Pagina 30 di 86 primaprima ... 2028293031324080 ... ultimoultimo
Visualizzazione dei risultati da 291 a 300 su 855
[Samsung Galaxy S7] Notifiche Aggiornamenti Ufficiali
  1. #291
    Androidiano L'avatar di Psyf00l
    Da sammobile risulta che sia uscito Nougat per gli S7 brandizzati H3G 😲
    Senior Droid L'avatar di magiczazza
    Galaxy S9
    Ringraziato 33 volte in 33 Posts
    Quote Originariamente inviato da Psyf00l Visualizza il messaggio
    Da sammobile risulta che sia uscito Nougat per gli S7 brandizzati H3G ��
    Forse ci siamo, io ho Voda, speriamo si sbirghino
    Che la forza sia con voi
    E' ORA DI MOLLARE iPhone DEFINITIVAMENTE, ANDROIDIANO A VITA
  4. #293
    Confermo per il brand h3g
    After aggiornamento bisogna ancora eseguire le varie procedure per il ripristino?
    Inviato dal mio S7 Androidiani App
    Ultima modifica di mjrko; 21-02-17 alle 13:05
  5. #294
    Androidiano L'avatar di Skirmish
    Android 7.0 Nougat for the Galaxy S7 and S7 edge expanding to a slew of countries today
    ABHIJEET M. / 4 HOURS AGO
    It looks like today is the day that the Nougat update for the Galaxy S7 and Galaxy S7 edge will make its true global debut. Samsung has pushed the update to only a handful of countries since the rollout began last month, but the update seems to be reaching a lot more markets today, particularly in Europe and the Middle East. The official Nougat firmware for these regions are now available for download from our firmware section (here for the S7 and here for the S7 edge), and the update should also be making its way to devices over the air in the coming days.
    As always, those unwilling to wait can download the firmware for their country from our database and do a manual upgrade using a PC; the update should also be available through Samsung’s Smart Switch program. To see what’s new on the latest version of Android, don’t forget to take a look at our comprehensive list of features. You can also check out the video below for a quick walkthrough, and check out a few tips and tricks to get the most out of Nougat on your Galaxy S7 or Galaxy S7 edge.
  6. #295
    Galaxy S7
    Ringraziato 18 volte in 15 Posts
    Questa mattina appena acceso il mio terminale (vodafone) mi segnalava un aggiornamento sw , ho provato a farlo ma subito dopo è comparso il messaggio che il terminale era già aggiornato alla versione più recente ...
    errare è umano , ma per fare veramente casino ci vuole la password di root
  7. #296
    Galaxy S9
    Quote Originariamente inviato da trombetta Visualizza il messaggio
    Anch' io ho Vodafone, su SamMobile ancora niente, anche in Australia hanno aggiornato...
  8. #297
    Per ora la 3 ha aggiornato
  9. #298
    Ringraziato 28 volte in 24 Posts
    Quote Originariamente inviato da magiczazza Visualizza il messaggio
    Anche a me stessa cosa. S7 flat no brand italia..
  10. #299
    Galaxy S7
    Quote Originariamente inviato da albys70 Visualizza il messaggio
    so che non hanno ancora rilasciato l'aggiornamento , la cosa che mi sembrava strana era la notifica appena acceso rivelatasi infondata
  11. #300
    Androidiano L'avatar di Phill-R6
    Ringraziato 15 volte in 12 Posts
    Confermo...
    Aggiornato S7 H3G via Ota ma notifica anche su switch
