Pagina 15 di 20 primaprima ... 51314151617 ... ultimoultimo
Visualizzazione dei risultati da 141 a 150 su 197
[KERNEL][3.4.x][KK] K^Kernel 3.4.x per KitKat ION+PMEM ADSP
  1. #141
    Senior Droid L'avatar di Christopher83
    Samsung Galaxy S Plus (I9001)
    Ringraziato 1,307 volte in 314 Posts
    Ciao a tutti,
    ho rilasciato le nuove build del kernel v2.8.
    Changelog:
    codice:
    - Kernel 3.4.103
    - Built with my latest custom Linaro 4.9.2-2014.08 toolchain optimized for Cortex-A8
    - Removed bcmdhd driver (credits to CastagnaIT)
    - net: wireless: bcmdhd: bring bcmdhd version 1.28-27 (credits to CastagnaIT)
    - net: wireless: bcmdhd: Fix SUPPORT_PM2_ONLY option for p2p (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.4 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.6 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.7 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Fix WEP-104 authentication (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.10 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Prevent recursive call of cfg80211_sched_scan_stopped() (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Enable full scan on PNO event (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.11 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.16 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Close p2p0 device in wl_down (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.21 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Fix tdls processing from cfg80211 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.27 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Fix NDO functionality (credits to ECCO PARK)
    - net: wireless: bcmdhd: Enable p2p support bits for p2p device (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Remove PASS_ARP_PACKET define (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Remove chatty message from wl_cfgp2p_act_frm_search (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.41 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.42 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Update to version 1.88.45 (credits to Ecco Park)
    - net: wireless: bcmdhd: enable WL_IFACE_COMB_NUM_CHANNELS (credits to Ecco Park)
    - net: wireless: bcmdhd: Update Location Service code (credits to Ecco Park)
    - net: wireless: bcmdhd: Fix of Wireless Location Service (credits to Ecco Park)
    - net: wireless: bcmdhd: new feature for Roaming. (credits to Ecco Park)
    - net: wireless: bcmdhd: Fixed Coverity issue. (credits to Ecco Park)
    - net: wireless: bcmdhd: fix for negative padding (credits to Ecco Park)
    - net: wireless: bcmdhd: Fixed Wi-Fi Location Service issues. (credits to Ecco Park)
    - net: wireless: bcmdhd: add code for WLS service. (credits to Ecco Park)
    - net: wireless: bcmdhd: Fix country checking (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: fixed power consumption issue of P2P. (credits to Ecco Park)
    - net: wireless: bcmdhd: Fixed a problem of buganizer issue (11190960) (credits to Ecco Park)
    - net: wireless: bcmdhd: reduced the wakelock time of RX packet (credits to Ecco Park)
    - net: wireless: bcmdhd: cancel current PNO if connection will happen (credits to Ecco Park)
    - net: wireless: bcmdhd: Change DTIM skip policy in suspend (credits to Ecco Park)
    - net: wireless: bcmdhd: Set MAX_DTIM_ALLOWED_INTERVAL to 600 (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Enable IPv6 RA filter feature (credits to Ecco Park)
    - net: wireless: bcmdhd: enable TDLS_auto_mode (credits to Ecco Park)
    - net: wireless: bcmdhd: Sync with N5 branch (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Change the parameter for TDLS (credits to Ecco Park)
    - net: wireless: bcmdhd: support Hotspot 2.0 release 1.0 (credits to Ecco Park)
    - net: wireless: bcmdhd: Add WIPHY_WOWLAN_ANY support (credits to Dmitry Shmidt)
    - net: wireless: bcmdhd: Add support for hidden ssid PNO scan (credits to Ashwin)
    - net: wireless: bcmdhd: added samsung specific code (credits to CastagnaIT)
    - net: wireless: bcmdhd: readded samsung MCAST_LIST_ACCUMULATION code updated from jf (credits to CastagnaIT)
    - drivers: usb: Use Android device as USB keyboard/mouse (credits to Pranav Vashi)
    - touchscreen: ancora: Update touchscreen API (credits to sirmordred)
    - touchscreen: ancora: Add missing BTN_TOUCH (credits to arco68)
    - mmc: msm_sdcc: Remove unnecessary delay in interrupt context (credits to Venkat Gopalakrishnan)
    - USB: msm_otg: Fix host mode suspend bug (credits to Sujeet Kumar)
    - USB: msm_otg: Fix a bug in charger detection procedure (credits to Pavankumar Kondeti)
    - msm: kgsl: Force the ME off before reading the microcode (credits to Jordan Crouse)
    - msm: kgsl: Increase the timeout value for fault detection (credits to Shubhraprakash Das)
    - msm: kgsl: Don't hold the refernce to the process private in kgsl create context (credits to Gaurav Gagrani)
    - n_tty: Fix n_tty_write crash when echoing in raw mode (credits to Peter Hurley)
    - msm_bam_rmnet: Fix potential memory corruption (credits to Subash Abhinov Kasiviswanathan)
    - fs: exFAT: Update to v1.2.9 (credits to arco68)
    - msm: qdsp5v2: Convert all audio devices to ION. (credits to Blefish)
    - msm: qdsp5v2: Minor code sync. (credits to Blefish)
    - devices-msm7x30: #ifdef around msm_nand device (credits to arco68)
    - board-ancora: Minor updates and changes (credits to arco68)
    - lcd: ancora: Adjust porch values for rev. 2 panels (credits to arco68)
    - lcdc:ancora:Adjust porch values for rev. 1 panels too (credits to arco68 and sirmordred)
    Le nuove build includono dei driver Wifi aggiornati e sincronizzati con quelli di Google (grazie a CastagnaIT per questo importante aggiornamento).
    Samsung Galaxy S Plus (GT-I9001)
  2. I seguenti 11 Utenti hanno ringraziato Christopher83 per il post:
    Ahasvero (12-09-14),Andreagia94 (12-09-14),Belamav (12-09-14),Boanerghes (12-09-14),Hirishiolo (12-09-14),Leorocky (12-09-14),Matt9001 (14-09-14),Nicolett (12-09-14),salvon (12-09-14),samulomba96 (14-09-14),Wallace75 (12-09-14)
    Androidiano L'avatar di FrAnChIni
    Mar 2014
    Galaxy S Plus/Lg G2
    Grande!!!!!!
    Inviato dal mio GT-I9001 usando Androidiani App
    <-- Se ti sono stato utile , ricordati il THANKS, grazie <--
  5. Il seguente Utente ha ringraziato FrAnChIni per il post:
    Christopher83 (13-09-14)
  6. #143
    Jan 2014
    Ferrara
    Lg Nexus 5, Galaxy S-Plus
    Ringraziato 44 volte in 37 Posts
    Grandissimo!
    Simone Belamav Casadio
    ex - Galaxy Ace-i quasi stock defunto
    Galaxy S-plus KitKat
    Lg Nexus 5 Red
  7. Il seguente Utente ha ringraziato Belamav per il post:
  8. #144
    scusate non ho capito le differenze tra le diverse versioni, mi aiutate per favore?
  9. #145
    Androidiano L'avatar di Nicolett
    Jun 2014
    Ringraziato 17 volte in 13 Posts
    Quote Originariamente inviato da bigletterato Visualizza il messaggio
    Ci sono varie versioni in base a quanta memoria vuoi a disposizione, io ovviamente ti suggerisco la 416 Poi per ogni kernel delle varie memorie c'è quella UV (undervoltage) e la exuv ( extreme undervoltage). Io ti suggerisco la exuv , se poi noti che il NS. GS+ si riavvia da solo installa la UV!! Christopher83, scusa se ho detto cavolate e nel caso correggimi!!!!
  10. I seguenti 2 Utenti hanno ringraziato Nicolett per il post:
    bigletterato (13-09-14),Christopher83 (13-09-14)
  11. #146
    Sanremo
    Huawei p8 lite
    Perdona la mia ignoranza ma che differenza c'è nel mettere il kernel più o meno grande?
  12. #147
    Jun 2014
    Quote Originariamente inviato da Sceriffo82 Visualizza il messaggio
    Non è il kernel più o meno grande è la RAM a disposizione più o meno grande!!! Meglio averla grande, no!?
  13. I seguenti 2 Utenti hanno ringraziato Nicolett per il post:
    Christopher83 (14-09-14),Sceriffo82 (13-09-14)
  14. #148
    Sanremo
    Huawei p8 lite
    Ah ecco,già il mio Samsung S+ non ne ha molta se poi la riduco è ancora peggio.........mi accingerò al più presto a mettere il 416.Grazie
  15. #149
    Androidiano L'avatar di jacano98
    Mar 2014
    zona verona
    S plus
    Quote Originariamente inviato da Nicolett Visualizza il messaggio
    si questo è il pro, ma ci sara anche un contro se ci sono 3 versioni di ram disponibili !!!!!!!!!
  16. #150
    Jun 2014
    Quote Originariamente inviato da jacano98 Visualizza il messaggio
    Apparentemente no! Diciamo che come per il discorso dell' uv e dell' Exuv se dovessero emergere problemi di riavvii frequenti, lag importanti o freezzature provare a tornare verso una quantità di RAM tendente a quella stock (398) ! Ma diversamente ai problemi sporadici con l' Exuv , la RAM da 416 non mi risulta abbia dato problemi, anzi è quella da 398 che è più facile vada in crisi con app "esose" (tipo game)!!!
