto "stupid", se non trovate il tasto "stupid", ma vi ho fatto sorridere, premete il tasto "thanks" comunque, che al giorno d'oggi il buon umore è una cosa preziosa!!!! )
    Baby Droid L'avatar di bbivan
    Sep 2013
    Hi,
    Thanks for you suggestion is working for me with foldermounth app. now is not the binded problem, i just explain how is this RR3 work in our device (GT-S7500), because the games data file is much bigger size (1gb plus). so must put in to External Sd only can work. the problem is i install this games to CM10.2, is lag seriously even (crashing/freezing) when the games launch/playing, is not able to play as well. Thanks.
    Ultima modifica di bbivan; 15-01-14 alle 09:07
  4. #523
    Androidiano VIP L'avatar di Giugiu19
    Porto Torres
    Galaxy S5mini (SM-G800F)
    Ringraziato 698 volte in 354 Posts
    hello I think it is a hardware problem that can not run the game properly but I see you do some research to find the reason why it does not work
    Seguimi su Twitter per informazioni su nuove uscite e aggiornamenti!@Giugiu19
    per chi vuole donare per sostenere lo sviluppo
  5. #524
    Androidiani Power User L'avatar di imre
    Bologna
    Nexus 5
    Ringraziato 1,000 volte in 466 Posts
    Quote Originariamente inviato da bbivan Visualizza il messaggio
    Hi,
    I've tried some driver for adreno 200..but no one offer a good performance in egl2.0 games. In the next build i wanna try the vanilla driver, i hope that give new life at gpu. Tnx for supporting andò visita our facebook fan page
    Alchemy ROM per Samsung Galaxy Ace Plus
    se vuoi ringraziarmi usa il tasto thanks
  6. #525
    Sep 2013
    Hi Team Dirty Dev,
    Thanks for you all help, appreciated ..Yesterday i also try report to the RR3 game developer, not sure whether is the games got bugs of the android version 4.0 & up. also Hope next build update give our device good perfomance too Seriously actually currently is great already for Dirty Dev team cm10.2 compare with others cm10 rom .
  7. #526
    Bologna
    Nexus 5
    Quote Originariamente inviato da antfior93 Visualizza il messaggio
    Raga due curiositá: perché non si vedono le anteprime delle foto ma appare il triangolo di allerta sopra e poi com'è possibile che le librerie della fotocamera siano cosi difficili da trovare, fixare?? Cavolo ma questo telefono è veramente sfortunato hahaha. Grazie e raga complimenti siete forti!!
    Strano bug e mai manifestato, servirebbe un logcat dell'app contatti per capire il problema. Per quanto riguarda le librerie c'è poco da fare abbiamo davvero un telefono sfigato!
  8. #527
    Xperia SP - Paranoid neXus ROM
    Ringraziato 45 volte in 41 Posts
    Quote Originariamente inviato da imre Visualizza il messaggio
    Imre non penso sia un problema dell'app contatti, a me lo da ad esempio quando provo a inviare un'immagine con whatsapp, ma se guardo le immagini dalla galleria no. Non ci avevo dato troppo peso pensando fosse colpa della mia sd che ogni tanto mi da problemi ma a quanto pare non è così. Se mi dici di cosa può esser utile il logcat ve lo faccio e ve lo invio!
  9. #528
    Messa la ROM ieri sera. Viaggia molto bene, complimenti. Soltanto ho notato un consumo abbastanza elevato della batteria.ier sera ho ripristinato le app connesso alla wireless e al carica batterie e il telefono si è scaricato del 20%! È normale?
  10. #529
    Porto Torres
    Quote Originariamente inviato da nem0 Visualizza il messaggio
    Prova a fare un logcat su whastapp e vedi se risulta l errore e ce lo inviii in privato
    Quote Originariamente inviato da Nemesis87 Visualizza il messaggio
    Jelly bean di suo consuma tantissimo come gia detto il cell non arrivera mai al consumo della stock ma e un problema che anno tutti i terminali che montano jelly bean forse la situazione migliorera in futuro con kitkat e successivi
    Inviato dal mio GT-S7500 con CyanogenMod 11 usando Androidiani App
  11. #530
    Segnalo il problema alla applicazione google play service.
    Non funziona e crasha.
    Per il resto, complimentoni, avete fatto un'ottimo lavoro!
    Amo la boot animation.
