Pagina 15 di 112 primaprima ... 513141516172565 ... ultimoultimo
Visualizzazione dei risultati da 141 a 150 su 1120
[GUIDA] Eseguire ROOT e UNROOT Samsung Galaxy W (GT-I8150)
  1. #141
    Baby Droid L'avatar di alexsensei
    Ho seguito tutte le istruzione, ma non mi ha il root. Ecco l'errore:
    --- STARTING ----
    --- WAITING FOR DEVICE
    --- cleaning
    rm failed for *, No such file or directory
    --- pushing zergRush"
    3752 KB/s (23056 bytes in 0.006s)
    --- correcting permissions
    --- executing zergRush
    [**] Zerg rush - Android 2.2/2.3 local root
    [**] (C) 2011 Revolutionary. All rights reserved.
    [**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
    [+] Found a GingerBread ! 0x00029118
    [+] Found a Samsung, running Samsung mode[*] Scooting ...[*] Sleeping a bit (~40s)...[*] Waking ![*] Sending 149 zerglings ...[*] Sleeping a bit (~40s)...[*] Waking ![*] Sending 189 zerglings ...
    [-] Hellions with BLUE flames !
    --- WAITING FOR DEVICE TO RECONNECT
    if it gets stuck over here for a long time then try:
    disconnect usb cable and reconnect it
    toggle "USB DEBUGGING" (first disable it then enable it)
    --- DEVICE FOUND
    --- pushing busybox
    3008 KB/s (1075144 bytes in 0.349s)
    --- remounting /system
    mount: permission denied (are you root?)
    --- copying busybox to /system/xbin/
    /system/xbin/busybox: cannot open for write: Read-only file system
    --- correcting ownership
    Unable to chmod /system/xbin/busybox: No such file or directory
    --- installing busybox
    /system/xbin/busybox: not found
    --- pushing SU binary
    failed to copy 'files\su' to '/system/bin/su': Read-only file system
    Unable to chmod /system/bin/su: No such file or directory
    --- correcting symlinks
    rm failed for /system/xbin/su, Read-only file system
    link failed Read-only file system
    --- pushing Superuser app
    failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only
    file system
    --- cleaning
    --- rebooting
    ALL DONE!!!
    Premere un tasto per continuare . . .
    Come non detto, ho trovato lo script per il mio firmware nello stesso thread. Dispositivo rootato.
    Quote Originariamente inviato da alexsensei Visualizza il messaggio
    --- STARTING ----
    --- cleaning
    --- DEVICE FOUND
    --- pushing busybox
    file system
    --- cleaning
    --- rebooting
    ALL DONE!!!
  4. #143
    Quote Originariamente inviato da ringhio74 Visualizza il messaggio
    Salve a tutti,
    sono riuscito, con il recovery mode, a rootare il mio galaxy W. Volevo togliere i porcai che chi sono installati di default, ma nella lista applicazioni non appare il disinstalla. Nessuno mi può dare qualche info.
    Tra le altre cose lo script di unroot fuonziona tranquillamente per tornare indietro.
    I dati del telefono sono:
    Versione 2.3.6
    BB I8150XXKL3
    build gingerbread.xxla2
    puoi dirmi quale guida hai usato per rootare?
  5. #144
    ciao sono nuovo e ho scaricato i file del root ma risultano infetti, poi volevo chiedere se questa guida va bene per il mio software (I8150XXKK1), e infine se qualcuno mi può passare i link dei file di root e unroot....grazie
  6. #145
    Ciao ragazzi la mia domanda è la seguente:
    Ho da poco aggiornato il fw al 2.3.6 e vorrei roottare per fare un'pò di pulizzia da cose per me inutili. Vorrei sapere se dopo aver unroottato il W quando andrò a fare i futuri aggiornamenti mi rispunteranno o meno le app indesiderate da me cancellate coi permessi di root
    In poche parole vorrei solo eliminare definitivamente app di default che non userò mai e poi mantenere lo smartphone originale.
    Grazie in anticipo!
  7. #146
    Senior Droid L'avatar di PioBernardo
    Abruzzo
    LG G2 - Samsung Note N8000
    Ringraziato 52 volte in 40 Posts
    Dopo un devastante periodo tra lavoro ed esami eccomi qui, anch'io rootato. E ora Thanko Fender e vado di Cwr. Yeah.
    Ops, intendevo snake.
  8. #147
    Firenze
    Galaxy Wonder
    Quote Originariamente inviato da stun91 Visualizza il messaggio
    Ho usato il recovery con il file update .zip . Il metodo dei tre tasti all' accensione o poi selezioni il file e alla fine il telefono si riavviare con il programma super user.
  9. #148
    bene, appena effettuato l'accesso da amministratore anch' io con in recovery è stato l'unico modo per portare a termine con successo l' operazione, tramite la procedura da guida, provata sia da windows che da linux, non ho ottenuto esito positivo.
  10. #149
    ma questo procedimento è anche valido per il galaxy s 2 versione 2.3.4?
    e cosa sarebbe il galaxy w che vedo spesso scritto da alcuni utenti.....come avrete capito sono nuovo del forum ...avevo un galaxy s che ho smarrito e mi sono appena comprato il galaxy s2 ....
    Inoltre il mio galaxy s era rootato ed aggiornato con sconcau...andata fortissimo , ma adesso mi mancano alcune funzionalità sul 2....come per esempio la segnalazione con lucette sui tasti di messaggi ricevuti o chiamate mancate...o la lettura ed ingrandimento dei messaggi ricevuti....potete aiutarmi?
    Ultima modifica di ciscodrum; 13-02-12 alle 14:06
  11. #150
    il galaxy w (wonder) è un normale terminale di casa samsung con sistema operativo android, la procedura per abilitare i permessi di root su un s2 è differente da questa relativa per il w.
