Pagina 77 di 83 primaprima ... 27677576777879 ... ultimoultimo
Visualizzazione dei risultati da 761 a 770 su 830
[KERNEL][3.4.x][JB] K^Kernel 3.4.x per JB 4.2.2 e JB 4.3
  1. #761
    Pescara
    Samsung Galaxy S Plus
    Ringraziato 228 volte in 153 Posts
    Quote Originariamente inviato da luigi977 Visualizza il messaggio
    2450 GHz -.-. vedi ke ho l s plus e puo arrivare fino a 1804 GHz. sai xke si blocca?
    Non tutti gli esemplari sopportano overclock e undervolt
    SAMSUNG GALAXY S PLUS (GT-i9001)
    ROM: CM11 by AriesVE DevConnection Team
    KERNEL: K^Kernel 3.4.x con pkf
    • home_allowed_irqs = 1
    • home_report_wait = 11
    GOVERNOR CPU: SmartassV2
    FREQs: 245 MHz - 1401 MHz
    SCHEDULER I/O: noop
    BASEBAND: I9001XXKPO
    RECOVERY: TWRP 2.7.0.0 by ADC Team
    Senior Droid L'avatar di Christopher83
    Samsung Galaxy S Plus (I9001)
    Ringraziato 1,307 volte in 314 Posts
    Ciao a tutti,
    ho rilasciato le build v2.4 del kernel pronte per essere usate con le nuove rom ADC CM 10.1 R8, ADC CM 10.2 A3 e le future derivate:
    codice:
    - Kernel 3.4.66
    - Sources synched with cm-10.1 and cm-10.2 repo branches of Arco68 and DevCon Team
    - Built with my latest custom Linaro 4.7.4-2013.09 toolchain optimized for Cortex-A8
    - msm: display: Prevent fb suspend in charging mode for ancora only
    - decompressor: Add LZ4 decompressor module (credits to Kyungsik Lee)
    - lib: Add support for LZ4-compressed kernel (credits to Kyungsik Lee)
    - arm: Add support for LZ4-compressed kernel (credits to Kyungsik Lee)
    - lib: Add lz4 compressor module (credits to Chanho Min)
    - crypto: Add lz4 Cryptographic API (credits to Chanho Min)
    - lib/lz4/lz4_compress: fix macro usage error (credits to Faux123)
    - LZ4: compression/decompression signedness mismatch (v2) (credits to Sergey Senozhatsky)
    - binder: use freezable blocking calls (credits to Colin Cross)
    - epoll: use freezable blocking call (credits to Colin Cross)
    - select: use freezable blocking call (credits to Colin Cross)
    - af_unix: use freezable blocking calls in read (credits to Colin Cross)
    - usb: gadget: mass_storage: added sysfs entry for cdrom to LUNs (credits to FrozenCow)
    - Resolved problems of magnetic, proximity and orientation sensor (credits to CastagnaIT)
    - Updated default and custom configs for new sensor drivers and LZ4 support
    Fate riferimento a questo post per calibrare il sensore magnetico:
    Procedura di calibrazione
    Nota:
    Quest'ultima versione del kernel richiede una rom con le nuove librerie aggiornate, attualmente disponibili sulle ultime rom ADC, ma probabilmente nei prossimi giorni anche gli altri dev rilasceranno le loro rom aggiornate.
    Ultima modifica di Christopher83; 15-10-13 alle 23:40
    Samsung Galaxy S Plus (GT-I9001)
  4. I seguenti 10 Utenti hanno ringraziato Christopher83 per il post:
    Ahasvero (16-10-13),dell (16-10-13),Fury (16-10-13),leonbeson (16-10-13),Leorocky (15-10-13),orzobimbo (16-10-13),Pilone92 (16-10-13),ppippo (16-10-13),sinistro (16-10-13),Wallace75 (16-10-13)
  5. #763
    Senior Droid L'avatar di Leorocky
    Nexus 5/7; Samsung GT-9001
    Ringraziato 360 volte in 287 Posts
    Grazie, Kernel v2.4 aggiornato insieme alla ROM R8, grande lavoro e ottimo risultato!
    Samsung GT-i9001
    Rom : ADCTeam CM11 R17
    Kernel : 3.4.106-K^Kernel v5.0 OC/UV 425MB-
    Recovery : TWRP-2.8.1.0
    Baseband : XXKPO
    Nexus 5 16Gb | Nexus 7 32Gb (Flo)
    Rom\Kernel : Stock
  6. Il seguente Utente ha ringraziato Leorocky per il post:
    Christopher83 (16-10-13)
  7. #764
    Quindi l'ultima versione non va bene per la liquid con patch RC5?
  8. #765
    Androidiano VIP L'avatar di Pilone92
    Venezia
    SAMSUNG S+ - LG G2 - ONEPLUS 5
    Ringraziato 514 volte in 421 Posts
    Non credo. Devi aspettare un'ulteriore patch per i sensori..
  9. Il seguente Utente ha ringraziato Pilone92 per il post:
    orzobimbo (17-10-13)
  10. #766
    Androidiano VIP L'avatar di pierm
    S plus +tab2.1 3G
    Ringraziato 639 volte in 457 Posts
    ciao christopher
    volevo ringraziarti per la fluidità del nuovo kernel la 3.4.66. Sono riuscito a far girare anche la exuv che prima mi dava problemi di S.O.D., grazie alla dritta di ktulu con la creazione dello swap ram su SD ext, che porta peraltro una maggiore la fluidità del kernel. Per cui i famosi problemi che ho sempre riscontrato della gestione dei numerosi widget, caselle e-mail e apk in ram e' sparita. I freeze sono quasi inesistenti e devo dire anche i riavvii. Pensa che riesco anche a gestire la hight bar e la navigation bar prevista nella pacman jb4.3 (krisli e' stato bravissimo in questo).
    Con il PKF gli interrupt sono dai 2 ai 5 in tre giorni. Manca solo riuscire a calibrare la batteria al 75% di ricarica o massimo 80%, perche' con l'apk trickster non funziona (mi tocca fare da terminale, devo controllare se nelle tue feature di xda lo script vale anche in caso di riavvio e non si azzera).
    Riesco cosi anche ad avere un buon drain battery (un giorno va piu' che bene) e un deep sleep che e' sceso al 79% ma con tutto cio' che ho detto lo considero ottimo lo stesso.
    Certo devo dirti che la pacman jb 4.3 ha una funzione nelle impostazioni che ha reso ancora piu' vantaggioso la gestione della ram. Parlo dell Hardware acceleration. Nel quale riesco a disattivare quelle apk che si insidiano nella ram infruttuosamente, portando una migliore gestione.
    Grazie di tutto e buon lavoro come sempre.
    Quote Originariamente inviato da orzobimbo Visualizza il messaggio
    ci sono i kernel che vanno bene dopo la RC5, devo vedere se li hanno messi nel thread o nella rom liquid
    S+ i9001 DarkCM + gapps Team ADC
    TWRP_2.6.3.0_ariesve - Governor On demand 245-1401 I/O row - Band/DDKP0
    Samsung Tab 2.10+3G slimbean
    mi trovi anche qui twitter dcroma
    Il thanks! e' gratis e La Wiki di dell serve a tutti, impariamo a leggerla
  11. Il seguente Utente ha ringraziato pierm per il post:
    Christopher83 (18-10-13)
  12. #767
    Venezia
    Mitico e non dico altro
    Immagini allegate
  13. Il seguente Utente ha ringraziato Pilone92 per il post:
  14. #768
    Senior Droid L'avatar di spiderman1961
    Avella
    Galaxy S4/S+/Tab2/, OmniaII,
    Ringraziato 160 volte in 129 Posts
    Quote Originariamente inviato da pierm Visualizza il messaggio
    ... Sono riuscito a far girare anche la exuv che prima mi dava problemi di S.O.D., grazie alla dritta di ktulu con la creazione dello swap ram su SD ext, che porta peraltro una maggiore la fluidità del kernel...
    Ciao Pierm... Forse mi sono perso il suggerimento di ktulu, potresti spiegarmi in cosa consiste per favore?
    Se ti sono stato utile è gradito un THANKS
  15. #769
    S plus +tab2.1 3G
    Ho creato uno swap RAM su SD ext per avere più RAM. Ti mando appena rientro tutta la procedura
  16. Il seguente Utente ha ringraziato pierm per il post:
    spiderman1961 (18-10-13)
  17. #770
    Avella
    Ok aspetto
