Pagina 9 di 20 primaprima ... 789101119 ... ultimoultimo
Visualizzazione dei risultati da 81 a 90 su 197
[KERNEL][3.4.x][KK] K^Kernel 3.4.x per KitKat ION+PMEM ADSP
  1. #81
    Senior Droid L'avatar di Christopher83
    Samsung Galaxy S Plus (I9001)
    Ringraziato 1,307 volte in 314 Posts
    Ciao a tutti,
    ho rilasciato le nuove build del kernel v2.1 pronte per essere usate con la nuova rom ADC CM 11.0 Release 7 (dovrebbero andare anche sulla precedente Release 6):
    codice:
    - Kernel 3.4.93
    - Sources synched with cm-11.0 repo branch of DevCon Team
    - Built with my latest custom Linaro 4.9.1-2014.05 toolchain optimized for Cortex-A8
    - New kernel branch based on kk_2.7-stable branch of Code Aurora Forum
    - Up to 406MB of free RAM thanks to the dynamic allocation via CMA of ION heap related to MM features (camcorder, video playback/recording/encoding)
    - ksm: Provide support to use deferred timers for scanner thread (credits to Chintan Pandya)
    - net: ipv6: ping: Use socket mark in routing lookup (credits to Lorenzo Colitti)
    - net: add a sysctl to reflect the fwmark on replies (credits to Lorenzo Colitti)
    - net: support marking accepting TCP sockets (credits to Lorenzo Colitti)
    - mmc: core: enable eMMC5.0 card detection (credits to Subhash Jadavani)
    - block: bfq: Squashed update from BFQ-v7r3 to BFQ-v7r4 (credits to arco68)
    - futex: Prevent attaching to kernel threads (credits to Thomas Gleixner)
    - futex: Add another early deadlock detection check (credits to Thomas Gleixner)
    - futex-prevent-requeue-pi-on-same-futex.patch (credits to Thomas Gleixner)
    - futex: Validate atomic acquisition in futex_lock_pi_atomic() (credits to Thomas Gleixner)
    - futex: Always cleanup owner tid in unlock_pi (credits to Thomas Gleixner)
    - futex: Make lookup_pi_state more robust (credits to Thomas Gleixner)
    - msm7x30: Update defconfigs (credits to Christopher83)
    - Revert "msm: pm2: Setup memory for save/restore cpu registers early" (credits to Christopher83)
    - Revert "ARM: 7169/1: topdown mmap support" (credits to Laura Abbott)
    - msm7x30: Use CMA for MM ION heap (credits to Christopher83, Blefish, Chintan Pandya)
    - msm7x30: Update defconfigs to enable CMA (credits to Christopher83)
    - mm: try_to_unmap_cluster() should lock_page() before mlocking (credits to Vlastimil Babka)
    - msm:vidc: Amend error checks on ION API failures (credits to Maheshwar Ajja)
    - ion: cma: Add debug heap ops for CMA heap (credits to Chintan Pandya)
    - ariesve: New high memory configurations (380MB, 388MB, 398MB, 406MB) (credits to Christopher83)
    - msm7x30: Update default and custom configs (credits to Christopher83)
    Note:
    Ora la memoria dello heap MM ION (usato dal camcorder, durante video playback/encoding) è dinamicamente allocato attraverso il framework CMA e la memoria viene liberata quando non usata in modo tale da essere disponibile per altri processi.
    Le nuove configurazioni della memoria sono:
    - 380MB di RAM libera, ha la stessa memoria disponibile del kernel stock, configurazione stabile, tutto funziona correttamente, ma potreste avere dei forti rallentamenti con le app che richiedono molta RAM
    - 388MB di RAM libera, ha 8 MB in più di memoria libera rispetto al kernel stock, configurazione adatta a chi usa il cel principalmente per chiamate, messaggi, semplici app e semplici giochi. La fotocamera, la registrazione video (sia a 480p che 720p) e video playback funzionano perfettamente
    - 398MB di RAM libera, ha 18 MB in più di memoria libera rispetto al kernel stock, è la mia configurazione preferita ed è adatta a chi usa app più pesanti magari anche contemporaneamente, vari widget, giochi un po' pesanti. La fotocamera, la registrazione video (sia a 480p che 720p) e video playback funzionano perfettamente
    - 406MB di RAM libera, ha 26 MB in più di memoria libera rispetto al kernel stock, configurazione adatta a chi usa app e giochi pesanti. La fotocamera e video playback funzionano correttamente, mentre la registrazione video è possibile solo a 480p (ricordatevi di impostare, nelle opzioni della fotocamera, questa modalità prima di installare questa configurazione)
    Attenzione:
    Per favore non attivate l'opzione KSM (Kernel Samepage Merge) all'interno di Impostazioni -> Prestazioni -> Gestione Memoria -> Fusione pagine kernel. Questa funzionalità può causare dei problemi di allocazione della memoria quando usate la registrazione video a 720p o nella visualizzazione di video HW/HW+.
    Buon week end!
    Samsung Galaxy S Plus (GT-I9001)
  2. I seguenti 14 Utenti hanno ringraziato Christopher83 per il post:
    Ahasvero (14-06-14),Andreagia94 (14-06-14),antfior93 (15-06-14),Hirishiolo (14-06-14),leonbeson (14-06-14),Leorocky (14-06-14),Matt9001 (29-06-14),Matt95 (16-06-14),Nello96 (14-06-14),pablonik79 (19-06-14),ppippo (16-06-14),samulomba96 (14-06-14),SkyWolker (14-06-14),Wallace75 (16-06-14)
    Androidiano VIP L'avatar di Ahasvero
    Mar 2011
    Salerno, Campania
    Galaxy S4, Galaxy S Plus
    Ringraziato 308 volte in 254 Posts
    Quote Originariamente inviato da Christopher83 Visualizza il messaggio
    Ciao a tutti,
    Sto utilizzando il nuovo Kernel da questa mattina ed l telefono non è mai stato così fluido e reattivo! Sino ad ora non ho riscontrato alcun problema.
    Grazie per il lavoro, come sempre, ineccepibile
    ROM: [5.1.1_r13][07/09/15]Resurrection Remix 5.5.8 EOL
    Kernel: ​Stock
    Governor/Scheduler: SmartassV2/sio
    Recovery:
    TWRP v2.8.1.0
  5. Il seguente Utente ha ringraziato Ahasvero per il post:
    Christopher83 (14-06-14)
  6. #83
    Senior Droid L'avatar di Leorocky
    Nexus 5/7; Samsung GT-9001
    Ringraziato 360 volte in 287 Posts
    Quote Originariamente inviato da Ahasvero Visualizza il messaggio
    Sottoscrivo e confermo, incredibile i risultati che avete ottenuto.
    Grazie per tutto ciò che fate!!!
    Samsung GT-i9001
    Rom : ADCTeam CM11 R17
    Kernel : 3.4.106-K^Kernel v5.0 OC/UV 425MB-
    Recovery : TWRP-2.8.1.0
    Baseband : XXKPO
    Nexus 5 16Gb | Nexus 7 32Gb (Flo)
    Rom\Kernel : Stock
  7. Il seguente Utente ha ringraziato Leorocky per il post:
  8. #84
    Androidiano VIP L'avatar di Andreagia94
    Aug 2013
    Floridia, Sicilia
    Google Nexus 5X
    Ringraziato 715 volte in 515 Posts
    Qualcosa oltre natura..alla faccia tua Samsung!
    LG Google Nexus 5X (Carbon)
    ROM: Nougat Stock 7.0 & Kernel 3.10
    Miei lavori su S Plus: Slim CyanogenMod 11.0 - 12.0/1 (Slim CM)
    Miei lavori su S3 Neo: Slim CyanogenMod 11.0
    --> Se ti sono stato utile, THANKS in basso a sinistra! <--
  9. Il seguente Utente ha ringraziato Andreagia94 per il post:
  10. #85
    Motorola Moto G XT1032
    Ringraziato 18 volte in 14 Posts
    Quando vedo: "RAM 327 MB usati 73 MB liberi" mi commuovo (KK 398MB).
    Grazie.
  11. I seguenti 2 Utenti hanno ringraziato ppippo per il post:
    Christopher83 (16-06-14),Matt95 (16-06-14)
  12. #86
    Jan 2014
    Ferrara
    Lg Nexus 5, Galaxy S-Plus
    Ringraziato 44 volte in 37 Posts
    Fenomenale!!!!!
    Simone Belamav Casadio
    ex - Galaxy Ace-i quasi stock defunto
    Galaxy S-plus KitKat
    Lg Nexus 5 Red
  13. Il seguente Utente ha ringraziato Belamav per il post:
    Christopher83 (18-06-14)
  14. #87
    Ciao a tutti,
    ho rilasciato le build del kernel v2.2:
    codice:
    - Kernel 3.4.94
    - Built with my latest custom Linaro 4.9.1-2014.06 toolchain optimized for Cortex-A8
    - Revert "mdp4_overlay_lcdc: Fixed wrong initialization of VSYNC" (credits to arco68)
    - gpu: ion: Sync CMA caching logic with carveout heap. (credits to Blefish)
    - defconfigs: Build crypto devices as modules (credits to arco68)
    - msm: dma: Moving queue_work() function within spinlock (credits to Utsab Bose)
    - msm: kgsl: Add the buffer user address to the debugfs memory list (credits to Jordan Crouse)
    - msm: kgsl: use %pK to restrict printing GPU / memory addresses (credits to Jordan Crouse)
    - sched: Reset rq->next_interval before going idle (credits to Srivatsa Vaddagiri)
    - sched: re-calculate a cpu's next_balance point upon sched domain changes (credits to Srivatsa Vaddagiri)
    - ARM: 7486/1: sched_clock: update epoch_cyc on resume (credits to Colin Cross)
    - ARM: 7565/1: sched: stop sched_clock() during suspend (credits to Felipe Balbi 2)
    - sched: Set MC (multi-core) sched domain's busy_factor attribute to 1 (credits to Srivatsa Vaddagiri)
    - msm: kgsl: Cleanup the memory free list (credits to Jordan Crouse)
    Questa release include la fix ai problemi riscontrati durante la navigazione nella app Galleria o guardando video su YouTube.
  15. I seguenti 9 Utenti hanno ringraziato Christopher83 per il post:
    Ahasvero (19-06-14),Andreagia94 (19-06-14),Boanerghes (19-06-14),leonbeson (18-06-14),Leorocky (18-06-14),Matt9001 (29-06-14),ppippo (19-06-14),samulomba96 (20-06-14),Wallace75 (20-06-14)
  16. #88
    Androidiano VIP L'avatar di pablonik79
    galaxy s advance /s3 neo
    Ringraziato 287 volte in 226 Posts
    ciao a tutti , tengo a dire che il mio telefono è l' s advance , oggi un amico stava per lanciare dalla finestra il suo s plus, allora mi sono messo all'opera , quindi ho installato questa rom che sembra essere le migliori ( le altre non le ho provate ) [ROM][ION][KK][4.4.3][KTU84M] CyanogenMod 11.0 ION by ADC-Team - Kernel 3.4.x,
    il telefono è rinato, ancora era a gingerbread stock, gli uscivano le lacrime quando ha visto i risultati, poi ho letto i kernel suggeriti e ho installato questo del thread, unico dilemma ( ho letto tutte le pagine) l'oc regge al max, se non sbaglio arriva a 1,8 Ghz, o che configurazione oc scheduler mi consigliate per ecquilibrio velocità autonomia?
    Un grosso ringraziamento allo sviluppatore del kernel, quando ho visto che il bnl funziona perfettamente, e sul mio advance no rodevo dall'invidia
  17. #89
    Senior Droid L'avatar di samulomba96
    Torino
    NEXUS 5 , Xiaomi Mi A 2 Lite
    Ringraziato 193 volte in 150 Posts
    Solo l'Exuv arriva a 1800 mhz se non sbaglio
    Inviato dal mio Nexus 5
    SE SONO STATO UTILE , NON RINGAZIARMI MA, PREMI IL TASTO !!
    TELEFONO:LGE Google Nexus 5 32 Gb
    ROM:Purity Rom Lollipop 5.0.2
    KERNEL:Hells Core L
    BASEBAND:M8974A-2.0.50.2.22
    AUDIO:Faux Sound - Quality
    PC:Linux Kubuntu 14.04 Lts 64Bit
  18. #90
    Nov 2013
    Galaxy S4, ex Galaxy S Plus
    Quote Originariamente inviato da pablonik79 Visualizza il messaggio
    Settalo come lo settiamo praticamente tutti...... Minima: 245 Mhz, Max 1401Mhz, Governor SmartassV2, I/O Sio
    Questo è il migliore e credo il più equilibrato. Non ho fatto altri tentativi perchè cosi mi trovo benissimo, perciò non so dirti se ci sono combinazioni migliori!
  19. Il seguente Utente ha ringraziato Boanerghes per il post:
    pablonik79 (20-06-14)
