Pagina 307 di 467 primaprima ... 207257297305306307308309317357407 ... ultimoultimo
Visualizzazione dei risultati da 3,061 a 3,070 su 4668
[STAR][G9000 S5 MTK6592] 1.7GHz 1920x1080 Ram 2Gb [MODDING]
  1. #3061
    Ringraziato 29 volte in 25 Posts
    Flat questo è il file GPS.conf ottimizzato. NTP_SERVER=0.it.pool.ntp.org
    NTP_SERVER=1.it.pool.ntp.org
    NTP_SERVER=2.it.pool.ntp.org
    NTP_SERVER=3.it.pool.ntp.org
    NTP_SERVER=0.europe.pool.ntp.org
    NTP_SERVER=1.europe.pool.ntp.org
    NTP_SERVER=2.europe.pool.ntp.org
    NTP_SERVER=3.europe.pool.ntp.org
    NTP_SERVER=it.pool.ntp.org
    XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
    XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
    XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
    # DEBUG LEVELS: 0 - none, 1 - Error, 2 - Warning, 3 - Info
    # 4 - Debug, 5 - Verbose
    DEBUG_LEVEL =0
    # Intermediate position report, 1=enable, 0=disable
    INTERMEDIATE_POS=0
    # Accuracy threshold for intermediate positions
    # less accurate positions are ignored, 0 for passing all positions
    ACCURACY_THRES=0
    # Report supl ref location as position, 1=enable, 0=disable
    REPORT_POSITION_USE_SUPL_REFLOC=1
    # Wiper (wifi positioning), 1=enable, 0=disable
    ENABLE_WIPER=1
    ##### AGPS server settings #####
    # FOR SUPL SUPPORT, set the following
    SUPL_HOST=supl.google.com
    SUPL_PORT=7276
    SUPL_NO_SECURE_PORT=3425
    SUPL_SECURE_PORT=7275
    SUPL_TLS_HOST=FQDN
    SUPL_TLS_CERT=/etc/SuplRootCert
    # FOR C2K PDE SUPPORT, set the following
    C2K_HOST=c2k.pde.com
    C2K_PORT=1234
    CURRENT_CARRIER=common
    DEFAULT_AGPS_ENABLE=TRUE
    DEFAULT_SSL_ENABLE=FALSE
    # TRUE for "User Plane", FALSE for "Control Plane"
    DEFAULT_USER_PLANE=TRUE
    Inviato dal mio Star Kingelon G9000 usando Androidiani App
    Le righe NTP_SERVER multiple non servono perchè lo standard prevede un solo NTP_SERVER
    Il file dovrebbe essere (/systsem/etc/gps.conf)
    DEBUG_LEVEL =0
    INTERMEDIATE_POS=0
    ACCURACY_THRES=0
    ENABLE_WIPER=1
    SUPL_PORT=7276
    SUPL_TLS_HOST=FQDN
    C2K_PORT=1234
    it.pool.org switch automaticamente in base al carico dei server su 1.it.pool.org, 2.it.pool.org, etc.
    Ultima modifica di bovirus; 03-11-14 alle 15:38
  4. #3063
    Oct 2014
    Quote Originariamente inviato da flatflay Visualizza il messaggio
    No no ho risolto per la batteria e grazie ai consigli di bovirus, ora datemi il tempo (siate elastici) rifaccio tutta la rom e la sistemo...
    Per Bovirus, appena finisco di sistemare la rom te la posto in versione backup preparazione dei file per flashtool, come mi avevi chiesto, cosi sostituiamo la 442 con questa. ok?
    flatfly ti ringrazierò all'infinito. quindi aspetto la nuova rom. speriamo si possa fare con flashtool che è più facile. casomai risolvo anche il problema della perdita del segnale che da stanotte tra l'altro non ho più avuto. ma perdonami, state studiando anche qualcosa per il gps? aggancia i fix dopo tantissimo tempo (con questa grandezza di schermo il navigatore sarebbe utilissimo). buon lavoro. siete grandi tu, bovirus ma anche provendj
  5. #3064
    Androidiano L'avatar di gekkofragger
    Nov 2013
    Cariati
    Star Kingelon G9000
    Questo è il mio hardware. Quale rom mi consigliate?
    Immagini allegate
  6. #3065
    @luca7304
    Non vedo difficoltà nell'usare l'aggironamento via recovery.
    Basta avviare la recovery e scegliere Install ZIP.
    Questo sistema non richiede modifiche di partizionamento, driver USB preloader, metti togli la batteria, etc.
    L'uso di flashtool è molto più rischioso ed espone a danni seri non usato correttamente.
    Per l'uso del GPS va fissato (una volta caricato il file gps.conf corertto) in engineer mdoe scaricando i file EP.DAT corretti.
    Lo puoi anche fare suando programmi tipo fasterGPS.
  7. #3066
    Senior Droid L'avatar di NforceRaid
    Xiaomi Mi 9T - Mi 9T Pro
    Ringraziato 173 volte in 144 Posts
    Ciao, un mio collega ha il g9000 e da stamattina non parte più, già provato le 2 batterie ma non succede nulla non parte proprio, i giorni scorsi mi ha detto che ha avuto un riavvio per problemi di ram (di più non mi ha detto), oltre ad usarlo come fermacarte cosa posso provare per vedere di resuscitarlo? sempre che non sia un problema HW, in quel caso deve tentare la via della garanzia.......
    grazie e ciao
  8. #3067
    Prova se funziona lea recovery VOL+ e POWEr.
    Se funziona fai i tre wipe (vedi post precedenti).
    Altroimenti vedi la procedura per identificare l'harwdare del tuo device (cpu/camera/lcd/touch).
    Poi puoi provare a flashare le ROM presenti qui
    https://www.androidiani.com/forum/st...-16gb-rom.html
  9. Il seguente Utente ha ringraziato bovirus per il post:
    NforceRaid (03-11-14)
  10. #3068
    Oct 2014
    @luca7304
    ok grazie, attendo l'aggiornamento. questo indicatore della batteria mi sta mandando al manicomio. certo che per il gps ci provo. dovrei capire quali sono i file ep.dat corretti
    Ultima modifica di luca7304; 03-11-14 alle 17:09
  11. #3069
    ok, grazie provo
    ciao
  12. #3070
    ASC
    ASC non è in linea
    Jun 2014
    Direi di aspettare un attimo a pubblicare le ROM.
    Appena ho un attimo di tempo pubblico i file di update.zip (da usare bvia recovery) per le 4 ROM con
    boot.img pre-sbloccato e rootato
    build.prop modificato con le impostazioni ottimizzate
    custom.conf modificato con le impostazioni ottimizzate
    gps.conf modificato con le impostazioni ottimizzate
    su (comando admin) dove non disponibile (ROM 16GB 4.2.2).
    Poi ti mando una ROM per vedere una possibile proposta su come distribuire la ROM (nome file zip e struttura all'interno, con i file otiginali e patchati in modo che tutte òle risorse siano integrate).
    Salve...scusate un pochino ....a prescindere che non riesco a scaricare alcuna ROM sia da questo 3D che da quello di "servizio" (https://www.androidiani.com/forum/st...-16gb-rom.html) perchè una volta scaricata da MEGA mi da l'archivio rar che quando vado a scompattarlo da errore....ora, se ho ben capito, ci saranno nuove ROM? per il 16Gb ci sarà la 4.4.2...esatto? saranno ROM da usare con flashtools o da copiare su SD ed installare da lì?. Grazie.-
