Pagina 192 di 214 primaprima ... 92142182190191192193194202 ... ultimoultimo
Visualizzazione dei risultati da 1,911 a 1,920 su 2131
[ROM][JB 4.2.2][JDQ39E] CyanogenMod 10.1 [ADC Team]
  1. #1911
    Samsung Galaxy S Plus I9001
    In Xda il post è fatto cosi. Significa che le GApps sono già integrate nel kernel?!
    20131124 KERNEL: (DL from Dev-Host)
    MD5SUM: fe0e25678467a8f901b7827294010a46
    ATTENTION: This kernel is included in the rom... this download is in case of custom kernel installed and want to come back to stock!
    Kernel 3.4.70
    msm: kgsl: Avoid turning on GPU clock if already off (credits to Ananta Kishore K)
    Revert "ALSA: fix oops in snd_pcm_info() caused by ASoC DPCM" (credits to Christopher83)
    Add exFAT support (credits to radu) (Tested on Samsung 64GB SDXC uhs1 PRO card)
    Update defconfigs for exFAT support (credits to Christopher83)
    input: Updates to Phantom Key Presses filter (credits to Christopher83)
    msm: vidc: Check validity of userspace address (credits to Deepak Verma)
    ALSA: pcm: check for integer overflow during multiplication (credits to Phani Kumar Uppalapati)
    base: genlock: Zero a structure before sending it to user space (credits to Jordan Crouse)
    qt602240_ts: updated touchscreen driver in according of Multi-touch protocol (credits to CastagnaIT)
    Clone ion.h to msm_ion.h (credits to Arco68)
    20130812 GApps (DL from Goo.im) (DL from androidfilehost)
    MD5SUM: 5f22f046e37038a3856eeb825e73d4ed
    Samsung Galaxy S Plus (GT-I9001)
    Rom: AriesVE DevConnection Team CM 11 ION release4
    Kernel: stock/ provando da poco KKernel OC UV 366 v1.7
    Recovery: TWRP v2.6.3.0 ADC Team
    Baseband: XXKPO
    Governor: smartassV2 , I/O Scheduler: SIO
    Senior Droid L'avatar di nextlevel
    Ringraziato 38 volte in 31 Posts
    Con la versione 9 consigliate di usare sempre un kernel diverso tipo il k-kernel o quello della rom va bene lo stesso?
    Smartphone: Samsung Galaxy SIII
    ROM: Cyanogenmod 13
  4. #1913
    Androidiano L'avatar di capnet
    Scusate ma per installare la rc9 bisogna reinstallare pure le googleapps e kernel o va come fix lo so di essere troppo stupido
  5. #1914
    Androidiani Power User L'avatar di leonbeson
    Sull'Adda
    N6P, N5 e il mitico i9001
    Ringraziato 1,168 volte in 825 Posts
    Quote Originariamente inviato da daryo24 Visualizza il messaggio
    In Xda il post è fatto cosi. Significa che le GApps sono già integrate nel kernel?!...
    no dario24, è tecnicamente impossibile includere le gapps nel kernel
    Significa (parafrasando): "questo kernel è già incluso nella ROM, mettiamo questo download (del custom kernel già incluso nella ROM) nel caso in cui abbiate messo un altro kernel e vogliate tornare al kernel stock della ROM", ossia basta riflashare questo kernel per tornare a quello stock della ROM senza riflashare l'intera ROM
    Quote Originariamente inviato da nextlevel Visualizza il messaggio
    EDITATO: ciao nextlevel, se vuoi puoi metterne anche un altro (K^K, castagna o phenom)
    Quote Originariamente inviato da capnet Visualizza il messaggio
    come diceva il poeta, domandare è lecito, rispondere è cortesia
    le gapps sono sempre le stesse del 12/08/2013, mentre per il kernel ti installa quello stock, se l'avevi cambiato devi nuovamente flashare quello che avevi. Quando dici "o va come fix" qua non ti capisco..
    Ultima modifica di leonbeson; 26-11-13 alle 17:27
  6. I seguenti 2 Utenti hanno ringraziato leonbeson per il post:
    capnet (26-11-13),nextlevel (26-11-13)
  7. #1915
    Samsung Galaxy S Plus GT-I9001
    Ringraziato 53 volte in 49 Posts
    Cercando di fare un fix permission...
    ecco il log:
    I:fix permissions started!
    I:Mount: Unable to find partition for path '/sd-ext'
    Fixing permissions...
    Loading packages...
    Iarsing package, 16384...
    Parser error: expected =
    Start of string:
    E:Error parsing XML file.
    Parser error: expected ' or "
    Start of string:
    Parser error: expected >
    Start of string:
    Parser error: unexpected end of data
    Start of string:
    Start of string:
    E:No package found to fix.
    I:Unmounting main partitions...
    Done.
    I:Set page: 'action_complete'
    I:Set page: 'clear_vars'
    I:Set page: 'advanced'
    I:Set page: 'confirm_action'
    I:Set page: 'action_page'
    I:Copying file /tmp/recovery.log to /sdcard/recovery.log
  8. #1916
    Quote Originariamente inviato da leonbeson Visualizza il messaggio
    ciao nextlevel, anche la versione 9 monta il K^K, poi se vuoi puoi metterne una versione diversa o anche un altro (castagna o phenom)
    Che significa monta il KK? non monta lo stock?
    Baseband: XXKPO
  9. #1917
    Non capisco più niente :what:
  10. #1918
    Sull'Adda
    ehm.. piccolo refuso, monta un kernel stock 3.4.x senza supporto di undervolt e overclock, dal primo post:
    Quote Originariamente inviato da Matt95 Visualizza il messaggio
    La ROM monta di default il kernel 3.4.x .....
    non monta lo stock?
    certamente, per stock si intende che quel kernel è di default sulla ROM, poi se vuoi puoi cambiarlo.
    colpa mia capnet, ti ho confuso chiamandoti lo stock con il k^k, sarà perchè è il mio preferito ti ho corretto anche la risposta nel post sopra
    Ultima modifica di leonbeson; 26-11-13 alle 17:28
  11. Il seguente Utente ha ringraziato leonbeson per il post:
    capnet (26-11-13)
  12. #1919
    Quindi riepilogando:
    1: flash rom
    2:flash googleapps
    3: flash kernel
    4:vari wipe
    Giusto?
  13. #1920
    Sull'Adda
    Mannaggia capnet.. il buon matt ha passato la notte insonne ad aggiornare.. dai primi post:
  14. Il seguente Utente ha ringraziato leonbeson per il post:
    Matt95 (26-11-13)
