Rendere il sistema Android stabile
    Makes android system stable and efficient battery can done in many ways. Some of them is to turn off application or feature that are not being used. There are two ways that you can try, but what can only be done if you have the root android.
    Preparation
    Download*Minfreemanager and*install*in your android Download*sysctl config *root* Download*busybox, in case sysctl config *root* *need it. Root Android device (MUST!),*read here to root android Setting for MinFreeManager Open
    MinFreeManager
    Set the paramater foreground
    app = 6 mb
    visible app = 8 mb secondary*server*= 16 mb
    hidden app = 60 mb
    content provider = 70 mb
    empty app = 80 mb
    Option -> apply -> aplly at*boot
    Setting for Sysctl Config
    Open Sysctl Config Set the*parameter Sysctl suppot =enable
    in free kbites = 16384
    dirty ratio = 90
    dirty background ratio = 55
    VFS cache Pressure = 20
    Oom Allocating task = enable
    option -> reboot With this new setting,
    Unused applications will be close automatically. Your RAM will be keep around 80Mb. It`s not like task killer that do a force close, this setting will close unused application with smoothly. Closing with smoothly will make system more smooth and the battery life span is more longger.
    Localitą
    Berghčm de sura e de sota
    Galaxy S III
    Quote Originariamente inviato da sagiter Visualizza il messaggio
    Preparation
    MinFreeManager
    app = 6 mb
    hidden app = 60 mb
    empty app = 80 mb
    dirty ratio = 90
    non ho capito molto.. cmq qualcuno lo ha provato?? non si puo mettere in italiano? grz....
    Androidiani Power User L'avatar di d128b
    Jun 2010
    Localitą
    spica,wave,nexusS,xperiaZ
    Ringraziato 722 volte in 409 Posts
    1, se proprio vogliamo scrivere una guida sforziamoci di farlo in italiano. Il copia/incolla mi disgusta.
    2, questa guida non rende affatto il sistema stabile. Lo peggiora.
    Per dimostrare che non mi sto inventando la cosa, invito tutti gli interessati a leggere questa guida
    https://www.androidiani.com/forum/an...u-android.html
    dove l'utente crimescene spiega egregiamente come android gestisce la ram in automatico e perchč č inutile utilizzare task killer o similari.
    Sperando di essere stato chiaro, chiudo questo thread.
    Buona giornata a tutti
    Xperia Z 1 compact @ stock
    Flash! - un amaro racconto di vita
    che ha riportato in vita il mio nexus S quando tutto sembrava perduto)
